POV-Ray : Newsgroups : povray.general : POVWIN beta 38 available Server Time
6 Nov 2026 08:59:55 EST (-0500)
  POVWIN beta 38 available (Message 1 to 8 of 8)
Subject: POVWIN beta 38 available
Date: 1 Jul 2010 11:31:32
Message: <4c2cb4d4@news.povray.org>
There's a new windows beta available, beta 38, which fixes the timeout
issue. It also has a bunch of other fixes and improvements. See
  http://www.povray.org/beta/
for the changelist and download links.
-- Chris
Subject: Re: POVWIN beta 38 available
Date: 1 Jul 2010 12:46:05
Message: <4c2cc64d@news.povray.org>
> -- Chris
Thanks :-D
Best Regards,
Date: 1 Jul 2010 15:30:00
Message: <web.4c2ceca6a25e074a5522d71e0@news.povray.org>
> -- Chris
Goodness gracious, kudos to whomever proposed and/or implemented the display of
filename when hovering over an editor tab and the  right-click menu to editor
tabs!
Well done, POV-team!
-Reactor
Date: 1 Jul 2010 16:30:01
Message: <web.4c2cf9d4a25e074afd5f66790@news.povray.org>
> -- Chris
Sorry, there are some questions and comments
1. In version 3.7 beta38 issue warnings on your own Gold.inc
for example
File: ..\My Documents\POV-Ray\v3.7\include\golds.inc Line: 118
Parse Warning: Expected pure RGB color expression, unexpected filter and
transmit components will have no effect.
2.Using Radiosity:
Compared with version 3.1 beta37a output image has now become VERY
dark.
current settings Radiosity:
global_settings (
  file_gamma 1
  max_trace_level 5
  radiosity (
       count 100
       nearest_count 5
       error_bound 2
       recursion_limit 2
       low_error_factor 0.2
       minimum_reuse 0.015
       gray_threshold 0.0
       brightness 1
       adc_bailout 0.01/2
what's wrong?
Date: 1 Jul 2010 17:15:01
Message: <web.4c2d0456a25e074afd5f66790@news.povray.org>
"Avk61" <kut### [at] academorg> wrote:
> 2.Using Radiosity:
I will explain - daylight falls through the windows and
made as a sphere.
sphere { 0, 11000 inverse
         texture { pigment { rgb <1, 1, 1> }
                   finish  { ambient 15 diffuse 0}
         hollow no_shadow
in version beta38 no light from the sphere
Date: 1 Jul 2010 18:05:01
Message: <web.4c2d1072a25e074afd5f66790@news.povray.org>
I tried to use sky_sphere. Good results.
Date: 1 Jul 2010 18:40:01
Message: <web.4c2d18b8a25e074afd5f66790@news.povray.org>
but..
  radiosity {
    brightness 10 //?
Date: 1 Jul 2010 18:51:10
Message: <4c2d1bde@news.povray.org>
Le 2010-07-01 17:10, Avk61 a écrit :
> "Avk61"<kut### [at] academorg>  wrote:
>> 2.Using Radiosity:
> made as a sphere.
>           texture { pigment { rgb<1, 1, 1>  }
>           hollow no_shadow
Now, ambient is automaticaly turned off for radiosity scenes.
Add emission to the finish.
Date: 1 Jul 2010 19:25:01
Message: <web.4c2d237ea25e074afd5f66790@news.povray.org>
> Alain
ok. It's already clear. Thanks.
Date: 2 Jul 2010 00:34:46
Message: <4c2d6c66@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:4c2cb4d4@news.povray.org...
> -- Chris
Thanks, I can use POV again!
Cheers Dre
Date: 2 Jul 2010 03:34:33
Message: <4c2d9689$1@news.povray.org>
Am 01.07.2010 22:25, schrieb Avk61:
> for example
This is a known issue, and will be addressed when time permits; please
don't worry about it for now.
> 2.Using Radiosity:
> dark.
> what's wrong?
Can you please be more specific? A full scene showcasing the problem may
probably be required for a useful answer; INI and command line settings
might also be needed.
Date: 2 Jul 2010 03:36:30
Message: <4c2d96fe$1@news.povray.org>
Am 01.07.2010 23:10, schrieb Avk61:
> made as a sphere.
>           hollow no_shadow
Yup - there has been a major change regarding ambient and radiosity.
Date: 2 Jul 2010 04:00:20
Message: <4c2d9c94@news.povray.org>
I love POV-Ray....
Thank you indeed, all you marvellous wizards!!
Date: 2 Jul 2010 04:05:42
Message: <4c2d9dd6$1@news.povray.org>
> -- Chris
"Default output file type is now PNG"
Thank you,
Paolo
Date: 2 Jul 2010 04:12:09
Message: <4c2d9f59$1@news.povray.org>
Just one little note, to reduce possible confusion for users:
In povray.ini, it is still mentioned that "up 20 paths may be specified.".
This is not true anymore.
Date: 2 Jul 2010 04:25:00
Message: <web.4c2da1c5a25e074afd5f66790@news.povray.org>
ok.
> > what's wrong?
The answer has already obtained. "AMBIENT" NO LONGER WORKS IN RADIOSITY SCENES"
Thanks.
Date: 6 Jul 2010 09:22:46
Message: <4c332e26@news.povray.org>
Lots of useful improvements, good work team!
