POV-Ray : Newsgroups : povray.general : Can you use the trace command on a heightfield? Server Time
31 Oct 2026 00:29:58 EDT (-0400)
  Can you use the trace command on a heightfield? (Message 1 to 23 of 23)
Subject: Can you use the trace command on a heightfield?
Date: 7 Apr 2010 21:20:25
Message: <4bbd2f59$1@news.povray.org>
Hi, as the title states, can you use the trace command on a heightfield?
I've been trying and trying and I cant get it to work.  I've successfully
used the trace() command on isosurfaces and simple boxes, spheres but I cant
for the life of me get this to work.
Just wondering if this actually does work or I'm barking up the wrong tree!
Cheers Dre
Subject: Re: Can you use the trace command on a heightfield?
Date: 7 Apr 2010 23:42:56
Message: <4bbd50c0@news.povray.org>
"Dre" <and### [at] gmailcom> wrote in message
news:4bbd2f59$1@news.povray.org...
> cant for the life of me get this to work.
> tree!
> Cheers Dre
Date: 7 Apr 2010 23:46:05
Message: <4bbd517d$1@news.povray.org>
> tree!
> Cheers Dre
Nevermind, I worked it out, that trace command has some weirdness about it.
This doesn't work:
#declare norm = <0, 0, 0>;
trace(object, <xPos, 10, zPos>, <xPos, -10, zPos>, norm>)
Yet this does:
#declare startPoint =<xPos, 10, zPos>;
#declare endPoint = <xPos, -10, zPos>;
trace(object, startPoint, endPoint, norm)
Unless I'm doing something wrong, that seems broken to me...
Version 3.6 btw.
Cheers Dre
Date: 8 Apr 2010 03:18:02
Message: <4bbd832a$1@news.povray.org>
"Dre" <and### [at] gmailcom> schreef in bericht
news:4bbd517d$1@news.povray.org...
>> tree!
>> Cheers Dre
> it.
> This doesn't work:
> Yet this does:
No, trace() is not broken. The following always works for me, with whatever
object as target:
    #declare Norm =  <0, 0, 0>;
    #declare Start = <my.x, 10, my.z>;
    #declare Pos = trace (Obj, Start, -y, Norm);
Start must be above the object, so adapt the y value; -y indicates the
direction of tracing.
Date: 8 Apr 2010 05:20:54
Message: <4bbd9ff6$1@news.povray.org>
Am 08.04.2010 05:46, schrieb Dre:
How does the failure-to-work manifest itself? Are we talking e.g. about
a parser error?
> This doesn't work:
> #declare norm =<0, 0, 0>;
> trace(object,<xPos, 10, zPos>,<xPos, -10, zPos>, norm>)
> Yet this does:
> #declare endPoint =<xPos, -10, zPos>;
Well, unless you introduced a typo when writing this posting, I'm not at
all surprised: In the non-working example, you have an extra ">" after
"norm". I'm not sure what the parser makes of this, but most likely not
what you expected.
Date: 8 Apr 2010 05:28:30
Message: <4bbda1be@news.povray.org>
Dre <and### [at] gmailcom> wrote:
> Yet this does:
  I don't think it does (well, not in the way you want). The third parameter
of trace() specifies a direction, not an endpoint.
  Probably you want the third parameter to be <0, -1, 0> because that's
the direction you are shooting the rays towards.
Date: 8 Apr 2010 18:39:44
Message: <4bbe5b30@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4bbd9ff6$1@news.povray.org...
>>> successfully
> How does the failure-to-work manifest itself? Are we talking e.g. about a
> parser error?
No it parses correctly, however none of the intersections are correct, they
are all either at <0, 0, 0> or some weird location.
>> This doesn't work:
>> Yet this does:
> what you expected.
Ooops!  Yes that extra bracket is a typo, sorry.
I just find it weird that it accepts the same vectors as variables, but not
as the actual vector itself...
Cheers Dre
Date: 8 Apr 2010 18:40:49
Message: <4bbe5b71$1@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4bbd832a$1@news.povray.org...
>>> successfully used the trace() command on isosurfaces and simple boxes,
>>> spheres but I cant for the life of me get this to work.
>>> tree!
>>> Cheers Dre
>> it.
>> This doesn't work:
>> Yet this does:
> whatever object as target:
> Thomas
Yes that format works for me too, now try your example without the
variables, put the actual vectors in your Pos declaration and see if you get
the same results.  I dont.
Cheers Dre
Date: 8 Apr 2010 18:48:17
Message: <4bbe5d31$1@news.povray.org>
news:4bbda1be@news.povray.org...
>> Yet this does:
> parameter
>                                                          - Warp
Well it does to what I want now that I changed the way I coded it to the
example above.  I then modified the norm as you stated but it didn't make
any difference at all.  Both my norm and yours are below my start point so
they are essentially shooting the rays in the same direction.
Cheers Dre
Date: 9 Apr 2010 01:48:32
Message: <4bbebfaf@news.povray.org>
> >> Yet this does:
> > parameter
> >                                                          - Warp
  The normal is the *fourth* parameter. I was talking about the *third*
parameter, which is the direction. That should be <0, -1, 0>.
Date: 9 Apr 2010 01:49:18
Message: <4bbebfde@news.povray.org>
  Because you are not shooting the rays towards <0, -1, 0>.
Date: 9 Apr 2010 13:40:00
Message: <web.4bbf648570f2d07d65f302820@news.povray.org>
> > Yet this does:
Warp's correct. (Also, I would assume that <0,-10,0> has the same directional
effect as <0,-1,0> )
There's a big difference between <xpos,-10,zPos> and <0,-10,0> as a *direction*
vector. Let's say xPos=7 and zPos=5.  That produces a *direction* of
<7,-10,5>--which certainly isn't straight down. The trace rays are probably not
even hitting the HF (and your placed object(s) are ending up at a <0,0,0>
location by default, unless you're using Norm to 'stop' that in some way, which
I assume you are.)
As has been mentioned:
* The trace ray 'start' location needs to be somewhere *above* the
HF...obviously  ;-)  Personally, I would use <xPos,1000,zPos> to be safe.
* the 'start' vector is an actual location point; the trace ray direction is a
*directional* vector, NOT the location of a point, and shouldn't normally
change--at least when tracing a HF.
Ken
Date: 10 Apr 2010 03:23:55
Message: <4bc0278b$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> schreef in bericht
news:web.4bbf648570f2d07d65f302820@news.povray.org...
> is a
Yes, and when you want to trace, say, a spherical object, like a planet, the
following macro by Tim Attwood comes in handy:
//start code
//--- Tim Attwood's random distribution macro ---
#macro RandOnSurface(Obj, rsd, thresh)
   #local mn = min_extent(Obj)-thresh;
   #local mx = max_extent(Obj)+thresh;
   #local dist = 1000000;
   #while (dist>thresh)
      #local flag = 0;
      #while (flag = 0)
         #local rfrom = VRand_In_Box(mn, mx, rsd);
         #local rdir = vrotate(<1,1,1>,
            <360*rand(rsd),360*rand(rsd),360*rand(rsd)>);
         #local hit = trace(Obj, rfrom, rdir, Norm);
         #if (vlength(Norm) != 0)
            #local flag = 1;
      #local dist = vlength( hit - rfrom);
   #local result = hit;
   (result)
//end code
Date: 11 Apr 2010 20:19:57
Message: <4bc2672d@news.povray.org>
news:4bbebfde@news.povray.org...
>> they
>                                                          - Warp
I believe I am shooting them in that direction, they are starting at <x, 10,
z> and finishing at <x, -10, y>, thats towards <0, -1, 0> in my mind or am I
wrong here?
Cheers Dre
Date: 11 Apr 2010 20:21:52
Message: <4bc267a0@news.povray.org>
news:4bbebfaf@news.povray.org...
>> >> Yet this does:
>> > parameter
>> >                                                          - Warp
>> so
>                                                          - Warp
What difference does it make if its -1 or -10, they are both in the same
plane.
Or are you saying the 3rd parameters is a direction vector not a final end
point vector?
Cheers Dre
Date: 11 Apr 2010 20:27:14
Message: <4bc268e2$1@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote in message
>> > Yet this does:
>> parameter
> directional
> *direction*
> probably not
> which
> I assume you are.)
> is a
> Ken
Thanks very much for the clarification.  That clears things up completely :)
I was getting the third parameter wrong, I thought it was an end point
rather than a direction vector, I mentioned this in my reply to warp.
So much POV to learn, so little time!
Cheers Dre
Date: 12 Apr 2010 05:15:01
Message: <web.4bc2e33970f2d07d65f302820@news.povray.org>
Not a day goes by that I don't learn something new as well, some new trick that
POV-Ray is capable of, or some new 'understanding.' The best way to learn
is...practice, practice, practice.  ;-) And to read these newsgroups, of
course--they are a real fountain of knowledge.
I remember the trace command being difficult to fully understand as well, when I
first tried to use it. (In fact, a newsgroup query may have helped *me* at the
time.) And that Norm thing had me guessing too--until I finally
realized that the value (the vector) that's placed there--with #declare norm =
<0,0,0> --is just to set it up, as a kind of 'place-holder.' (In fact, the
vector can contain *any* three values.) Then, when trace() is used or called, it
RETURNS an *actual* vector (a directional vector again!) found at the traced
point, and loads it into 'norm', replacing the temporary values--which can then
be used elsewhere in the scene. The documentation describes some of this, but in
a roundabout way, not completely clear. (Which is unfortunate, because trace is
an *extremely* valuable and fun tool!) So don't feel bad about your temporary
lack of understanding.
Ken
Date: 12 Apr 2010 07:47:59
Message: <4bc3086f@news.povray.org>
> >> they
> >                                                          - Warp
> wrong here?
  You are shooting them towards <x, -10, y>, not towards <0, -1, 0> because
that's what you are telling trace() to do.
  You have to do it like this:
trace(TheObject, <X, 10, Z>, <0, -1, 0>, TheNormal)
Date: 12 Apr 2010 07:48:49
Message: <4bc308a1@news.povray.org>
> >                                                          - Warp
> plane.
  <X, -10, Z> is not the same thing as <0, -10, 0>.
> point vector?
  It's a direction vector.
Date: 12 Apr 2010 09:13:40
Message: <4bc31c84$1@news.povray.org>
Le 2010-04-11 20:19, Dre a écrit :
> "Warp"<war### [at] tagpovrayorg>  wrote in message
>>> they
>>> are all either at<0, 0, 0>  or some weird location.
>>   Because you are not shooting the rays towards<0, -1, 0>.
>>                                                           - Warp
> I believe I am shooting them in that direction, they are starting at<x, 10,
> z>  and finishing at<x, -10, y>, thats towards<0, -1, 0>  in my mind or am I
> wrong here?
> Cheers Dre
You are wrong :(
If you start at <x,10,z> and have a direction of <x,-10,z>, then, you
shoot toward <x*2,0, z*2>.
Remember, the first value is the starting location.
The second value is a *direction* vector, it is ADDED to the start
location. If you use a /location/ your tracing rays will fan out.
The result is that most rays, about 75% if the hight_field is around the
X-Z plane, will totaly miss the hight_field. Any ray that don't hit the
target will return a location of <0,0,0> and a normal of <0,0,0>.
If the hight_field is a around -10*y, then only 1/16 trace will hit it,
at the wrong locations.
Date: 12 Apr 2010 21:02:27
Message: <4bc3c2a3$1@news.povray.org>
news:web.4bc2e33970f2d07d65f302820@news.povray.org...
> that
> when I
> the
> norm =
> called, it
> traced
> then
> but in
> trace is
> temporary
> Ken
I totally agree.  There is something very satisfying when you see your scene
finally trace correctly after working out some new process/technique.
Without these groups I would be stuck a long time ago, not to mention the
absolutely amazing pictures you see in p.bi.
Cheers Dre
Date: 12 Apr 2010 21:02:58
Message: <4bc3c2c2@news.povray.org>
news:4bc308a1@news.povray.org...
>> >                                                          - Warp
>> plane.
>> end
>> point vector?
>                                                          - Warp
Yep, that was where I was going wrong.
Thanks for your help!
Cheers Dre
Date: 12 Apr 2010 21:04:52
Message: <4bc3c334$1@news.povray.org>
"Alain" <aze### [at] qwertyorg> wrote in message
news:4bc31c84$1@news.povray.org...
>>>> they
>>>                                                           - Warp
>> 10,
>> am I
>> wrong here?
>> Cheers Dre
> You are wrong :(
> If the hight_field is a around -10*y, then only 1/16 trace will hit it, at
> Alain
Yep, the thing that was messing me up was the fact that I thought the second
value was the final end point not a direction vector.
All sorted now though, thanks for your help!
Cheers Dre
