POV-Ray : Newsgroups : povray.general : Interested in 16-bit height field functions? Server Time
31 Oct 2026 02:14:27 EDT (-0400)
  Interested in 16-bit height field functions? (Message 1 to 19 of 19)
Subject: Interested in 16-bit height field functions?
Date: 12 Dec 2009 12:58:26
Message: <4b23d9c2$1@news.povray.org>
Hello,
I'm developing a set of macros to load and manipulate 16-bit height
field data. With them, you can import red/green 16-bit grayscale images
and manipulate them as you would any other pigment. There are functions
for finding edges (via a proximity pattern), finding angles for special
effects, and even one for exporting red/green images to a few 24-bit
image formats (to compensate for 3.7's rudimentary 16-bit support). They
can be used to add features to existing height field data or to create
new data. The pigments can be used in isosurfaces. I'm keeping my macros
easy-to-use this time :)
Unfortunately, there are limitations. For one, POV-Ray's handling of
image_maps produces strange edge artifacts, so I'm having to bring the
edges of the images down to zero. This creates a sharp drop-off at the
perimeter of the height field. It's not a feature I wanted.
Another problem is speed. A person would have to develop their height
maps in a 2D fashion to avoid high parse times, but the macros *can* be
used directly in a scene.
Considering these limitations, does anyone think they might find such an
include file useful? I'm pretty much done with most of the functions, so
all I need is one response so I can begin making example files!
~Sam
Subject: Re: Interested in 16-bit height field functions?
Date: 12 Dec 2009 13:20:03
Message: <4b23ded3$1@news.povray.org>
stbenge wrote:
> Hello,
such an
> ~Sam
That’s very kind of you Sam. Consider it requested :-)
Best Regards,
Date: 12 Dec 2009 14:24:05
Message: <4b23edd5$1@news.povray.org>
> images and manipulate them as you would any other pigment.
I'm not sure I understand what these do. As far as I know,
Povray 3.6 already supports 16 bit png as input format both
for height fields and image_map pigments. Wouldn't that be
simpler to use than red/green tga?
> There are functions for finding edges (via a proximity pattern),
> finding angles for special effects
I can see these would be useful. Do they work on pigments which
encapsulate height information both in red and green channel or
do you linearize the data into a gray pigment? The latter case
would be more flexible as your processing functions will then
be independed of the height field image format.
> POV-Ray's handling of image_maps produces strange edge artifacts
What kind of edge artifacts do you mean?
Date: 12 Dec 2009 16:27:11
Message: <4b240aaf@news.povray.org>
World Machine and TerraBrush use 16-bit tgas. In the version of WM I
have, the option for png output is not supported yet. My attempts to
convert a 16-bit tga to a png have not been successful; the data is
still encoded with red and green colors, thus resulting in a high
frequency mess. This probably wouldn't be true if I converted it using
POV, but it's faster to use IrfanView :)
Regarding pngs, if a person were to supply a well-supported 16-bit png
to some versions of my functions, then it should work out all right.
The macros will return straight grayscale data, be it 8 or 16-bit data.
Some will load images (converting them to a grayscale pigment), and some
will work directly with whatever pigment you provide for it, including
pre-declared, processed images. All will return grayscale information
which can then be encoded into a red/green height map if one wishes to
do so.
>The latter case would be more flexible as your processing functions will then
My goal is to make the edge and angle functions work with any pigment,
exporting to a few 16-bit pigments.
It only appears at certain times, under certain conditions, when I
convert images to functions. It's a single line of incorrect image info
residing between units. I can try to reproduce the artifact. It happens
with my luminous bloom code if I comment out the fixes I made.
Date: 12 Dec 2009 16:34:35
Message: <4b240c6b@news.povray.org>
Stephen wrote:
> stbenge wrote:
>> Hello,
>> so all I need is one response so I can begin making example files!
>> ~Sam
Date: 14 Dec 2009 03:39:39
Message: <4b25f9cb@news.povray.org>
"stbenge" <UN### [at] hotmailcom> schreef in bericht
news:4b240aaf@news.povray.org...
> World Machine and TerraBrush use 16-bit tgas. In the version of WM I have,
> the option for png output is not supported yet. My attempts to convert a
> 16-bit tga to a png have not been successful; the data is still encoded
> with red and green colors, thus resulting in a high frequency mess. This
> probably wouldn't be true if I converted it using POV, but it's faster to
> use IrfanView :)
WM2, which is also free (with the usual limitations) exports 16bit png
heightfields. My latest landcape here is precisely that.
I am certainly very much interested in your functions, Sam  :-)
Date: 14 Dec 2009 14:55:17
Message: <4b269825@news.povray.org>
>> use IrfanView :)
I'll have to download that. When trying to stitch pieces of 512x512
height fields together, are there still visible seams when using erosion?
Really, I've got only two functions so far: the angle map and the edge
map. The edge map is just a hack from a previous proximity pattern.
The red/green importing functions are just useless novelties. I was
learning how to decode/encode 16-bit data for another project, which, in
the end, won't need that kind of functionality anyway.
Hopefully the angle map can be used to displace pigments from from an
isosurfaces according to angles. This should overcome problems arising
when displacing isosurfaces based on height field data. There might be
another way to do this. It wouldn't be the first time I've tried to
solve a problem the hard way ;)
I was beginning to regret having mentioned this set of macros, but maybe
  you guys will find a good use for them.
Sam
Date: 14 Dec 2009 20:47:28
Message: <4b26eab0$1@news.povray.org>
On 12/12/2009 12:58 PM, stbenge wrote:
> Hello,
> ~Sam
See here:
http://wiki.povray.org/content/Knowledgebase:High_precision_heightfields
Michael Horvath
mik### [at] gmailcom
http://isometricland.com
Date: 15 Dec 2009 01:54:46
Message: <4b2732b6@news.povray.org>
SharkD wrote:
> See here:
That looks really cool, but really slow :( In my include file, I rewrote
some of my comments and code to redirect a user towards using pngs
instead of other formats.
I was unaware that the png format could be used with such flexibility...
Date: 15 Dec 2009 01:55:18
Message: <4b2732d6@news.povray.org>
Stephen wrote:
> stbenge wrote:
>> Hello,
>> ~Sam
All right, it's in p.b.scene-files.
Date: 15 Dec 2009 03:24:27
Message: <4b2747bb$1@news.povray.org>
news:4b269825@news.povray.org...
> I'll have to download that. When trying to stitch pieces of 512x512 height
I am not sure about that as I have not investigated that properly.
Oh yes, you bet!
Thank you very much indeed, Sam.
Date: 9 Jan 2010 02:40:00
Message: <web.4b4830e4dee126c34a0208b20@news.povray.org>
stbenge <UN### [at] hotmailcom> wrote:
> Hello,
> ~Sam
Hi Sam,
I'm trying for a couple of days now to generate a 6000x4000 pixel image of a
hexagon pattern and am at the brink of getting a little desperate. First I tried
it with a smooth-edged hi-res heightfield texture, than with the same texture as
16bit grayscale tga but I still got little jagged edges. Then I tried the Wilbur
software to generate that special red-green tga for POV, which worked nicely,
except that the Wilbur software always crashed, when I wanted to generate a
really big texture (more than 4000x4000 pixels or so). So that didn't work
either for a hi-res rendered image.
Then I came across your .inc files. Do you think they are suitable for making
such a heightfield with a hexagon pattern? Something like this (I used the
tga-texture generated from the wilbur software for the heightfield in this
image):
http://alien23.de/misc/forum_up1.jpg
I tried a little to make a hexagon heightfield with your .inc files (first with
the pov-ray hexagon pattern and than with a hexagon texture map) but I didn't
got very far:
http://alien23.de/misc/forum_up2.jpg
Possibly I'm just too stupid, though.
Best wishes,
Simone
Date: 9 Jan 2010 15:49:44
Message: <4b48ebe8@news.povray.org>
mone wrote:
> Hi Sam,
Hello mone.
> image):http://alien23.de/misc/forum_up1.jpg
Actually, you don't need my include file to accomplish that. POV-Ray has
some special functions in functions.inc. One of them can produce
honeycomb-like patterns. Check this out:
// begin code
// If using 3.7, put +fng at the command line for 16-bit gray scale.
// If using 3.6, uncomment this line:
//global_settings{hf_gray_16 on}
#default{finish{ambient 1}}
camera{
  orthographic
  right x*2 up y*2
  location -z*100
  look_at 0
#include"functions.inc"
plane{z,0
  pigment{
   function{
    f_hex_x(x,y,z, 0)
   color_map{[.7 rgb 0][.9 rgb 1]}
   scale .25
// end code
Not at all! Sometimes we tend to over-think our problems, and we don't
know all our options.
I encourage you to continue reading as much of the documentation as you
can. This way, when a problem arises, solutions will start popping up.
POV-Ray is one of those programs that lets you accomplish many tasks in
several different ways.
I released some hexagonal patterns a while back, you might want to check
them out:
http://news.povray.org/povray.binaries.scene-files/message/%3C482478cb%40news.povray.org%3E/#%3C482478cb%40news.povray.org%3E
Happy Raytracing,
Sam
Date: 9 Jan 2010 15:57:11
Message: <4b48eda7$1@news.povray.org>
I think these macros won't help you as they are designed to
facilitate importing red-green tga data which you didn't yet
manage to create at the desired resolution.
You didn't mention what the actual source of your height_field
data is. The supported formats for 16-bit height_fields in Povray
are either 16-bit PNG grayscale or red-green TGA.
As red green TGA is a POV-specific hack software which uses it is
sparse. You should however manage to find a way to get 16 bit PNG.
You may find the excellent ImageMagick suite helpful:
   http://www.imagemagick.org/script/index.php
Date: 9 Jan 2010 16:12:14
Message: <4b48f12e$1@news.povray.org>
Le 2010-01-09 02:37, mone a écrit :
> Hi Sam,
> image):
> got very far:
In this image, you should NOT have those dark parts along the edges. The
tint should go from dark or black in the center of every hex, and
sharply climb to 1 on BOTH sides of every edges.
> Best wishes,
> Simone
Maybe you can try shearing the pattern to have some vertical as well as
horizontal edges. You then apply an inverse shear to the resulting hight
field.
You still will have one direction with jaggies, but you can use some
juditious rotation, lighting, texturing and camera placement to mostly
hide those.
You can use a small tile that you use many times. That tile only covers
one complete hex and just enough of 4 adjacent ones to create a
continous pattern when tilled. That smaller tile can have much finner
grain than a single one covering the whole thing.
Another solution would be to NOT use an hight field but a mesh that you
replicate as needed. That mesh alone just create a single hex and one
single edge on one side.
Date: 10 Jan 2010 15:40:01
Message: <web.4b4a39f0dee126c3fa00a0a00@news.povray.org>
Thanks to all of you for the useful advice!
> camera{
>   orthographic
>   right x*2 up y*2
>   location -z*100
>   look_at 0
> plane{z,0
>   pigment{
>    function{
>     f_hex_x(x,y,z, 0)
>    scale .25
> // end code
I tried this function and it can generate textures suitable for the heightfield
very quickly, thanks for the code! I tried some changes with the color map in
the code, and wonder if it's possible to change it in a way, that you don't get
a gradient, but only a white on black pattern?
Because all kinds of gradients, which at first I hoped would maybe result in a
rounded or bevelled looking edge in the heightfield instead made it looking
either jagged or make some strange sort of tiny stripes on the heightfield
walls.
So I removed the gradients in Photoshop (which can handle 16bit grayscale png)
and put a gray border around the white edge without antialiasing.
It still looked a little jagged but a lot better than with the gradients.
Another possibility was to cut a little of the top of the heightfield off with
csg. Now all edges looked perfectly smooth, but they also looked a bit boring,
because the top of the edges reflect the radiosity all in the same way and have
the same color. I'm still experimenting with that, though.
Yes. I had searched "hexagon" in the documentation, but I hadn't found the code
in the functions.inc, because it's abbreviated to "hex" there and it didn't show
up in the search result. I should definitely read more in the doc, but the
problem is, before I'm even partly through I've already forgotten completely
about what I had read in the beginning. I'm not good at memorizing things. I
remember I had read  through the functions.inc half a year or so ago, but I
didn't even remember there was this hex-function in there.
> them out:
y.org%3E
Yes they look groovy :)
The little yellow star thing inspired me to try to make a whole field of sphere
sweep hexagons in a row with a while loop. But I still haven't figured out the
correct distance between them.
I thought I could use tiles only with textures/pigments and so on. I don't know
how to put them on heightfields? Because in the documentation I didn't found any
"repeat" statement in the description for heightfields, so I thought tiles are
not possible. But maybe I missed some essential point, it wouldn't be the first
time :).
Best wishes
Simone
Date: 10 Jan 2010 16:38:42
Message: <4b4a48e2@news.povray.org>
Sure, you can squeeze the color_map values together, but the jaggies
will look much worse.
> walls.
Whatever works :)
Do you know about sin/cos functions? With them, you can make polygonal
shapes with any number of sides. For instance, to make a 6-sided prism
you can use sin/cos like so:
prism{
  -1,1,7,
  <sin(pi*2/6*0),cos(pi*2/6*0)>,
  <sin(pi*2/6*1),cos(pi*2/6*1)>,
  <sin(pi*2/6*2),cos(pi*2/6*2)>,
  <sin(pi*2/6*3),cos(pi*2/6*3)>,
  <sin(pi*2/6*4),cos(pi*2/6*4)>,
  <sin(pi*2/6*5),cos(pi*2/6*5)>,
  <sin(pi*2/6*0),cos(pi*2/6*0)> // closing the hexagon
  pigment{rgb 1}
Essentially, sin/cos functions map a circle. By studying this code, you
can figure out how to make polygons with any number of sides. You can
apply it towards other objects, like cylinders and spheres to make
skeletal frameworks.
Learning POV-Ray is daunting, to be sure. It is helpful to create mini
projects for yourself, to learn how different features work. Also, it
might be helpful to have a testing scene file with camera, lights,
background, etc. to test things out in. I always keep such a file
around, as well as a texture-making scene for trying out new
pattern-related things.
>> them out:
> y.org%3E
I included two functions and two variables in the include file for
working in trigonal space, you might want to check them out. With them,
you can find the correct distances :) They are called: h1, h2, ht(x,y),
ht2(x,y).
> time :).
I think he might have been talking about making a basic height_field
tile, like this (Thunderbird might put a line directly through the hexagon):
     ____
__/      \__
    \____/
It's a height_field with only one hexagon, an object you can place in a
nested #while loop to make a larger honeycomb. You can use the
previously mentioned variables and functions from my hex patterns
include file to scale the hexagon correctly.
Sam
Date: 10 Jan 2010 17:36:39
Message: <4b4a5677@news.povray.org>
Le 2010-01-10 16:38, stbenge a écrit :
>> heightfield
>> map in
>> don't get
>> result in a
>> looking
>> heightfield
>> walls.
>> grayscale png)
> Whatever works :)
> prism{
> -1,1,7,
> pigment{rgb 1}
>> the code
>> didn't show
>> the
>> completely
>> things. I
>> but I
>>> them out:
>> y.org%3E
>> of sphere
>> out the
> ht2(x,y).
>> don't know
>> found any
>> tiles are
>> the first
>> time :).
> hexagon):
> ____
> __/ \__
> \____/
> Sam
That's exactly what I had in mind.
Date: 10 Jan 2010 18:45:00
Message: <web.4b4a6617dee126c3fa00a0a00@news.povray.org>
I recall dimly there was sth. like that at school that I never quite understood.
> prism{
>   -1,1,7,
>   pigment{rgb 1}
I see. I just checked that with cylinders, it becomes a hexagon when one puts
the sin/cos lines in the end and start points coordinates. There are some ugly
gaps in between but basically it works. Might be useful for some other things
I'll put it in my "tipps & tricks" folder :).
> ht2(x,y).
I had a look at them but I don't understand them.
The distances between points I tried to find out yesterday with graph paper,
which didn't work, then I looked them up at wikipedia which did work.
But what I meant with distances in the rows and columns of the hexagonal
sphere_sweeps was not the distances between the points of one hexagon but
between the single hexagons. Though I could calculate the distance, I wanted
them to overlap, so two of them always share one border because that looks
better. The width of the borders I could not calculate because it is determined
by the width of the gradient in the heightfield texture. Maybe some mastermind
can calculate them too, but it will be no problem to just trial&error a bit.
>      ____
> __/      \__
>     \____/
Oh, I see. I have understood that now :)
I'll try to do my best and output some final images now, which should be no
problem with all the useful advice and before anybody will get hexagonized :))
Thanks & Best wishes
Simone
