POV-Ray : Newsgroups : povray.general : sunpos.inc Server Time
5 Mar 2026 14:49:26 EST (-0500)
  sunpos.inc (Message 1 to 9 of 9)
Subject: sunpos.inc
Date: 5 Sep 2009 18:17:42
Message: <4aa2e386@news.povray.org>
The docs don't tell you how *far away* the sun is from the center of the
scene when you include this file. What is the distance?
-Mike
Subject: Re: sunpos.inc
Date: 5 Sep 2009 18:28:19
Message: <4aa2e603$1@news.povray.org>
I have some other lighting questions as well.
1. Does CIE_Skylight.inc in LightsysIV use media to create the sky
color, or does it simply create a sky_sphere pigment?
2. Does it create a sun as well as a sky? Is the sun an object, or is it
just a brighter spot in the sky?
2.Right now I am using the looks_like statement, to create a sun object
and light source. Unfortunately, the distances are so great that the sun
object is culled from the scene. Is there a way to place the object
nearer to the camera while still having the light source very far away?
I'm guessing that this would normally create problems such as shadows.
How do I get around them?
-Mike
Date: 6 Sep 2009 03:51:59
Message: <4aa36a1f@news.povray.org>
   It is a mesh dome, where triangles are colored according to complex
calculations. Read the readme_skylight.txt file: it's all explained there by
the author, Philippe Debar.
   No object, is just a spot in the dome mesh. AFAIK, this spot doesn't
models the sun, but the brightness of the sky at that point. I usually put a
light_source at the SolarPosition returned by the include.
   Just take out the object from the looks_like and place it where you want,
adding no_shadow to it.
Jaime
Date: 6 Sep 2009 03:52:18
Message: <4aa36a32$1@news.povray.org>
A quick look at sunpos.inc reveals that the point returned by the SunPos
macro will be placed 1000000000 (1e+9) units  away.
You can pick your own favorite distance by using
     #declare MySunPos = vnormalize(SunPos(...))*MySunDistance;
Date: 6 Sep 2009 03:56:31
Message: <4aa36b2f$1@news.povray.org>
You can...
a) place a sphere a good deal closer, give it ambient-only finish, and
mark it as "no_shadow" to prevent it from casting shadows, or
b) use a sky_sphere with some smart pigment generating a bright spot
where the sun should be.
Date: 6 Sep 2009 13:09:11
Message: <4aa3ecb7$1@news.povray.org>
> -Mike
If the light_source with it's looks_like objects is to far away, you can
place it closer while making it proportionaly smaller.
So, if you place it 1000 times closer, make it 1000 times smaller. This
will preserve it's perceived dimention.
Also, use the "parallel" attribute for the light_source, with "point_at
0" to orient it toward the center of your scene. This simulate a
light_source cituated at "infinity".
It's always a good idea to create your scene around the origin.
Date: 6 Sep 2009 13:35:36
Message: <4aa3f2e8$1@news.povray.org>
Does the scene's basic unit of measurement matter when using sunpos?
Also, is the sun's radius/diameter isn't calculated by the script?
-Mike
Date: 6 Sep 2009 13:36:28
Message: <4aa3f31c$1@news.povray.org>
> Alain
OK, thanks.
-Mike
Date: 6 Sep 2009 18:34:43
Message: <4aa43903$1@news.povray.org>
No, the SunPos macro doesn't care about the size of the rest of your scene.
No, SunPos only computes the sun's position.
For realism, the diameter should be approximately 1/100 of the distance.
