By default, TerraPOV uses an assumed_gamma value of 1. However, this
messes up the rest of my scene. What adjustments do I need to make to
the media to make it look right with the default gamma value for 3.61?
-Mike
You'll have to adjust *your* scene to work in linear color space (i.e.
gamma 1.0) as gamma correction does not only change brightness, it
changes also the hue and TerraPOV (or e.g. lightsys) will only work in
linear color space (also default for POV-Ray 3.7) as expected.
-Ive
> -Ive
Any tips on how to go about doing this? The renders always end up
looking too bright and washed out.
-Mike
Does TerraPOV use images for texturing? If so, try converting them to
PNG. (Make sure the converter writes a gAMA chunk; from my experience, I
can recommend IC for this job.)
Actually, the only part of TerraPOV I used is the atmospheric media
described in the tutorials newsgroup. Everything else was created
separately.
-Mike
