POV-Ray : Newsgroups : povray.general : Precision of large objects Server Time
11 Oct 2026 11:05:54 EDT (-0400)
  Precision of large objects (Message 1 to 14 of 14)
Subject: Precision of large objects
Date: 26 Aug 2009 06:34:15
Message: <4a950fa7$1@news.povray.org>
Assuming my units of measurement 1 Povray unit, how big can I make
things before precision errors become a problem? I.e. what is the
"range" of scales that will still work?
-Mike
Subject: Re: Precision of large objects
Date: 26 Aug 2009 07:22:42
Message: <4a951b02$1@news.povray.org>
That depends on what you actually want to do.
Any values in the order of 1.0e+17 or above are destined to get you into
utter trouble.
Distances between camera and objects, between different objects, or
between parts of an object, in the order of 1.0e+7 or above will mess up
various ray-object intersection tests.
Object sizes in the order of 1.0e+6 or above will disengage the bounding
mechanism for that object.
It is also recommended to place the scene near the coordinate origin, as
that's where computations can be done with highest precision; if the
smallest details you expect to see are X units in size, they should be
no further away from the coordinate origin than X * 1.0e+7 units,
otherwise bounding box and other mechanisms will freak out.
Date: 26 Aug 2009 07:23:29
Message: <4a951b31$1@news.povray.org>
> Assuming my units of measurement 1 Povray unit, how big can I make things
> before precision errors become a problem? I.e. what is the "range" of
Try a simple 1-line scene like this:
sphere{ <0,0,1> .4 scale X pigment{color rgb 10}}
And increase X until the sphere disappears, on my system X=2e7 doesn't
render.
Date: 26 Aug 2009 07:59:59
Message: <4a9523bf$1@news.povray.org>
> render.
Awesome, thanks!
-Mike
Date: 26 Aug 2009 11:57:03
Message: <4a955b4f@news.povray.org>
> render.
  AFAIK that's not because of precision, but because of an explicit limit
in the source code for such things.
Date: 26 Aug 2009 16:45:59
Message: <4a959f07$1@news.povray.org>
>> render.
That is so indeed.
Date: 31 Aug 2009 04:27:55
Message: <4a9b898b$1@news.povray.org>
>> render.
Is the purpose of the explicit limit to hide precision errors becoming
visible?
Why is the limit so low, 2e7 is absolutely tiny compared to the 64-bit
floating point range of 1e300 or whatever it is (which presumably POV uses).
Date: 31 Aug 2009 06:25:19
Message: <4a9ba50f$1@news.povray.org>
> uses).
Personally, I have the impression that the rationale behind most of
these limits has been lost in obscurity by now.
Date: 31 Aug 2009 13:54:59
Message: <4a9c0e73$1@news.povray.org>
>>> render.
> visible?
> uses).
If you have a value of about 1e100, then, the last digit presision would
be about 1e90 to 1e93. This is a serious loss of precision.
Date: 31 Aug 2009 14:28:55
Message: <4a9c1667@news.povray.org>
  Note that a double-precision floating point number (which is 64 bits
in size) has only 53 bits of precision for the base. That's approximately
15 digits of precision in base 10. (In other words, if you try to store
a number with more significant decimal digits than 15 into such a floating
point value, the lower ones will just be lost.)
  I assume 1e7 was chose as half of that.
Date: 1 Sep 2009 11:22:04
Message: <4a9d3c1c@news.povray.org>
Probably. It looks like a reasonable cut point when you concider that,
during the calculations, you need to get square roots as well as squares
and cubes.
Just a multiplication of two floats can double the number of digits.
Date: 1 Sep 2009 13:36:44
Message: <4a9d5bac$1@news.povray.org>
> and cubes.
Although this is the case, multiplications do not affect the precision
of floating-point computations too much. The same goes for square roots.
Note that even though a double-precision floating-point number can hold
numbers with only 15 /significant/ digits, it can still hold values much
larger than 1e+15 (albeit at lower precision).
The most troublesome operations in the realm of floating-point numbers
are actually subtractions (or additions of values with different sign,
for that matter): For instance, 1.000 - 0.999 will give 0.001 at a
precision of only 12 significant digits.
Date: 1 Sep 2009 13:53:52
Message: <4a9d5faf@news.povray.org>
  Of course it doesn't affect the precision of floating point computations.
Double-precision floating point numbers will always have 53 bits of
precision. that doesn't change.
  However, when multiplying two 15-digit numbers, the result will have
30 significant digits of information, and from those the 15 least significant
will be lost. Thus the result will not be exact.
  As a concrete example:
0.123456789012345 * 0.123456789012345 =
0.01524157875323866912056239902
  When stored into a 'double', the result will be rounded to something like
0.0152415787532387
Date: 1 Sep 2009 14:19:42
Message: <4a9d65be$1@news.povray.org>
Well, it will be just about as exact as the input numbers:
That's actually more like:
     ( 0.123456789012345e0 +/- 1.0e-15 )
   * ( 0.123456789012345e0 +/- 1.0e-15 )
=     0.01524157875323866912056239902e0
   +/- 0.123456789012345e-15
   +   1.0e-30
=     0.1524157875323866912056239902e-1
   +/- 2.46913578024690e-16
   +   1.0e-30
which again fits neatly within the original relative precision. No harm
done by storing it into a double-precision floating point again (the
number format even provides a slightly higher precision than the
multiplication result could ever have, given that the operands were
double-precision floats as well).
