POV-Ray : Newsgroups : povray.general : Precision of large objects Server Time
5 Mar 2026 14:59:59 EST (-0500)
  Precision of large objects (Message 1 to 10 of 14)
Subject: Precision of large objects
Date: 26 Aug 2009 06:34:15
Message: <4a950fa7$1@news.povray.org>
Assuming my units of measurement 1 Povray unit, how big can I make
things before precision errors become a problem? I.e. what is the
"range" of scales that will still work?
-Mike
Subject: Re: Precision of large objects
Date: 26 Aug 2009 07:22:42
Message: <4a951b02$1@news.povray.org>
That depends on what you actually want to do.
Any values in the order of 1.0e+17 or above are destined to get you into
utter trouble.
Distances between camera and objects, between different objects, or
between parts of an object, in the order of 1.0e+7 or above will mess up
various ray-object intersection tests.
Object sizes in the order of 1.0e+6 or above will disengage the bounding
mechanism for that object.
It is also recommended to place the scene near the coordinate origin, as
that's where computations can be done with highest precision; if the
smallest details you expect to see are X units in size, they should be
no further away from the coordinate origin than X * 1.0e+7 units,
otherwise bounding box and other mechanisms will freak out.
Date: 26 Aug 2009 07:23:29
Message: <4a951b31$1@news.povray.org>
> Assuming my units of measurement 1 Povray unit, how big can I make things
> before precision errors become a problem? I.e. what is the "range" of
Try a simple 1-line scene like this:
sphere{ <0,0,1> .4 scale X pigment{color rgb 10}}
And increase X until the sphere disappears, on my system X=2e7 doesn't
render.
Date: 26 Aug 2009 07:59:59
Message: <4a9523bf$1@news.povray.org>
> render.
Awesome, thanks!
-Mike
Date: 26 Aug 2009 11:57:03
Message: <4a955b4f@news.povray.org>
> render.
  AFAIK that's not because of precision, but because of an explicit limit
in the source code for such things.
Date: 26 Aug 2009 16:45:59
Message: <4a959f07$1@news.povray.org>
>> render.
That is so indeed.
Date: 31 Aug 2009 04:27:55
Message: <4a9b898b$1@news.povray.org>
>> render.
Is the purpose of the explicit limit to hide precision errors becoming
visible?
Why is the limit so low, 2e7 is absolutely tiny compared to the 64-bit
floating point range of 1e300 or whatever it is (which presumably POV uses).
Date: 31 Aug 2009 06:25:19
Message: <4a9ba50f$1@news.povray.org>
> uses).
Personally, I have the impression that the rationale behind most of
these limits has been lost in obscurity by now.
Date: 31 Aug 2009 13:54:59
Message: <4a9c0e73$1@news.povray.org>
>>> render.
> visible?
> uses).
If you have a value of about 1e100, then, the last digit presision would
be about 1e90 to 1e93. This is a serious loss of precision.
Date: 31 Aug 2009 14:28:55
Message: <4a9c1667@news.povray.org>
  Note that a double-precision floating point number (which is 64 bits
in size) has only 53 bits of precision for the base. That's approximately
15 digits of precision in base 10. (In other words, if you try to store
a number with more significant decimal digits than 15 into such a floating
point value, the lower ones will just be lost.)
  I assume 1e7 was chose as half of that.
