I may have asked this before, but what are some good ways to create 2D
textures that tile? A tiling desktop background is a common (maybe not
so much these days...) example.
Secondly (and this is the more advanced part), how might I turn tiling
on and off for a particular direction? What I really want to do is
create square terrain tiles (for a game) that have 16 possible "states"
based on whether or not a tile has a neighbor.
For example, a tile with four neighbors would join nicely on all four
sides. A tile with only three neighbors would be "closed" on one side.
Here's are the 16 possible "states":
o o x x
o o o x o o o o o x o o
o o o o
o o x x
o o x x o x o o x x o x
o o o x
o o x x
x x x x
o o x x
x x x x
The "o" in the middle of each diagram is the tile in the center. The
rest are its neighbors.
-Mike
> textures that tile?
In 2D space you can use diamond tiling:
#declare repeatable_pattern=
pigment{
cylindrical rotate x*90 scale 1.00
pigment_map{
[0 rgb 0]
[1 crackle scale .5]
plane{z,0
pigment{
average
pigment_map{
[1 repeatable_pattern translate -x]
[1 repeatable_pattern translate x]
[1 repeatable_pattern translate -y]
[1 repeatable_pattern translate y]
translate(x+y)
warp{repeat x*2}
warp{repeat y*2}
or square tiling:
pigment{
cylindrical rotate x*90 scale 1.50
pigment_map{
[0 rgb 0]
plane{z,0
pigment{
average
pigment_map{
[1 repeatable_pattern translate<-1,-1,0>]
[1 repeatable_pattern translate<1,-1,0>]
[1 repeatable_pattern translate<-1,1,0>]
[1 repeatable_pattern translate<1,1,0>]
translate(x+y)
warp{repeat x*2}
warp{repeat y*2}
where "repeatable_pattern" is a pigment you wish to use in excess.
I think perhaps you'll be keeping track of where the break in repetition
occurs, so for a tile which repeats using diamond tiling, with a break
in repetition to the right:
pigment{
average
pigment_map{
[1 non_repeatable_pattern translate x]
translate(x+y)
warp{repeat x*2}
warp{repeat y*2}
might suffice.
I hope this helps somewhat.
Sam
> pigment{
> pigment_map{
> [0 rgb 0]
[1 crackle color_map{[0 rgb 0][1 rgb 4]}]
Oh yeah, this^ will fix any dimness experienced while averaging four
copies of the pigment. Can't stretch it too thin without proper
compensation ;)
> textures that tile?
#declare PatternFunc =
function { pattern { wood turbulence .5 scale .5 } };
#declare PatternFuncTiledX =
function
{ pattern
{ function
{ (1-x)*PatternFunc(x, y, z) +
x*PatternFunc(x-1, y, z)
warp { repeat x }
#declare PatternFuncTiledY =
function
{ pattern
{ function
{ (1-y)*PatternFunc(x, y, z) +
y*PatternFunc(x, y-1, z)
warp { repeat y }
#declare PatternFuncTiledXY =
function
{ pattern
{ function
{ (1-y)*PatternFuncTiledX(x, y, z) +
y*PatternFuncTiledX(x, y-1, z)
warp { repeat y }
camera { location -z*3 look_at 0 }
plane
{ -z, 0
pigment
{ function { PatternFuncTiledXY(x, y, z) }
color_map { [0 rgb 0] [1 rgb 1] }
finish { ambient 1 }
