POV-Ray : Newsgroups : povray.general : Problem shaping a CSG object Server Time
31 Oct 2026 04:03:22 EDT (-0400)
  Problem shaping a CSG object (Message 1 to 21 of 21)
Subject: Problem shaping a CSG object
Date: 29 Jul 2009 05:27:58
Message: <4a70161e@news.povray.org>
Hi all,
I need a CSG object that basically has the shape of a cone, but with the
apex as a straight edge parallel to the base, with a length equal to the
diameter of the base. I tried all kinds of combinations but am unable to get
this right.
Any help will be much appreciated. Thanks a lot.
All the best,
"Sic vive, tanquam cras moriturus, sic stude, quasi semper victurus."
Desiderius Erasmus
Subject: Re: Problem shaping a CSG object
Date: 29 Jul 2009 06:40:00
Message: <web.4a7026819ce95c17d98590c80@news.povray.org>
I doubt this can be done with a (finite) CSG.
Just for clarity, what you need is something like this?
isosurface {
  function { x*x + z*z*(1-y)*(1-y)/4 - (1-y)*(1-y)/4 }
  contained_by { box { -1, 1 } }
> Hi all,
> this right.
> All the best,
> Thomas
> Desiderius Erasmus
Date: 29 Jul 2009 06:50:32
Message: <4a702978@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4a70161e@news.povray.org...
> Hi all,
> get this right.
> All the best,
> Thomas
> Desiderius Erasmus
An Isosurface is the easiest and quickest and is technically CSGable.
Otherwise you can get the same shape by taking slices of a squashed sphere.
Both are illustrated below. Turning up the interval for the slicing gives
smoother results, but less interesting render times.
Chris B.
camera {location <-2, 2.5, -1.5> look_at <1,0.25,0>}
light_source {<2,20,-15> color rgb 1}
isosurface {
  function { (x*x*(y*y)+z*z-y*y)}
    accuracy 0.001
    max_gradient 4
    contained_by{box{<-1,-1,-1>,<1,0,1>}}
    pigment {rgb <1,1,0>}
    finish {phong 0.5 phong_size 10}
    translate y
    translate x*3
#local Interval = 0.05;
merge {
  #local I = 0;
  #while (I<1)
     intersection {
       sphere {0,1}
       box {<-1,0,-1><1,Interval,1>}
       scale z*(1-I)
       translate I*y
     #local I = I+Interval;
  pigment {rgb 1}
Date: 29 Jul 2009 07:22:30
Message: <4a7030f6@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4a702978@news.povray.org...
>> Hi all,
>> get this right.
> sphere.
> Regards,
> Chris B.
While making a cup of tea it just occurred to me that you can also do it
with two sheared cones and a filler:
#include "transforms.inc"
merge {
  cone {0,1,y,0 Shear_Trans(x,<-1,1,0>,z)}
  cone {0,1,y,0 Shear_Trans(x,< 1,1,0>,z)}
  intersection {
    plane {< 0, 1, 1>,0 translate y}
    plane {< 0, 1,-1>,0 translate y}
    plane {<-1,-1, 0>,0}
    plane {< 1,-1, 0>,0}
  pigment {rgb 1}
Just goes to show that a good cup of tea can solve many problems  :-)
Chris B.
Date: 29 Jul 2009 07:31:29
Message: <4a703311@news.povray.org>
news:4a7030f6@news.povray.org...
> it just occurred to me that you can also do it with two sheared cones and
> a filler:
This is a slightly different shape of course, but it still seems to fit the
description you gave.
Chris B.
Date: 29 Jul 2009 07:33:16
Message: <4a70337c$1@news.povray.org>
Roman, Chris, Thank you for the tips! I had not thought about the use of an
isosurface.
Chris, your cup of tea did it! That is exactly what I was looking for. I had
been struggling with cones but did not think of shearing them indeed.
You're the Boss! Thanks a lot.
P.S. Drink more tea...
Date: 29 Jul 2009 10:10:00
Message: <web.4a7057989ce95c17edb9d8df0@news.povray.org>
> this right.
You might take two half-cones with point apexes, spread their apexes apart by
means of shearing matrix transformations, and fill the gap with a tetrahedrical
wedge.
Date: 29 Jul 2009 11:02:44
Message: <4a706494$1@news.povray.org>
Could one start with a cylinder instead? Since the top is as wide as the
bottom in at least one direction?
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
Date: 29 Jul 2009 11:55:00
Message: <web.4a70706f9ce95c17edb9d8df0@news.povray.org>
Hm, yes, I guess a cylinder intersected with a wedge would fit Thomas' bill, too
(at least nominally, though it may not be what he looked for, due to the hard
edges this would produce)
Date: 29 Jul 2009 12:29:04
Message: <4a7078d0$1@news.povray.org>
I was thinking more scale it from x=1.0 y=1.0 to x=1.0 y=0.0 as you move
from z=0 to z=1, if that makes sense. Not an intersection, but a non-linear
scaling.
Date: 29 Jul 2009 12:32:04
Message: <4a707984@news.povray.org>
Le 29/07/2009 11:27, Thomas de Groot nous fit lire :
> Hi all,
> this right.
Can you check "apex as a straight edge *parallel* to the base."
apex is a point.
On standard "right circular" cone, the apex is projected on the center of the base
circle.
Your description seems to describe an oblique circular cone, whose apex is projected
on a
point of the base circle. Distance between projection plane and apex being diameter of
the
 circle.
You need a quadratic equation. Either as isosurface or quadric.
Isosurface has been provided, but a quadric might provide a different rendering time,
bounded by a unit box.
A x2 + B y2 + C z2 + D xy + E xz + F yz + G x + H y + I z + J = 0
A centered circle on <0,0,0>, radius 1: A=B=1, J=-1; D=0; G=0; H=0;
symetry implies E=0;
Remains C,F,I
with apex on <0,1,2>:
0+1+4C +2F+2I-1=0
4C+2F+2I=0
Also <0,1,1> on surface.
0+1+C+F+I-1=0
C+F+I=0
therefore C=0;
and F=-I
<0,0,1> also on surface
I-1=0 so I=1
intersection {
box{ <-1,-1,0>,<1,1,2> }
quadric { <1,1,0>,<0,0,-1>,<0,0,1>,-1}
have a nice day.
Date: 29 Jul 2009 12:40:00
Message: <web.4a707ac99ce95c17edb9d8df0@news.povray.org>
> scaling.
Here's the catch: You can't do non-linear scaling in POV-Ray (unless you use
parametrics, isosurfaces or some such).
Date: 29 Jul 2009 12:56:40
Message: <4a707f48$1@news.povray.org>
Further thinking about your description, if apex really a segment parallel to base:
check volume 3 of news://news.povray.org:119/496f790c@news.povray.org
(title: "6 volumes" OP: Le_Forgeron, Date 15 january 2009)
It's a conocuneus, a quartic.
Toothpath tube classical end.
intersection {
box {<0,-1,-1><2,1,1>}
quartic {
  <0,0,0,0,0, 0,0,1,0,-1,
   0,0,0,0,0, 0,0,0,0,0,
   0,0,0,0,0, 4,0,0,0,0,
   0,0,0,0,0> }
Date: 29 Jul 2009 13:00:43
Message: <4a70803b@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4a7078d0$1@news.povray.org...
>> bill, too
>> hard
> non-linear scaling.
That's what two of the three examples I posted this morning do, one using an
Isosurface, the other using slices of a sphere, (but a cylinder would work
the same). The third example I posted used the method Clipka outlined, which
generates a slightly different shaped surface.
I think there is at least one more way without using shear, which is to
scale a cone non uniformly, rotate and slice it, such that the horizontal
section becomes circular while the edge is vertical, then fill out the
middle as before.
Chris B.
Date: 29 Jul 2009 13:31:52
Message: <4a708788@news.povray.org>
news:4a70803b@news.povray.org...
> middle as before.
In fact I've tried it and I don't think my fourth way works because you
always end up with a parabolic conic section.
Nevertheless, Le Forgeron looks as though he's still churning out more
alternatives :-)
Geometry questions seem popular. Any more ;)
Chris B.
Date: 30 Jul 2009 05:38:22
Message: <4a716a0e@news.povray.org>
Toothpaste tube end indeed covers the bill  :-)
"Le_Forgeron" <jgr### [at] freefr> schreef in bericht
news:4a707f48$1@news.povray.org...
> to base:
> intersection {
> quartic {
>   0,0,0,0,0> }
Date: 30 Jul 2009 05:43:45
Message: <4a716b51$1@news.povray.org>
> intersection {
> quartic {
>   0,0,0,0,0> }
This is now the most elegant solution. Thanks a lot!
Date: 8 Aug 2009 04:17:33
Message: <4a7d349d$1@news.povray.org>
> to base:
Maybe me, but this reference is not pointing to anything on news.povray.org
Date: 10 Aug 2009 03:28:54
Message: <4a7fcc36$1@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> schreef in bericht
news:4a7d349d$1@news.povray.org...
Seriously, I cannot find any message related to this on the server in any
n.g. (I used Search). Neither title nor date refer to a message. Any help?
Date: 10 Aug 2009 04:50:58
Message: <4a7fdf72$1@news.povray.org>
news:4a7fcc36$1@news.povray.org...
> Thomas
Hi Thomas.
See:
Newsgroups: povray.binaries.images
Sent: Thursday, January 15, 2009 6:57 PM
Subject: 6 volumes
The URL above incorporated the port number (119) in a way that screwed up
the link on my newsreader (and I imagine on yours too). It's the default
port anyway, so when I removed that it popped up ok in the Windows Mail
client on Vista. ie news://news.povray.org/496f790c@news.povray.org
It's also available through the browser interface at:
http://news.povray.org/povray.binaries.images/thread/%3C496f790c%40news.povray.org%3E/?ttop=318396&toff=250
It seems that Le Forgeron foresaw your very question at the start of the
year. Next Psychic challenger please :-)
Date: 10 Aug 2009 11:40:25
Message: <4a803f69$1@news.povray.org>
"Chris B" <nom### [at] nomailcom> schreef in bericht
news:4a7fdf72$1@news.povray.org...
> Hi Thomas.
> See:
> From: "Le_Forgeron" <jgr### [at] freefr>
> Subject: 6 volumes
Thanks Chris. I also found it at last through the browser interface. My
primary problem was in fact that all older messages on my news reader were
gone so that my search didn't give any results. I just then realised I had
to load them back up again to access them. Summer heat makes the brain
sluggish :-)
