POV-Ray : Newsgroups : povray.general : Test version of POVWIN version 3.62 available Server Time
11 Oct 2026 12:17:53 EDT (-0400)
  Test version of POVWIN version 3.62 available (Message 1 to 20 of 20)
Subject: Test version of POVWIN version 3.62 available
Date: 23 May 2009 09:18:26
Message: <4a17f7a2@news.povray.org>
Folks,
I've generated a v3.62 RC1 POVWIN and new installer. I'd appreciate it if
some of you could test it as the installer in particular is a re-write.
  http://www.povray.org/temp/POVWin-v3.62-RC1.msi
Note: on Vista systems, the files will be installed by default to your
local profile. On XP and earlier, the default remains Program Files.
-- Chris
Subject: Re: Test version of POVWIN version 3.62 available
Date: 23 May 2009 14:50:00
Message: <web.4a1844aa3e2c17459677c2120@news.povray.org>
Installed and ran without issue, WinXP sp3 media center edition.
Looking through the changes I see the new +ac/Antialias_Clipped option,
interesting :-)
Stephen S
Date: 24 May 2009 00:40:56
Message: <4a18cfd8$1@news.povray.org>
Um, I will say great thing first and thank you Chris.
You did say in Vista it will go into the user profile... I'm in Windows 7 RC
(build 7100) and I thought it might be the same way you have it for the
POV-Ray beta, going into the documents folder with a POV-Ray parent folder
in there.
This install turned out like earlier P-R betas and went into AppData\roaming
so the scene files are hidden away. Hopefully not something to do with
already having the old 3.6.1c in Program Files.
BTW the old POV-Ray icon sure would look better if done like the beta,
smooth alpha AA. I use the appearance difference to my advantage, of course,
but I guess we will need to keep them both different and nice-looking...?
P.S.
I had looked at the install log when asked and noticed at the end it
mentions a reboot = yes. Nothing asked or happened at the end so I restarted
Windows 7 but before I did I found the Explorer (user folders and files)
wasn't allowing me to change settings to show hidden files. Also a padlock
over the user name icon. Could be my ineptitude about this particular thing
but thought I better mention it.
Date: 24 May 2009 08:25:12
Message: <4a193ca8$1@news.povray.org>
> in there.
Nope, it was too much work to split the program locations in v3.6, it's an
old code base. This is really just a maintenance release to get it working
on Vista.
Nope, nothing to do with that. It does create a shortcut to the scene files
on the desktop, though.
Which icon didn't come out well? The program itself, the shortcuts, or the
menu items?
Not sure why that's there, must be some installshield thing that sets up a
reboot if required. However certainly for POVWIN it's not needed.
Thanks for mentioning it. While I can't explain what that would be caused
by, I'd be surprised if it was the installation.
-- Chris
Date: 24 May 2009 18:43:56
Message: <4a19cdac$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:4a193ca8$1@news.povray.org...
>> RC
>> POV-Ray beta
Ok, just wasn't sure what was meant before.
> It does create a shortcut to the scene files on the desktop
Yep, got that... :) wondering if naming it 3.6 instead of 3.62 might confuse
people.
>> course,
> menu items?
Program. A "jaggy" perimeter causing an ugly gray and black edge. Well, ugly
compared to the new 3.7 one and compared to most other programs.
Main point being different icons will be needed or else there's no visual
cue to know which is which, not that it matters if a previous 3.6 version is
present.
Maybe you don't need to see them but I'll post at p.b.i  those two icons
from my Vista's recent programs list.
Oh, and install into Vista went perfectly fine just haven't checked actual
changes yet. No news will be good news on that.
Date: 25 May 2009 08:21:06
Message: <4a1a8d32@news.povray.org>
This should be fixed now. Please try again, filename is now:
  http://www.povray.org/temp/POVWin-v3.62.msi
Unless problems crop up I intend this to be the actual release (hence no RC
suffix).
-- Chris
Date: 25 May 2009 12:21:12
Message: <4a1ac578@news.povray.org>
message news:4a1a8d32@news.povray.org...
>> ugly
> RC
> suffix).
Looks good! The install asked me to uninstall the previous one so that
answers a question I was wondering as to whether or not a backup was
possible same as earlier 3.6 installs. Guessing the idea is clean installs
only...?
Got to say it... program and scene file location is bothersome to me.
Going into the desktop shortcut and running a file from there or dragging it
into POV does okay, yes, but when trying to open a file from within POV it
wants to go elsewhere and the hidden scenes location is lost. I presume this
is in part due to the install finding the file open location where 3.6.1c
was last at.
This is worsened by Vista not allowing folder and file view settings to be
changed (same as what happened in Windows 7) so getting to the new location
is impossible at first. I thought maybe having a file opened from the
desktop shortcut would update the File|Open but it didn't.
I'm sure this particular aspect would be good to hear observations from
other people not just me.
I've only tried several renders, all seems right so far.
Date: 25 May 2009 12:39:42
Message: <4a1ac9ce$1@news.povray.org>
> be changed
Press the ALT key, and you get all the XP menus back. There's also a hack to
turn it on permanently.
   There's no CD like OCD, there's no CD I knoooow!
Date: 25 May 2009 15:09:55
Message: <4a1aed03$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4a1ac9ce$1@news.povray.org...
>> be changed
> to turn it on permanently.
Not here, although I think I know what you meant Darren.
What I'm seeing happen in the File|Open dialog is just the Organize
drop-down with the "folder and search options" inaccessible. ALT doesn't
change anything here.
To get back into AppData\Roaming\POV-Ray\v3.6\Scenes I must first change the
"view hidden files" setting outside of POV to see it in the open file
dialog.
Both Vista and 7 are like this for me. Interestingly, I did have the hidden
path in the folder path drop-down list while in Vista, yet not in 7. Just
wasn't thinking of looking there before.
So I'm still believing this could be trouble because navigating away from
these hidden files (while files are set to be hidden, the default) then
later try to return it becomes likely you won't be able to use the open file
menu to get there until changing to view hidden files again (outside POV, as
said already).
Hope I'm making sense.
Date: 25 May 2009 15:28:09
Message: <4a1af149$1@news.povray.org>
>> ugly
> RC
> suffix).
> -- Chris
Hi Chris,
The install went smoothly on Vista 64 but it intalled the 32 bit version
rather than the 64 bit version. I presum the 64 bit compile will be made
available in a different dowload package once you have time to put it
together?
Ken Tyler
Date: 25 May 2009 15:42:40
Message: <4a1af4b0$1@news.povray.org>
> the "view hidden files" setting outside of POV to see it in the open
> file dialog.
Oh, that's what I was talking about. The option to get to "view hidden
files" is hitting ALT in Explorer. They hid the "normal" menu bar.
I agree that putting the user's data files under AppData seems like the
wrong place. If you can use it with other programs (e.g., text editors), it
should probably go under "My Documents" somewhere.
Yes.
Date: 26 May 2009 02:53:19
Message: <4a1b91df@news.povray.org>
> together?
Hi Ken,
Yes, the version of InstallShield I've got doesn't allow me to make dual 32
and 64-bit installers. I'll make the 64-bit one available once the 32 is
settled.
regards,
-- Chris
Date: 26 May 2009 02:58:21
Message: <4a1b930d$1@news.povray.org>
> only...?
This isn't really under my control, it's a Windows Installer thing, so yes
- clean installs only. It's also why I use a different install path (even
on Windows XP); there's no way for me to tell Windows Installer to backup
the old files, especially files that weren't installed by it (as 3.61c did
not use WI).
I don't like it either. I feel uncomfortable having everything in the one
place (which is why I fixed it in 3.7). However the code refers to the
install path in many places and since the codebase is now so different
between v3.6 and v3.7 I'd basically have to do all the changes over again.
But thinking of it, I really think you're right. I might just have to go in
and do it.
> was last at.
This would be due to the shared registry settings.
-- Chris
Date: 26 May 2009 03:59:05
Message: <4a1ba149$1@news.povray.org>
message news:4a1b930d$1@news.povray.org...
> in
> and do it.
Which is why I didn't want to make you feel pressured to do that just for my
own sake. I'm sure you would rather consider this new 3.6 version finished.
The way it's an update to 3.6 I know most people will find all this to be a
problem, too, when they try to go from the old to new. I thought it might
not matter if no previous file were already left open in 3.6.1c when last
used. What I really didn't expect (but probably should have) was 3.6.2
finding one elsewhere even when no open files were left in editor, by going
into File|Open.
For me, not so much a problem if the file view settings had not locked me
out. That made me believe it was causing trouble for either Windows, or POV
itself had difficulty interfacing with the file system, or whatever other
reason unknown to me. I've only kept everything as administrator status, no
other user account exists.
Date: 26 May 2009 07:07:20
Message: <4a1bcd68$1@news.povray.org>
Chris Cason wrote:
> Folks,
I've updated this to RC2, which includes splitting the binaries and text
files dirs.
    http://www.povray.org/temp/POVWin-v3.62-RC2.msi
Scenes, INI files, etc, will be installed to "My Documents\POV-Ray\v3.6"
(or the equivalent).
-- Chris
Date: 26 May 2009 11:44:23
Message: <4a1c0e57@news.povray.org>
message news:4a1bcd68$1@news.povray.org...
> files dirs.
Wow, that was fast! A tremendous thank you from me to you. So much better
this way.
Guess I'm going to be removing 3.6.1c after I check this new one awhile,
MegaPOV, etc.
Hmmm. Some tidying up to do in that first install location, the uninstall
left renders in there because I didn't change from default file output.  : )
Date: 28 May 2009 10:17:51
Message: <4a1e9d0f$1@news.povray.org>
"BobH" <omniverse*charter!net> wrote in message
news:4a1c0e57@news.povray.org...
> MegaPOV, etc.
Trouble with library paths using megapov, needed to move its includes into
the v3.6\includes. Seems peculiar that it didn't want to use the
Library_Path= I added for its own location(s).
So to anyone else doing megapov+v3.6.2, put the files into the v3.6
locations (unless you have success any other way first). I just didn't want
to mix them but this was the only way.
Date: 28 May 2009 10:31:08
Message: <4a1ea02c@news.povray.org>
Another pass at a hopefully final 32-bit binary and installer:
The only significant difference between this and RC2 is that libpng has
been updated to the latest available.
-- Chris
Date: 31 May 2009 05:50:46
Message: <4a2252f6@news.povray.org>
> together?
Hi Ken,
Please give this a try:
  http://www.povray.org/temp/POVWin-v3.62-64bit.msi
-- Chris
Date: 31 May 2009 13:51:52
Message: <4a22c3b8$1@news.povray.org>
message news:4a2252f6@news.povray.org...
>> together?
> Hi Ken,
> -- Chris
Worked just peachy, Chris. The install was clean and the renderer appears to
be fully functional.
I'll beat up on it for a while but the few scenes I've rendered so far look
good.
Ken
Date: 8 Jul 2009 06:15:01
Message: <web.4a5470ce3e2c1745bbaa2810@news.povray.org>
> Folks,
> -- Chris
I uninstalled 3.6.1c a few days ago, and just now installed 3.6.2 (64 bit; Vista
Home Premium 64) about 30 minutes ago.
Before running the installer under Vista I set to -> "unblock". At some point
after running it a couple of times from the desktop shortcut (but I haven't
rendered anything yet), I have set the desktop shortcut to "Run as
Administrator"; no particular reason, I just did that with 3.6.1 back in 2007
when I got my new Vista computer, and I thought it might help with the "HELP"
problem mentioned in para (2) below (it didn't fix the problem).
DURING installation, I forced the install folder to "C:\POV-Ray\", due to some
old Vista oddities that became apparant when I installed 3.6.1 back in 2007.
(1)(a) Splitting off the INI files, scene files, etc into - > Documents is VERY
confusing. Why not just intall these into the POV-Ray installation folder? (In
my case under C:\POV-Ray\).
I have two (500 Gb) hard drives in a RAID 1 config, "Documents" is on D:\ (thats
just the way my computer builder set it up back in 2007). So now POVRay is on
C:, the INI files and so forth are shoved into D:\Documents. I ** think ** I
have figured out how to "transplant" all of the stuff from D:\Documents into
C:\POV-Ray (where they belong, in my opinion...), and alter things so that the
"transplants" are recognized - I don't want to fool with it until after I get
some replies to this... hopefully with a precise procedure to follow.
(1)(b) I thought I would try setting a "compatibility mode" for the desktop
shortcut (I did that with 3.6.1, it *might have* solved a couple of problems
under Vista back in 2007, but this is unverified) but the compatibility mode
settings for the shortcut are greyed out / un-set-able with 3.6.2 for some
reason.
(1)(c) When I FIRST ran the desktop shortcut, it (Vista) did not know where to
find the executable. I had to "Browse" to it manually the first time.
(2) While IN POV-Ray, clicking "Help" has no effect. Neither does any "Help with
This Menu". I have to manually navigate into C:\POV-Ray\help\, and click on the
povray36.chm file. I invoked REGEDIT.EXE and searched for povray36.chm, and
NONE of the ini files seem to point to the help files. How do I fix this?
I CAN work with 3.6.2 the way it is, but I would rather "fix it" (if possible).
If there is something different that I could do during installation, I am
prepared to UNinstall 3.6.2 and re-install it.
.... and one reason that I am reporting these oddities is to (hopefully) prevent
them from appearing whenever 3.7 is officially released (in my history w/
POVRay, I am reluctant to even try betas, I tend to wait for the official
releases).
- Thanks
Date: 8 Jul 2009 06:30:00
Message: <web.4a5474343e2c1745bbaa2810@news.povray.org>
> > Folks,
> > -- Chris
Never mind and sorry, to an extent... I think I now see why the INI files (etc)
were forced into \Documents (sorry, I should have done that forum research
BEFORE I made my post).
Okay, then... I can assume that it will be this way (probably) for 3.7, as a way
of coping with the Vista "Program Files and Ini Files" problem.
Can I ALTER POVRay so that all files (includes, ini's, etc) are copied (moved)
from D:\Documents into C:\POV-Ray, and this will be recognized and it will work
properly? (I THINK I see how to do this, but better wait for a reply or three
before I try it).
How do I fix the Help File problem? POV-Ray 3.6.2 under Vista (installed into
C:\POV-Ray) is not invoking the help file (povray36.chm). I have to do invoke
the help file manually/ separately. I CAN work with this, but it is
inconvenient. (and kind of foolish... clicking "HELP" does not "help". Its kind
of like... you hire contractors to build you a new house, but your porch light
switch turns on the dishwasher, and turning on the dishwasher does nothing...
or perhaps raises your neighbor's garage door).
Date: 8 Jul 2009 06:50:01
Message: <web.4a54793d3e2c1745bbaa2810@news.povray.org>
ALSO....
I just rendered one scene from Advanced to get started... Sounds are apparantly
NOT working. I just rendered "biscuit.pov" from \advanced, no sound when done.
I double checked Render -> Sound settings.
Date: 8 Jul 2009 06:55:00
Message: <web.4a547a673e2c1745bbaa2810@news.povray.org>
> Folks,
> -- Chris
> interesting :-)
> Stephen S
Apparantly "+AC" is on by default....(?)
.... this is new to me, it is apparantly not covered in the help file that was
distributed with POV-Ray 3.6.2 for Windows.
The help file needs to be updated for 3.6.2
What is "Antialias_Clipped"?
Date: 8 Jul 2009 07:35:00
Message: <web.4a5483fd3e2c1745bbaa2810@news.povray.org>
> ALSO....
Nevermind...
I figured out how to get 3.6.2 re-pointed to the proper place to play the
sounds.
Problem was:
The 3.6.2 installer, by default, sets some paths to users ... AppData ...
roaming ... (etcetera); and I installed to C:\POV-Ray (forced during the
install), but the installer does not take that into account. Fixed within
POV-Ray by invoking the Render menu -> Sounds -> and re-pointing to the actual
WAV locations in C:\POV-Ray.
Also... fixed the Help File problem by copying the C:\POV-Ray\help directory
(and contents) into Users\(ID)\AppData\Roaming\POV-Ray\v3.6\
Its looking like I should have just installed to the default directory that the
3.6.2 installer wanted to install to in the first place? Is that right? And to
avoid the Vista versus INI Files in Program Files problem, the installer places
INIs and INCLUDES (etc) into \Documents?
I am just going to uninstall / reinstall I think.
Date: 8 Jul 2009 08:00:01
Message: <web.4a548a013e2c1745bbaa2810@news.povray.org>
> > Folks,
> > -- Chris
> > interesting :-)
> > Stephen S
In revison.txt for 3.6.2:
Change 4387 on 2007/04/13 by chormann@chho
  [docs] adding documentation for the +ac/Antialias_Clipped option
I cannot find this anywhere.
Date: 8 Jul 2009 08:25:00
Message: <web.4a548fd13e2c1745bbaa2810@news.povray.org>
> Folks,
> -- Chris
Okay... SINCERELY SORRY about the "static" that I posted over the past couple of
hours... it was due to a knee-jerk reaction to differences between 3.6.1 and
3.6.2 installations under Vista.
I have re-installed into the *default* directory as suggested by the installer
(C:\Users ... AppData ... Roaming ... Confusing_Vista_Path_Stuff ... etcetera).
Everything is working fine. I can live with those critical files being in
D:\Documents. If this is the way that 3.7 is going to work (thanks to Microsoft
& Vista) thats OK I will get used to it (you have to remember that I am a
semi-senile old fart that built his first computer in 1978, and still sort of
misses DOS... actually I HAVE a legacy DOS 6.22 machine in the corner, that I
power up from time to time...).
One issue left; Documentation for 3.6.2 appears to need updating.
Antialias_Clipped is not covered in the documentation (revision.txt says that
the documentation WAS changed, but searching the CHM file I cannot find +ac,
+AC, or Antialias_Clipped). Would appreciate an explanation, I can't even guess
what "CLIPPING" is in relation to antialiasing...
Things like...
"Change 4428 on 2007/04/25 by calimet@lavender"
"photons change 3379"
(is this an "under the hood fix", or has photons changed to an extent that there
is something that users need to know?)
.... and possibly other things.
Date: 8 Jul 2009 10:30:00
Message: <web.4a54ace63e2c1745bbaa2810@news.povray.org>
> Folks,
> -- Chris
POVRay 3.6.2, installed under WinVista Home Premium 64 bit;
For Options -> Editor Window -> Create Backups; I could not disable this by
clicking (changing from Checked to UnChecked). I had to use regedit.exe to hack
it.
.... might be an issue that will occur with 3.7, if not fixed.
Date: 8 Jul 2009 19:50:01
Message: <web.4a552fbb3e2c1745de52d56d0@news.povray.org>
> reason.
Heh, no surprise here: The main reason for releasing 3.6.2 was to provide a
fully Vista compatible version of POV-Ray 3.6 :D
So being installed as a "native Vista" binary on Vista systems, why should the
OS offer any compatibility options? :P
Date: 8 Jul 2009 22:15:00
Message: <web.4a55520e3e2c17457a70716b0@news.povray.org>
FYI: This refers to the clipping of overly-bright colors to the displayable
range (0.0 to 1.0 in POV-Ray terms, or 0..255 in 8-bit RGB terms).
With anti-aliasing active, "prehistoric" versions of POV-Ray clipped such colors
on a *per-ray* basis, instead of the resulting pixel value. This seems to have
been changed in the course of introduction of proper gamma handling, so that
POV-Ray 3.6.1 clipped the colors on a per-pixel basis; note that this has the
same effect as generating HDR output, and converting the image to 8-bit in a
post-processing step.
However, in some situations - especially with extremely-overly-bright objects in
the scene - this approach may seem to give inferior results, which may be the
reason why it was re-introduced later (as an option) in 2007 (but never
released before; interestingly, it has also never been re-introduced to 3.7).
However, I think it was an oversight to include the 2007 change into 3.6.2
without at least changing the default to "off", as this has been the standard
for years now.
As already mentioned, POV-Ray 3.7 also invariably uses per-pixel clipping
(unless HDR output is used of course, in which no clipping is performed at
all).
Date: 8 Jul 2009 22:20:00
Message: <web.4a5553513e2c17457a70716b0@news.povray.org>
> it.
Just for additional info: Works fine under Windows XP Professional x64 Edition.
Date: 8 Jul 2009 23:50:00
Message: <web.4a5568733e2c17453ee9c7d90@news.povray.org>
> > reason.
Clipka;
Thanks much for your reply.... that makes sense. I've been playing with 3.6.2
all day, and now I have rendered many of the \scenes and some of the \portfolio
files... 3.6.2 seems to be working OK, except for a few very minor quirks.
Date: 8 Jul 2009 23:55:00
Message: <web.4a55690e3e2c17453ee9c7d90@news.povray.org>
> for years now.
> all).
.... then it sounds like something "not- to- worry- about", for someone
transitioning from 3.6.1 to 3.6.2 (I think...)
.... thanks for your reply Clipka.
Date: 9 Jul 2009 00:50:04
Message: <web.4a5576873e2c17457a70716b0@news.povray.org>
Well, as it *does* change the behavior (again) from 3.6.1 to 3.6.2 (unless you
explicitly turn it off), I would consider it something to worry about. A bit. A
very tiny bit, to be frank. I wouldn't expect it to ruin your shot either way,
and I guess for most shots it will not make a difference at all.
