POV-Ray : Newsgroups : povray.general : Requesting ideas/opinions for RNG seeding syntax Server Time
11 Oct 2026 12:18:03 EDT (-0400)
  Requesting ideas/opinions for RNG seeding syntax (Message 1 to 50 of 106)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: Requesting ideas/opinions for RNG seeding syntax
Date: 19 May 2009 13:11:34
Message: <4a12e846@news.povray.org>
I have discussed with the team about the idea of adding alternative,
higher-quality random number generators to POV-Ray 3.7. The current generator
would be kept for backwards compatibility, but alternatives would be offered.
  The only thing which is a bit open is the exact syntax for this. So far
this is the best idea:
  Enhance seed() so that it will take an optional second parameter, which
would specify the RNG algorithm used. It would default to the current RNG.
The rand() function would remain unchanged (internally it smartly selects
the proper RNG from the type of seed given to it). In other words, you would
be able to do, for example, like this:
#declare S1 = seed(1234); // Use the current RNG
#declare S2 = seed(1234, 1); // Identical to the above.
#declare S3 = seed(1234, 2); // Use second RNG algorithm.
  Additional algorithms might be added in the future. As mentioned, rand()
would be unchanged, so its usage would be the same:
#declare RandomValue1 = rand(S1);
#declare RandomValue2 = rand(S3);
  The current RNG uses a 32-bit seed, so a single parameter to seed() is
enough to get all possible streams. However, higher-quality random number
generators usually support much longer seeds, so it would be possible to
choose among a vastly larger amount of RNG streams. Thus it would be very
nice if larger seeds could be specified.
  The problem here is one of syntax. How to do this? Here are the ideas
so far:
1) Simply don't support seeds larger than 32-bit. This would work, but would
   be a bit of a bummer because the capabilities of higher-quality RNGs
   wouldn't be fully utilized.
   Alternatively, since seed() actually takes a (64-bit) float rather than
   a 32-bit integer, the seed range could be somewhat enlarged by taking
   the entire float range into account. This would allow using seeds of
   about 52 bits. (But it's still a long shot from the thousands of bits
   supported by higher-quality RNGs.)
2) Make it possible to give either a regular float (as now), or an array
   of floats as the first parameter of seed(). This way larger seeds can
   be specified as an array.
   While a bit cumbersome, it's not as bad as it may sound at first, because
   it's possible to do eg. this:
     #declare S = seed(array[4] { 1, 2, 3, 4 }, 2);
   It would still be nicer if something less cumbersome could be used,
   though...
3) Use an alternative function for long seeds. For example:
     #declare S = longseed(2, 1, 2, 3, 4);
   (where the first parameter specifies the RNG type used.)
   One small cosmetic problem with this is, however, that it's a bit
   inconsistent with the seed() function. seed() takes the RNG type as
   the second parameter, while longseed() would take it as the first
   parameter. This can be a bit confusing.
4) Create an entirely new syntax for specifying a group of values. This,
   however, would be laborious and should preferably be avoided.
  Opinions and additional ideas will be appreciated.
Subject: Re: Requesting ideas/opinions for RNG seeding syntax
Date: 19 May 2009 14:25:00
Message: <web.4a12f87238187d7e8ec49feb0@news.povray.org>
> so far:
>    though...
Offhand, if the length of the array of floats that the higher quality RNG
requires is less than or equal to 5, could the existing vector syntax be used?
Of course, feeding a vector to the seed() function would implicitly select the
better RNG:
#declare S3 = seed(<1,2,3,4>, 2); // Use second RNG algorithm.
#declare S4 = seed(<1,2,3,4>);    // short hand for second RNG algorithm,
                                  //  same as above
Or something.
-Reactor
Date: 19 May 2009 14:57:23
Message: <4a130113@news.povray.org>
  It's not that the RNG *requires* longer seeds. It *supports* longer seeds.
  It could be one idea, although a bit limited.
> better RNG
  I think it's better for the syntax to be the same and consistent for all
RNG types. Besides, if there were more than one RNG type supporting longer
seeds, which one would be chosen?
Date: 19 May 2009 15:40:01
Message: <web.4a130a8638187d7e14a420210@news.povray.org>
Stupid question: Why? What would be the benefit?
Let's have a closer look at the use cases for seeding.
(a) To have multiple independent and uncorrelated RNG streams:
When e.g. randomly placing N trees and M rocks, you may want to use a "fresh"
RNG stream for each of the two tasks, so that in a test render you can place
only the trees, or only the rocks, without this affecting their placement; at
the same time you want the two streams to produce different values, to prevent
apparent correlations between the placement of the trees and rocks.
You can achieve this by using two random streams with different seeds.
To this end, you would probably need just a handful of distinctive seed values -
at most as many as there are RNG streams.
(b) To manually "pick" a certain RNG sequence:
Sometimes you may prefer the results of one random sequence over another; e.g.
you may want to place items at random, and the initially chosen seed may happen
to produce an unfavorable distribution.
You can solve this by trying out different seeds.
To this end, you'll probably try just several handful of different seed values
before you either find a suitable seed, or get tired and figure that the
unfavorable distribution may be virtually uavoidable for statistical reasons.
(c) To automatically "pick" different (but otherwise arbitrary) RNG sequences
based on some other parameter:
For instance, in an animation may want a certain RNG sequence to be different
for frame.
You can achieve this by seeding your RNG with the frame number - or a digest
thereof.
In this case, you'll need as many different seed values as there are frames in
your animation - several thousands probably.
There may be other use cases. However, I guess it will be difficult to find any
that will really require more than a few thousand distinct seed values.
Thus, a single 64-bit floating-point seed value (or even a 32-bit integer) is
probably perfectly sufficient, so that the whole issue boils down to devising a
smart enough way to "inflate" it to a suitable initial state value for the RNG.
If we'd be talking about cryptography, then yes - in that case it would make a
huge difference how many distinct seed values we actually have to choose from;
but even then not because we'd actually use them all, but for the sole reason
that we *could*, so that a bad guy wouldn't know which one we chose.
Other than that, there's no real use in having a high diversity in seeds. So
*that* capability of higher-quality RNGs wouldn't be utilized in POV anyway.
The other major capabilities of higher-quality RNGs - that for practical
purposes the sequences don't repeat, and that they are less prone to produce
obvious patterns - are in no way diminished by reducing the available set of
Date: 19 May 2009 16:28:48
Message: <4a13167f@news.povray.org>
  I don't agree with the idea that since you can't think of any use of
large seeds, we should not offer them for the user if he wants to use
them, given that the RNGs support them and it's only a question of what
would be the handiest SDL syntax to interface with them.
  Let me as you the reverse question: Why should we *not* offer large
seeds? Why limit the usability of the RNGs for no good reason?
  This is not a question of it being *difficult* to implement. It's just
a question of *choosing* which SDL syntax would be the most fluent to
interface with it. I see absolutely no rational reason to limit the
usability of higher-quality RNGs simply because it's a bit difficult to
choose the SDL syntax.
Date: 19 May 2009 17:11:30
Message: <4a132082@news.povray.org>
clipka wrote:
is
ber
to
ery
	There is a very common use case that you have forgotten: to be able
to save the state of the random generator so that you can pick up
from the same point later (in a subsequent animation frame for
example). This requires two things:
- A function that returns the current state of the generator;
- The ability to initialize the generator with this state.
	In that case, the seed may take the whole range of values supported
by the algorithm.
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 19 May 2009 17:17:23
Message: <4a1321e3$1@news.povray.org>
It disturbs the syntax of the seed() call that exists even more. So it's
mostly a matter that you already addressed: the syntax is ugly.
However, consider your longseed() example. Why not pass the random number
stream to the longseed() routine.  seed() would still be used to seed and
create a random number generator, but now you can reseed the generator with
longseed().  Given that someone might want to do this with the current PRNG,
it could just be called "reseed()".
Conflating "create a PRNG stream" with "set the seed" seems to be at the
crux of the syntactic-ugliness problem.  Just a thought to stew upon.
   There's no CD like OCD, there's no CD I knoooow!
Date: 19 May 2009 17:27:32
Message: <4a132444@news.povray.org>
  But it's not like you would notice if you don't care about the extra
long seeds. If you are content with the 32-bit seeds, you can use seed()
in the exact same way as now. The long seeds would just be an extra which
doesn't disturb the currently existing syntax.
Date: 19 May 2009 18:00:00
Message: <web.4a132ac038187d7e97530ad10@news.povray.org>
From an end user point of view, this is good. Can it be optionaly expanded
again?
#declare S4 = seed (1234, 2, array[4] { 1, 2, 3, 4 } )
to cover any additional requirements.
Stephen S
Date: 19 May 2009 18:30:00
Message: <web.4a13328238187d7e34d207310@news.povray.org>
Sounds like an excellent way of making povray more powerful without breaking the
old syntax.
I also think your philosophy is purely correct about erring on the side of
giving it more power. Giving povray a military-grade RNG may prevent some jerk,
five years from now, from complaining that it doesn't have such a quality RNG.
I sometimes wonder if there were a debate about giving us powerful tools like
the trace() function.  I could imagine someone saying, "povray is a raytracer,
not a modeler", so why would you give it functions that are properly handled in
the modeling software?
Date: 19 May 2009 18:53:17
Message: <4a13385d@news.povray.org>
Certainly. You asked what was wrong. It's not a big problem. It's just
slightly ugly, because you're trying to take a function that currently takes
one seed-number, and turn it into a function that takes an optional PRNG
identifier and a variable number of seed numbers. That's hard to do,
syntactically, without making things ugly (such as by passing a single value
that's actually a collection of values).
I'm just saying, perhaps having a different function would make it less
ugly, as well as leaving open the possibility of being able to save and
recall the PRNG's state. As Mr Berger pointed out, being able to dump out
the state and reload it would be good too.  Whether you can do the
dump/reload with the same function that sets the seed is another question,
tho. I would imagine some PRNGs (RC4 leaps to mind) might take a state that
needs to be in a specific form.
As an aside, how about allowing a string as a seed, perhaps with hex
digit-pairs if POV doesn't support 0-255 in strings?
seed(23)
seed("18D8237")
That would seem to allow for the maximum number of bytes in a seed without a
problem. If you made the state dump/reload also provide/require a similar
string, you could easily write it to a file, ship it to macros, etc.
Date: 19 May 2009 20:25:31
Message: <4a134dfb$1@news.povray.org>
Warp nous illumina en ce 2009-05-19 13:11 -->
> so far:
>    though...
An option could be to do something similar to the noise generators. You can
select witch one to use in the global_settings section, with a default one.
It should be possible to add something like:
random_gemerator 2
The generator 1 would be the number 1, the actualy proposed one number 2, and
there is room to add some other generators.
I also like the idea of been able to use a float as the seed. Providing a float,
like 1.0 would automaticaly sellect the new generator.
Date: 19 May 2009 20:28:55
Message: <4a134ec7$1@news.povray.org>
> generator
> offered.
> would
> so far:
> would
> because
>   though...
IMO, there's no real need for access to larger seeds...
for example mersenne twister (MT19937) is seeded from
a single 32 bit value, even though it generates 624 values for
the internal state. There's more call for access to the RNG
state, but I can't see a way to keep compatability with 3.6 syntax.
So, for now...
RNG_Identifier = seed( Float | Float_Identifier [,Float | Float_Identifier])
I'd like to see a reworking of the syntax for this in 4.0,
in general I think it's bad to have numbered parameters as
was done for media scattering models. I prefer more descriptive
wording. I also think that using optional parameters between ()
as if they were between {} looks ugly.
Ultimately for 4.0 I'd like to see all the command-line, and
ini file options moved into SDL, so that command-line, and
ini file options are always considered to over-ride settings
in SDL. Then separate the scope of such commands into
sections... animiation{}, environment{},scene{},post_process{}.
Seed is probably one of the commands that would belong in
the environment section, along with camera, photons, and radiosity.
It's part of the starting state of the renderer.
RNG_Identifier = random_number_generator {
   [type POV36 | mersenne_twister]
   seed Float | Float_Identifier
It's a bit more verbose, but it's more amenable to be
extended in the future.
Date: 20 May 2009 01:46:51
Message: <4a13994b$1@news.povray.org>
I don't think that's a good way to do it. The problem is that the second
parameter is confusing to people who don't already know the function. Even
if the parameter is passed as a named constant, like RNG_SUCHANDSUCH (which
in POV-Ray would probably require #including a file with a name you'll
forget), this isn't the sort of thing that's useful as a parameter, because
you're never going to want to change it dynamically. I think it would be
simpler and clearer to use a separate function for different random number
generators, like rand_suchandsuch( seed ).
> would
I would go with this, because it's easy for the user. In my life, I will
never see more than 2^32 images, so that many different random number
streams aren't necessary. The biggest advantages of other RNGs are the
randomness of their behavior over multiple calls, not the number of
different streams.
Keep in mind that, in practice, when you are writing a scene and need to
come up with a seed you just type in a "random" number. If it gives bad
results, you type in another one. Maybe instead you'll do something that's
calculated, like frame_number, or the time of day, or something like that,
but even in these cases, when are you going to run out of values?
At the very least, the simplicity of seed(345) should be available so users
don't have to learn more than they already do to use a conceptually simple
feature.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 20 May 2009 01:57:31
Message: <4a139bcb@news.povray.org>
As long as that is the case, I would go with whatever syntax is most useful
for people who will be generating their scenes programatically, because
they're the most likely to want to use that feature.
 - Slime
Date: 20 May 2009 02:45:01
Message: <web.4a13a5ea38187d7ef50167bc0@news.povray.org>
> random_gemerator 2
I like this idea as well--very simple. Although, I don't see how the more
complex random generators that Warp has mentioned would be able to be
incorporated in such a scheme, IF we continue to use just seed() with a single
value (as we do now.) I.e., how would seed(23) provide or access all the
multiple variables that have been discussed?
I tend to agree that just about any syntax for more complex seeding(s) would be
OK. Those of us that need a more complex random generator will learn it's
usage; those who just need a 'good' generator will stick with seed(23). I think
it boils down to who needs what: Scientists/cryptographers/experimenters will
likely welcome more complex seed algorithms; the typical POV 'artisan' (like
me) just needs a (better) random-number generator, simply an improvement over
what we have now, with the same easy-to-use syntax.
KW
Date: 20 May 2009 10:25:01
Message: <web.4a1411e738187d7ef708085d0@news.povray.org>
> by the algorithm.
Obviously it's not so common in the POV-Ray world :P
Anyway, if there would be intention to implement such a thing in POV-Ray SDL,
there would be no need for a "user-friendly" notation. So e.g. a base64-encoded
string of the raw state data would do as fine as any other notation.
Date: 20 May 2009 10:30:00
Message: <web.4a14136438187d7ef708085d0@news.povray.org>
Being on it, methinks the string handling in POV needs reworking anyway... one
more for the POV-Ray "bug"tracker
Date: 20 May 2009 10:39:31
Message: <4a141623$1@news.povray.org>
> by the algorithm.
In many PRNGs, the seed and the state are distinct structures. Sometimes,
for example, the internal state maintains a certain pattern, and the
algorithm stops working if you put arbitrary data into the state.
Date: 20 May 2009 10:43:30
Message: <4a141712$1@news.povray.org>
The advantage of changing the seeding rather than the rand() call is there's
usually a very small number of seed()s, one for each stream.  If you find
your trees aren't being placed properly, you can change the seed() for the
tree placement and leave the seed for the leaf placement alone. And you
don't need to track down every call to rand() and figure out which it is.
Putting it in the defaults is a good idea, but then it prevents using
multiple different PRNGs in the same scene.
Date: 20 May 2009 10:55:00
Message: <web.4a14198d38187d7ef708085d0@news.povray.org>
Unfortunately, that's a no-go: POV-Ray's parser framework isn't designed to tell
the difference between 1 and 1.0.
Date: 20 May 2009 11:05:01
Message: <web.4a141b4b38187d7ef708085d0@news.povray.org>
Not if it's used in some huge macro. In that case, it's part of the starting
state of the macro.
I'd actually favor something like:
My_Random_Stream = Pov36_Rng(4711);
My_Random_Number = My_Random_Stream.getNext();
Other_Random_Stream = Mersenne_Twister_Rng(...);
Other_Random_Number = Other_Random_Stream.getNext();
i.e. sort of defining the different RNGs as different, independent objects
(which just "happen" to use the same method identifier to get the next value).
But that's "future music" as we'd say in German.
Date: 20 May 2009 17:44:18
Message: <4a1479b2@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.4a141b4b38187d7ef708085d0@news.povray.org...
> starting
> state of the macro.
Sure, but a normal macro that isn't redefined multiple times
would belong in the environment section too... any subroutine
that can be compiled once would go there. With some
4.0 macro syntax to make it clear that is what is going on hopefully.
> value).
That would be hard on the parser, every RNG command would be
at the top level, if they're inside a common constructor then at the top
level there's just the check for the constructor.
Date: 21 May 2009 02:06:21
Message: <4a14ef5d@news.povray.org>
  You could only specify integer literals like that. You couldn't do
something like this, which isn't even rare:
#declare S = seed(1234 + frame_number);
with a long seed.
Date: 21 May 2009 02:10:14
Message: <4a14f046@news.povray.org>
  If the extra seed values are given as additional parameters, there's no
need for an array, as they could be given as direct parameters, ie:
#declare S4 = seed (1234, 2, 1, 2, 3, 4 );
  That could work, although it's still a small cosmetic problem that the
seed is specified as the 1st, 3rd, 4th, etc. parameters, so there's an odd
discontinuity there...
Date: 21 May 2009 02:17:07
Message: <4a14f1e2@news.povray.org>
  seed() can be changed so that it can take any amount of parameters.
  If the current RNG is being used, it would just take the first parameter
and ignore the rest. If RNGs with support for larger seeds are used, they
would take as many parameters as given (up to the maximum amount supported
by the RNG).
Date: 21 May 2009 02:21:14
Message: <4a14f2da$1@news.povray.org>
Good point. Probably still the easiest format if you want to dump internal
state and then reload it later.
Date: 21 May 2009 02:29:32
Message: <4a14f4cc@news.povray.org>
  There are RNGs and applications for them where larger seeds are needed.
  Someone mentioned encryption, where the seed acts as the encryption key.
Sure, you could always argue "nobody will ever need encryption in POV-Ray".
You could make the same argument about half of POV-Ray's features.
  I'm pretty sure there are things like stochastic simulations where seeds
larger than 2^32 could be useful.
  As I mentioned in another post, it makes little sense to me to stop the
user from accessing the features of the RNG simply because someone can't
think of good uses for them. And I really think that going the old route
of "2^32 random number streams ought to be enough for anybody" is not smart
in the long run.
  If that's true, then IMO that lessens the usefulness of MT.
  The RNG I'm considering supports very large seeds (up to something like
8192-bit seeds if so configured) and has very high quality and speed.
Date: 21 May 2009 02:38:20
Message: <4a14f6dc@news.povray.org>
> > would
  I'm not sure if you got the idea, but the addition of new RNGs with
larger seeds would *not* change the current usage of RNGs in any way.
You could still use the current RNG in the *exact* same way as currently.
  If you don't care about which RNG is used or how large the seeds are,
then you can simply ignore the extra stuff and use seed() and rand()
exactly like now.
  I really don't see how limiting the seeding is "easy for the user".
> In my life, I will
  How many of the features supported by POV-Ray have you ever used in your
life? Would you like those features you haven't used to be removed because
you have never used them?
  Does it bother you that POV-Ray supports more features than what you use?
If not, then why would it bother you if POV-Ray supported long seeds,
especially if you don't even have to know how they are specified and you
can still use seed() and rand() like currently?
  Can you agree that *some* people might find useful uses for longer seeds
even if you don't, exactly in the same way as some people find useful uses
for other POV-Ray features that you have never used?
Date: 21 May 2009 04:13:09
Message: <4a150d15$1@news.povray.org>
> exactly like now.
That's fine then. It's just the simple syntax which is easy.
I can agree that they might. However, I can't imagine a situation where it
would be useful, so the point to consider is whether it's worth the time to
implement the feature (and fix any bugs it may have afterwards). At least we
should come up with an imaginary case where someone might benefit from this
functionality.
 - Slime
Date: 21 May 2009 05:55:00
Message: <web.4a15247d38187d7ef50167bc0@news.povray.org>
> > In my life, I will
Good argument, I have to say. (I'll probably never get around to using all the
features POV offers, unless I were to spend full-time with it--which isn't so
different than I what I do now!)
KW
Date: 21 May 2009 12:30:00
Message: <web.4a15809c38187d7ed92e869d0@news.povray.org>
Actually, most common *implementations* of the Mersenne Twister use a single
32-bit value to seed the generator. In actuality, the "seed" of the Mersenne
Twister can be any 2^19937 bit value, except all 1 bits. In practice, we use a
single 32-bit value to "randomly" generate the seed, where the "random" part is
usually an LCG. Some specific implementations do allow seeding the with the full
range of valid seeds. The method of seeding is a separate issue from whether the
MT is a good RNG.
In practice, you're going to want a simple seeding system that uses a single
32-bit value, for people who just need data that "looks" as random as possible.
Then you will want a full-range seeding system (such that it places the RNG
anywhere in its period), for people who need data that IS as random as
possible.
For raytracing, I'll venture a guess that 99.9% or more of our users just need
data that LOOKS as random as possible. Very few people need data that truly IS
as random as possible. The distinction is subtle.
Consider shuffling a deck of cards. Each time we shuffle the deck, use a truly
random process to determine the shuffling, like thermal noise or radioactive
decay or whatever. This is basically what happens when you seed a high quality
RNG. Regardless of how you seed the RNG, as long as the seed is essentially
random, the output will be completely random for most practical purposes.
So, back to the card shuffling example: Do this 16 times, to get 2^4 (most
likely) different shufflings of the deck. (I'm using 2^4 to help exaggerate the
problem of insufficient seed space.)
Now consider each of these 16 shufflings as corresponding with a particular
"seed" in the range 0 to (2^4)-1. Each of these 2^4 shuffled decks appears
completely random, because they ARE completely random (remember, the thermal
noise or whatever?). Any one of these would be fine, if all we want is a
raytraced image of a poker game or whatever, one that LOOKS random.
However, there are only 16 possible shufflings out of 52!, or about 8*10^67. So
not every possible shuffling can be acheived from our initial seeds. Not even
close!
But in reality, every possible shuffling could appear from a truly random
process. So the 2^4 seeds are not sufficient to provide a poker hand that comes
from a proper random distribution. It LOOKS completely random, if all you want
is something that "looks" like a random shuffling of a deck. But, for example,
if none of those 16 shuffled decks contains a royal flush for some player, then
no matter how you seed the RNG, no one will EVER get a royal flush.
In other words, if I'm a poker player with money on the line, then I want a game
that guarantees that every possible shuffle of the deck is possible. With only
16 seeds, then the game can only guarantee that the deck will be one of 16
pre-determined random shufflings of the deck. Like I said, the distinction is
subtle, and I suppose some people won't think the distinction matters at all.
Date: 21 May 2009 12:44:11
Message: <4a1584db$1@news.povray.org>
clipka nous illumina en ce 2009-05-20 10:54 -->
Bummer!
Another possibility:
If the seed is an integer, use the current generator.
If the seed value is a float, use the improved generator. Here, a float would be
deffined as any value that can't be represented as a 32 bits integer: to big or
having a fractional part.
Date: 21 May 2009 13:45:00
Message: <web.4a15920938187d7ee1d5d3040@news.povray.org>
> in the long run.
Wasn't there *some* talk about a major rework of the SDL anyway?
So I'd say, never mind about "huge seeds" for now, and leave that up for a
next-generation SDL to take care of.
Date: 21 May 2009 14:48:50
Message: <4a15a212@news.povray.org>
> > in the long run.
  No, I disagree with the idea that we should simply not support long seeds
for the simple reason that deciding on the handiest syntax is not immediately
obvious. I would certainly want access to the whole RNG even if doing so
would require writing a few more characters.
Date: 21 May 2009 15:55:01
Message: <web.4a15b08f38187d7ee1d5d3040@news.povray.org>
.... and me, I'd consider a higher-quality RNG too important to waste time on
special syntax whose sole *real* benefit would be the ability to turn POV-Ray
into a strong cryptographic application or a poker game engine.
BTW, not only users, but also other parts of POV-Ray could benefit from a good
RNG. Subsurface scattering, for instance, currently suffers dearly from the
lack of a good random number source.
You can always wreck your brain on that super-duper-seeding syntax in a later
increment.
I'm not saying "never ever support it" - all I'm saying is "it's not nearly
important enough to waste time on it right now".
Date: 21 May 2009 16:35:30
Message: <4a15bb12$1@news.povray.org>
As an alternative suggestion, how about treating PRNGs
syntactically more like an object, such as
#declare R = prng {type 1 seed 42}
It gives more flexibility to the syntax as the specified
attributes may now depend on the type of PRNG (possibly some
PRNGs could have additional settings such as number of bits
used or similar?).
Obviously, "seed(n)" should be treated as "prng{type 0 seed n}",
although it might print a warning about obsolete syntax.
The seed attribute would be convenient 32-bit seed, but some PRNGs may
support specifying specialized seed values via additional attributes
long_seed or a different syntax for seed such as "seed {1,2,3,4}".
This syntax could probably be shared for most complex PRNGs.
There may also be additional type-specific attributes for
initializing the complete "state" of a PRNG (from messages in
this thread I infer the state may encompass more information
than even a long seed value?). However, to actually allow
persisting the state, it would be necessary to have a
function such as rand_state(R).
Date: 21 May 2009 18:45:28
Message: <4a15d988@news.povray.org>
>> > the
>> > can't
>> > route
>> > smart
>> > in the long run.
>> a
> immediately
I'm just worried that extended syntax for some things might become
ugly and undocumented.
Something like...
PRNG_Id = prng {
   [type pov36 | mersenne_twister]
   seed Float | Float_Id | FloatArray | FloatArray_Id
wouldn't be too bad. It's just not 3.6 compatible.
For 3.7 to be 3.6 compatible, it makes sense to have it be
PRNG_Id = seed(Float | Float_Id [, Float | Float_Id [, Array | Array_Id]])
where the second number is an optional PRNG type,
and the first seed number is ignored if there is an array provided
to seed the state with.
Date: 21 May 2009 18:47:49
Message: <4a15da15$1@news.povray.org>
Or, you could just have two ways to create a PRNG stream. One with the old
syntax, one with the new.
Date: 22 May 2009 02:43:42
Message: <4a16499e$1@news.povray.org>
no
e
odd
	Well, you could always say that if more than one parameter is
given, then the first parameter identifies the algorithm and the
other parameters make up the seed:
// Same as now:
#declare S1 = seed (1234);
// Equivalent to the above:
#declare S2 = seed (1, 1234);
// Use new algorithm number 2 with a longer seed:
#declare S3 = seed (2, 1234, 5678);
		Jerome
Date: 22 May 2009 02:52:36
Message: <4a164bb4$1@news.povray.org>
ke
	As a simple matter of curiosity, which RNG are you considering?
		Jerome
Date: 22 May 2009 12:40:02
Message: <9ltie6-obj.ln1@badulaque.unex.es>
Among other things, Warp saw fit to write:
Somewhere between 3 and 4:
3.5) Create a sort of "concatenate numbers" function, that would allow
really large numbers, maybe with and arbitrary number of parameters. If the
function is named "numconcat":
seed(1234)   // current
seed(1234,1) // same as above
seed(1234,2) // new RNG with small seed
seed(numconcat(1234,5678,90),2) // new RNG with large seed
The function numconcat need not be a "real" concatenation, i.e., there's no
reason why numconcat(1234,5678,90)=1234567890, it should just create a
large number out of smaller ones.
Hmm... maybe that's what option 4 meant from the beginning, though.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 22 May 2009 15:28:11
Message: <4a16fccb@news.povray.org>
  Btw, just use "float expression" to indicate anything that evaluates to
float in a comprehensive way.
Date: 22 May 2009 15:30:32
Message: <4a16fd58@news.povray.org>
"Jérôme M. Berger" <jeb### [at] freefr> wrote:
> [-- text/plain, encoding quoted-printable, charset: UTF-8, 14 lines --]
  The ISAAC RNG, of which I have some experience and have found to be of
very decent quality (should be rather cryptographically strong) and very
fast, and with a very large period. Also according to my experience it's
faster than Mersenne Twister without the need for special compiler options
(the MT can be made as fast, but only if you create a special SSE version
of it).
  (Of course speed is not really crucial here, but the quality should be
very good.)
Date: 22 May 2009 15:31:55
Message: <4a16fdab@news.povray.org>
  I'm not sure if with the POV-Ray parser that 'seed' keyword would cause
a clash with the seed() function. Some names can be used in different
contexts, but I'm not sure this is one of those cases.
Date: 22 May 2009 15:50:00
Message: <web.4a17019638187d7e92f9e9e10@news.povray.org>
> very good.)
Given that there might be some good use for a more sophisticated RNG inside
POV-Ray's rendering engine possibly heading our way (thinking of SSLT here, or
maybe addition of some montecarlo elements), I guess speed *should* be
considered an issue.
So to hear that the RNG you have in mind *is* fairly fast, that's good news.
Date: 23 May 2009 08:50:00
Message: <web.4a17efe538187d7e8256f3f20@news.povray.org>
What about this algorithm
Xn+1 = SXn - INT(SXn)
See
http://www.number.com.pt/index.html
Phoenix
Date: 23 May 2009 11:57:35
Message: <4a181cef@news.povray.org>
> of it).
> very good.)
	Thanks, that's very interesting to know.
		Jerome
PS: If anybody wants more information on ISAAC, Google gave me this
page: http://burtleburtle.net/bob/rand/isaacafa.html
Date: 23 May 2009 12:30:51
Message: <4a1824ba@news.povray.org>
  My C++ version should be much easier to use, though:
http://warp.povusers.org/IsaacRand.zip
Date: 23 May 2009 13:21:39
Message: <4a1830a3$1@news.povray.org>
> See
	That's a basic LCG (same as the current POV algorithm) except that
it's implemented in floating point. It will have the same
shortcomings...
		Jerome
