POV-Ray : Newsgroups : povray.general : Random Filling Plane with objects Server Time
5 Mar 2026 00:19:25 EST (-0500)
  Random Filling Plane with objects (Message 1 to 4 of 4)
Subject: Random Filling Plane with objects
Date: 4 Apr 2011 16:09:23
Message: <4D9A2562.7050901@joplin.com>
I've been playing with randomly putting boxes on a plane. I think I've
come up with a pretty good technique.
  I have an 2d array that acts as the plane. When every you place an
object you mark the array. But you don't just mark the location, you
treat the array as if it where a display screen and you paint the object
to it. And you also mark areas that around your object that no other
object could be placed there.
  When you randomly choose a location you only have to check if there
is anything at that location. I use #ifdef statement as I don't fill the
2d array with anything except objects.
  I've been using boxes and a 300*300 2D array. And getting fairly good
density (99%). And runs times less than 2 min. with display.
  Just Bragging :)
I was wondering if any one else has use this technique.
Subject: Re: Random Filling Plane with objects
Date: 4 Apr 2011 16:17:03
Message: <op.vtfjymztufxv4h@xena>
On Mon, 04 Apr 2011 22:09:06 +0200, Leroy Whetstone <lrw### [at] joplincom>
>   Just Bragging :)
How does it differ from
POV-Ray\v3.7\scenes\advanced\blocks\
-Nekar Xenos-
Date: 5 Apr 2011 01:42:19
Message: <4D9AABA9.6040308@joplin.com>
>> I've  come up with a pretty good technique.
>> object  to it. And you also mark areas that around your object that no
>> other  object could be placed there.
>> the  2d array with anything except objects.
>>   Just Bragging :)
I fill an area with boxes not stack them. And it is fast! Really it's
just a start.
Next thing to try is to fill with spheres.
Date: 13 Apr 2011 23:37:38
Message: <4DA66BE0.5030302@joplin.com>
Spheres placement done. Also I tried the same technique putting spheres
in a box.
Not so fast, it took 30 min. to place 170,000 in a 100*100*100 box
What got me started on this is an old random placement POV file that use
rather slow and time consuming algorithm. What I like about the
algorithm I use is that you have a choice of how close you want the
objects to be to each other. From touching to far apart.
Have Fun!
