POV-Ray : Newsgroups : povray.general : remove array element after N uses? Server Time
6 Nov 2026 17:19:53 EST (-0500)
  remove array element after N uses? (Message 1 to 15 of 15)
Subject: remove array element after N uses?
Date: 25 Mar 2009 10:18:54
Message: <49ca3d4e$1@news.povray.org>
Lets say that I have an array of vectors, and that I wish to use its
elements a variable number of times (which might be different for each
element) and then remove the used element from the array.
The only thing that I can come up with would be to use a 3D array like this:
//      randVectorMMR Macro by [GDS|Entropy]
//      For element reuse capability
#macro randVectorMMR(Array,ctr,Min,Max,rMin,rMax)
 #local i=0;
 #while (i<ctr)
  #declare Array[i][0][0] = <RRand(RsA, Min, Max),RRand(RsA, Min,
Max),RRand(RsA, Min, Max)>;
  #declare Array[i][1][0] = <0,0,0>;
  #declare Array[i][1][1] = <0,RRand(RsA, rMin, rMax),0>;
 #set i=i+1;
//      RRand Macro by Chris Huff
#macro RRand(RS, Min, Max)
 (rand(RS)*(Max-Min) + Min)
//      Round macro by [GDS|Entropy]
//      Adapted from Trevor G Quayle function
#macro Round(Number,RoundTo)
 #if (Number >= 0)
  1*int(abs(Number)*pow(10,RoundTo)+0.5)/pow(10,RoundTo)
 #else
  -1*int(abs(Number)*pow(10,RoundTo)+0.5)/pow(10,RoundTo)
//      VRound macro by [GDS|Entropy]
#macro VRound(Vector,RoundTo)
 <Round(Vector.x,RoundTo),Round(Vector.y,RoundTo),Round(Vector.z,RoundTo)>
#declare ctr = 10;
#local maxReuse = 10;
#local minReuse = 1;
#declare myArray = array[ctr][2][2];
randVectorMMR(myArray,ctr,1,5,minReuse,maxReuse)
#local i = 0;
#while (i < dimension_size(myArray,1))
 #local pos = myArray[i][0][0];
 #local use = myArray[i][1][0];
 #local ass = VRound(myArray[i][1][1],0);
 #debug concat("Array Value: ", vstr(3,pos,",",3,3)," ")
 #debug concat("Assigned Reuse : ", vstr(3,ass,",",3,3)," ")
 #debug concat("Used: ", vstr(3,use,",",3,3)," times \n")
 #if (use.y < maxReuse & use.y < ass.y)
  object {
   foo
   translate pos
  #declare myArray[i][1][0] = myArray[i][1][0] + 1;
  #local i = i;
 #else
  #local i = i + 1;
#undef myArray
That way sucks, and it doesn't remove the element from the array.
Whats a better way of doing this?
ian
Subject: Re: remove array element after N uses?
Date: 25 Mar 2009 11:40:00
Message: <web.49ca4fd59fb46029c1f399840@news.povray.org>
Oh, those pesky OOP-spoilt greenhorns! ;)
When I was still young and handsome, such information would be stored in a
separate array, like this:
    10 DIM x(100),y(100),z,used%(100)
    20 FOR loop% = 1 TO 4711
    30   LET i% = RND(100) + 1
    40   LET used%(i%) = used%(i%) + 1
    50   PRINT "<";STR$(x(%i));",";STR$(y(%i));","STR$(z(%i));">"
    60 NEXT loop%
    70 END
    5 RANDOMIE TIME
    12 GOSUB 1000 : REM fill data
    50   PRINT "<";STR$(x(%i));",";STR$(y(%i));","STR$(z(%i));">";
    55   PRINT " used ";STR$(used%(i));" times"
    LIST -100
    5 RANDOMIE TIME
    60 NEXT loop%
    70 END
    READY
    RUN
    SYNTAX ERROR IN LINE 5
    READY
    LIST 5
    5 RANDOMIE TIME
    READY
    5 RANDOMIZE TIME
    RUN
    LINE DOES NOT EXIST IN LINE 12
    READY
(Yeah, those were the days! You just flipped the power switch, and your
programming IDE would be up and running in 5 seconds... ah, modern
technological advancement has deprived us of all that joy...)
.... then someone invented structs (oh, well, "records" for me back then, because
I went for Turbo Pascal)...
But I'm getting a bit off topic... so back to your problem:
First thing to know: No, POV SDL unfortunately doesn't have something like
structs. Nor does it have dynamic lists. Be happy and content that you don't
have to mess around with line numbers ;)
Why use a 3-dimensional array when a 2-dimensional one will do the job?
#declare Array[i][0] = <...>;
#declare Array[i][1] = <0,0,0>;
#declare Array[i][2] = <0,RRand(RsA, rMin, rMax),0>;
Then, to get rid of an entry of such an array, you could use:
#undef Array[i][0]
#undef Array[i][1]
#undef Array[i][2]
and check for #ifdef(Array[i][0]) when you loop through the array.
I guess that's as close as you can get to what you want.
Date: 25 Mar 2009 11:55:00
Message: <web.49ca53b89fb460296dd25f0b0@news.povray.org>
[snip nostalgia]
Hmm, looks very much like Acorn BASIC. Although, 5 seconds? If that were a beeb
you'd be ready to go before your finger had even left the power button...
(GOSUB, eww. PROC was the only way forwards :-) )
Date: 25 Mar 2009 12:23:08
Message: <49ca5a6c@news.povray.org>
That included the time for the TV tube to warm up. ;-)
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 25 Mar 2009 12:50:00
Message: <web.49ca600c9fb46029c1f399840@news.povray.org>
Not on the Amstrad CPC 6128 I was toying around with ;)
Locomotive Basic 1.1 ((C) 1985 if I remember correctly...)
The Sinix Basic I had to work with about 20 years later was a bit more
sophisticated... still I was glad it was only a few months' assignment ;) (Much
of the stuff I had to deal with was old-school code, with lots of GOTO
<line_number> in it >_<)
It was quite fun though: As the old Sinix machine was scheduled for ultimate
powerdown, the task was to port those programs... to VBA of course :P
I ended up writing a parser for the old Sinix Basic code that would
auto-generate a VBA module, and a library of subroutines that would simulate
the Sinix Basic's formatted input, output and file access functions with all
their peculiarities...
Why do a brain-dead job when you can write a brain-dead piece of software to do
it for you? Usually it costs about the same time it actually saves, but it sure
as hell is a good deal more fun ;) (plus, it tends to impress people)
Date: 25 Mar 2009 14:02:14
Message: <49ca71a6$1@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.49ca4fd59fb46029c1f399840@news.povray.org...
<SNIP>
o_O'
Eew...BASIC...I'd rather learn just get it over with and Assembly (its on
the TODO list)..
Ubuntu will boot on a very old machine I have from the liveCD in just over 6
times that...not that bad considering that includes GNOME.
> because
Structs rock.
> don't
Dynamic lists also rock.
I did mess around with BASIC back in elementary school (early/mid 80's).
That is when I decided that I didn't like it much, and chose to avoid any
language with Basic in the name.
Damn...maybe it would be seriously worth the effort of tracking down
whatever code handles structs and dynamic lists and etc.. in the language
that pov was written, and integrating that into povray with some nice SDL
implementation. I'm more than sick of needing and not having those kinds of
things.
http://www.haskell.org/haskellwiki/POV-Ray_SDL_project
Someone has the right idea.
They said this too: "Endless flamewars have raged over the subject of
whether the SDL should become object-oriented."
When did THAT happen?! O_o'
This newsgroup seems rife with thoughtful discourse and quite a high SNR,
not "endless flamewars"...
Beyond being just something that I threw together to do something like what
I wanted, I decided that I might want to add an absurd amount of
functionality later and that this would be the most logical way to leave my
options open. For example I might add other related things to each of the
dimensions, and it might be best to keep each category of data seperate.
> #undef Array[i][0]
> #undef Array[i][1]
> #undef Array[i][2]
I might be able to adapt such a thing to do what I wanted in the first
place. I guess if the following (untested) macro works, I could just call it
once the established number of "uses" has been reached to purge the elements
I need to.
#macro
undefElement(Array,dim1Element,dim2Element,dim3Element,dim4Element,dim5Element)
 #local numDimensions = dimensions(Array);
 #if (numDimensions = 1)
  #undef Array[dim1Element]
 #if (numDimensions = 2)
  #undef Array[dim1Element][dim2Element]
 #if (numDimensions = 3)
  #undef Array[dim1Element][dim2Element][dim3Element]
 #if (numDimensions = 4)
  #undef Array[dim1Element][dim2Element][dim3Element]][dim4Element]
 #if (numDimensions = 5)
  #undef
Array[dim1Element]][dim2Element][dim3Element]][dim4Element][dim5Element]
So I wasn't too far off from what I was looking for. That is a good sign.
I suppose I could just redefine the wiped element with interpolated
vectors...or something...should I need to, by using the above macros
functionally mirror image.
As a side note, why in the nine hells aren't there Round and VRound macros
in pov to start with??
They seem kind of useful to just have been left out...then again...so do
structs, enums, custom types, multi-datatype arrays, type casting, type
conversion and list<T>'s...
More of a side note....it would be cool to create a set of macros which
emulated basic circuit components, so that one could produce such an act of
irony as a properly functioning raytraced circuit...
Hmm....to make a macro which can produce accurate semiconductor curves....
Gah! I need to finish this damn macro suite...no new projects! :-p
ian
Date: 25 Mar 2009 14:50:01
Message: <web.49ca7cb69fb46029219167190@news.povray.org>
I suspected it probably wasn't Acorn BASIC. The interpreter didn't worry about
LETs, and didn't say Ready at every prompt. Definitely a contemporary though!
Good job.
Whoops, this is veering a little off-topic now... :)
Date: 25 Mar 2009 15:40:00
Message: <web.49ca88269fb46029c1f399840@news.povray.org>
> things.
If I wasn't working on various other pieces of POV code, that's what I'd
probably be doing right now...
(Note however that "in the language that pov was written" would mean C until
only very recently, so nowhere close to dynamic lists whatsoever; and structs,
although C does have them, would have to be represented internally using
"arrays of members" as it were, because C can't create new structs at runtime.)
Yargh! Vade! >_<
Again, too much OO thinking for POV SDL. You can't store separate things in the
multiple dimensions of such an array anyway; and if one of your "subsections"
would need more elements, you'd need to add more elements to the other
"subsections" as well... not too bright.
But what you might want to do is:
#declare POINT  = 0;
#declare COUNT  = 1;
#declare RANDOM = 2;
#declare Array[i][POINT]  = <...>;
#declare Array[i][COUNT]  = <0,0,0>;
#declare Array[i][RANDOM] = <0,RRand(RsA, rMin, rMax),0>;
(That's basically how struct support would have to be implemented in POV
internally - except that we'd need to be able to store different things in the
array elements)
or maybe
#macro GET_POINT(a,i)
  Array[i][0]
#macro GET_COUNT(a,i)
  Array[i][1].x
#macro GET_RANDOM(a,i)
  Array[i][2].y
You can round using "int(x+0.5)", so no problem writing your own macros...
Yes, maybe the standard include files could use an overhaul, too.
.... and a new SDL grammar, as we're on it.
For the job we're doing, octrees would come in handy, too.
I think one of the greatest current limitations is the inability of arrays to
store elements of different types. Otherwise, structs could easily be simulated
by using identifiers holding constants, e.g.
#declare FIELD_FOO = 0
#declare FIELD_BAR = 1
#declare MyArray[FIELD_FOO] = <0,0,0>;
#declare MyArray[FIELD_BAR] = pigment { ... };
which still wouldn't be ideal, but still quite an improvement.
Date: 25 Mar 2009 16:57:23
Message: <49ca9ab3$1@news.povray.org>
news:web.49ca88269fb46029c1f399840@news.povray.org...
> until
> structs,
> runtime.)
I had a feeling it was C still; long ago I looked at the source when
considering adding new media scattering methods...then quickly abandoned
that idea when I discovered how much work would actually be involved with
the implementation of a new (to pov) algo.. :-|
> Yargh! Vade! >_<
Hmm? Sounds like something a norseman might shout just after boarding your
vessel and just before doing something awful with a large blade. ;-)
OO is the crack of programming. :-)
> You can't store separate things in the multiple dimensions of such an
All of the dim1 elements will have the same attributes, so in this case it
isn't really an issue, as they are just flags really. I do wish I could
store multiple datatypes though, as using vectors when all you want is a
flag is somewhat like the programming equivalent of a nasty hacked up
hairball; ugly, gross and not something you like having to deal with.
> #declare POINT  = 0;
> #declare COUNT  = 1;
So using different placed in dim2 would be better than having related vector
flags grouped in their own dimension?
It seems to me that it could become confusing and require code rewrites (for
grouping of like flags/misc) if one uses only 2d when thy might have a set
of flags in d2 for say, branching, child nodes, etc.. and more for
interpolated vectors or the like. It also seems that using those additional
attributes could become messy if they are just all over the place.
> the
> array elements)
I'd say step one would be to implement vector and integer/double/long
support in the same array, see what that took to do, and then fan out from
there.
> or maybe
>  Array[i][0]
> #end
>  Array[i][1].x
> #end
>  Array[i][2].y
> #end
I like that better, seems easier to use and keep track of. I still like the
idea of using multiple dimensions for related flags for my specific purpose,
as I won't have many categories. It isn't so much that it really matters, so
long as whatever method used works and does so quickly. Even so, for general
extensibility, get/set macros for the win. I'll need to try both using
stupid amounts of elements, and then compare the stats.
True, but sometimes you just want to use a thing, without having to go find
math.h to write your own.
There are a lot of little things like that in pov.
Agreed. Especially the textures, a lot of them kinda suck...like the
metals...and glasses...
I'd like to see a nice influx of textures created by the community. Waters,
glasses, metals, stones....there are so very many great ones I've seen used
here.
A lot of the more esoteric macros in povray need example files too.
Maybe once I get my macro suite to a good place, I could get the snowball
rolling on this..assuming they would actually use any files I created.
Probably if they would, I'd not be alone in wanting to do this.
Yes. My vote is cast with using more common C-ish things, as those who
program will quickly adapt, and those who don't will spend the same amount
of time learning as before, but will also be familiar with java/c#/c++ ish
languages without even knowing it. Good for everyone.
And hash tables(with a good many hashing methods), and heaps(with a lot of
heap types), and a proof of the riemann hypothesis, and and and ;-D
> to
> simulated
Indeed. I'd take any improvement at this point.
Any idea why they never did that?
*sigh* I might just have to track down the file(s) where they coded those
things and have a look...maybe it won't be the massive PITA that I get the
feeling it is...
ian
Subject: [OT] Nostalgia / Was: Re: remove array element after N uses?
Date: 25 Mar 2009 17:33:41
Message: <49caa335$1@news.povray.org>
Hash: SHA1
>> were a beeb
	Guess what? Somebody did a benchmark of an old 1986 Mac against a
dual core AMD64. And the winner is..... the 1986 Mac! By 9 tests to
8 (including a whopping six times faster boot sequence):
http://hubpages.com/hub/_86_Mac_Plus_Vs_07_AMD_DualCore_You_Wont_Believe_Who_Wins
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAknKozQACgkQd0kWM4JG3k8TCQCfQHSlH7oHl0sxvs/mLynEImeQ
dXUAnjCt3GBfJpePz2ACWYQUoTTHNuQJ
=79sN
-----END PGP SIGNATURE-----
Date: 25 Mar 2009 19:05:01
Message: <web.49cab78d9fb46029c1f399840@news.povray.org>
There are still some areas where the code is quite C-ish, and a few C-ish data
types are still waiting to be "classified", but the coding style has changed
quite dramatically. It now resembles software, not a hack ;P
(Speaking of it - ever seen the NetHack source code? *That* is something to
drive every OO-enthusiast mad... >_<)
> > Yargh! Vade! >_<
Well, I was thinking more of the latin "Vade Satanis!" :P
> > #declare POINT  = 0;
> > #declare COUNT  = 1;
Yeah, because it doesn't waste so much space. See, your approach used N*2*2
array entries - so far! This one only uses N*3 entries. Saves you N entries in
this case. Depending on how many groups you have, and how much they differ in
size, this can quickly get a lot more. E.g., if one group only had a single
entry while another had 8, you'd waste N*7 entries.
You cannot avoid *some* kind of mess with POV's SDL.
Most of them date back to the pre-Radiosity era; that's why they have ambient in
them, and that's why they do suck indeed.
> here.
I guess the POV team would agree. The major problem is that although the POV
community is obviously alive and kicking, nobody seems to see that here's where
they could help the dev team quite a lot.
People possibly don't get involved because they think developing POV 3.7 is all
about C++ programming. Well, it is not: POV 3.7 will need various updates to
the documentation. POV 3.7 would greatly benefit from a major overhaul of the
include files. And so on. Someone just needs to take the lead, team up with
others here to get those things done, and in the end lay the results in front
of the dev team to get it all approved. All the while the dev team can
concentrate on C++ coding.
I took the step from a normal POV user to a code contributor because I wanted
both symmetric multiprocessing *and* radiosity, which wasn't available end of
last year.
If you want better textures, why not take a step forward, too, and become a
contributor of texture include files? You don't even need to do all on your
own. Beg, steal or borrow whatever you think should be part of a "POV starter
pack". Or hack up some macros you think every POV user should have at their
disposal - you seem to be darn good at it, except for some lack of experience
(but really making up for it by a strong will to experiment, and actually
benefiting from that lack by looking at things from a different and fresh
perspective).
You know, becoming a contributor to the POV package is not difficult: Just pick
a thing you *want* improved and think you *could* improve if given the chance -
then step forward here in the newsgroups, making clear that you would like to
have a go at it, and I'm quite sure you will *get* that chance.
Do so. And expect them to do appreciate your contributions.
Yeah, that would (roughly) be the direction I'd suggest, too. I guess there's no
"syntax family" as big as the "C-alikes", ranging from C over C++, Java, C# to
JavaScript (so web designers should be familiar with it as well) or even some
unix shells.
However, for some statements I would take a radically different approach. For
instance, although I'm perfectly accustomed to it, I never got to really like
the C-style 'for' loops. For my taste, "for" loops should always iterate
linearly (99% of all C 'for' loops do anyway); and there should be a "foreach"
loop to iterate over data containers.
I don't care about the riemann hypothesis, and I don't think we need dedicated
heaps, but hash tables might be useful at times ;)
But I really wasn't kidding: As we're dealing with objects in 3D space, I think
really the most "natural" data structures for a lot of problems would indeed be
spatial subdivision trees, and octrees would probably the most widely applicable
of those.
Yes: C.
You don't think about such stuff as long as you're coding straightforward
classic C. In that language, you don't mix data types. Real C programmers just
don't think OO. It's almost a break of style that there is a generic object{}
statement.
Fortunately, the dev team doesn't have any real C programmers among their ranks
anymore (as far as I know); the internals are getting migrated to C++; and it's
probably about time for the SDL to head for OO, too.
Date: 25 Mar 2009 22:39:32
Message: <49caeae4$1@news.povray.org>
news:web.49cab78d9fb46029c1f399840@news.povray.org...
> data
> changed
> to
I'll have to check NetHack out. Yup last time I looked at the POV source I
think it was looking back; kinda like when you leave something in the fridge
too long and it grows a 'fro, and you aren't so sure who is about to throw
who away. ;-p
Gotcha! ;-D
Yeah some code looks more like Inno A Satana than much else. ;-p
> N*2*2
> entries in
> in
> single
They would all have the same number of entries; but you do make a valid
point. The way I was doing it isn't very efficient.
> ambient in
I think the metals include file will be my first project. I have some of my
own that I'll start out with, as well as improving the old ones. I think
I'll put a section on my website for this, showing previews (rad/norad) and
code. I may create some facility to allow users to upload code, or I may
just do a call to arms in the newsgroup. I have a VAST archive of povray
files, and some have some killer metals in them. I guess I'll need to track
people down and get permission for things..
> POV
> where
Almost nobody. ;-)
> is all
> to
> the
> with
> front
Yup, there are spelling errors that I have seen in the docs. I think my main
focus will be textures and later demo files for esoteric
functions/macros.I'll probably include a standard set of macros that people
seem to use a lot, but aren't included. Perhaps I'll write an insert menu
addon for them.
My concern is future changes in 3.7; it would be a shame to get this all
polished and then have it break in RC1 or some such.
> wanted
> of
> last year.
> a
> your
> starter
> their
> experience
> perspective).
While I doubt stealing would be appreciated by the community, I can always
make my own versions of anything that I can't get permission for. ;-D
I think that I will host some of this stuff on my site, so that people can
view and give feedback/improve/debug. Setting that up will take a bit, I
will probably not have usernames/logins just yet, but if I choose to allow
others to upload content, I'm sure as hell going to screen applicants. I
don't need any security issues...or jagoffs uploading pr0n...
> pick
> chance -
> to
Sounds like a capital idea, and a reasonable task which can be completed in
a reasonable time given the scope I wish to attack.
I've been using this program for more years than I'd like to admit to, given
my current skill level...but it's time for me to give something back. ;-D
> there's no
> C# to
> some
> unix shells.
Exactly, I can't see any possible disadvantage to this as of yet.
> For
> like
> "foreach"
I do like my foreach. Actually, I like all the loop types available. There
is always that one time when you need the weird one.
> dedicated
hehe...yeah all pov needs after all that is a windowing framework and we can
start cranking out apps in SDL. ;-p
> think
> indeed be
> applicable
> of those.
I think you are right, as many of the other types are only good in very
specific circumstances, and can be weird to implement.
> Yes: C.
D'oh!
> just
> object{}
> statement.
> ranks
> it's
*does a little dance*
w00t! :-D
ian
Subject: Re: [OT] Nostalgia / Was: Re: remove array element after N uses?
Date: 26 Mar 2009 03:48:01
Message: <49cb3330@news.povray.org>
  How is that comparing a Macintosh with an AMD64? That's comparing the old
MacOS with Windows.
  It is possible to set up a PC so that it uses coreboot and a architecture-
customized lightweight linux distro. You can get from power-on to the end of
the boot sequence in something like 2 or 3 seconds.
Date: 26 Mar 2009 14:23:16
Message: <49cbc814$1@news.povray.org>
Hash: SHA1
> MacOS with Windows.
	It's comparing a "standard" computer of 1986 and a "standard"
computer of today for "standard" tasks (i.e Word and Excel which is
what most users actually do when they work on their computers).
	Of course, and it is also possible to set up this same computer
with an optimized embedded OS that will be even faster and similar
things were already possible back in '86. But then you're comparing
apples and oranges. The point was to compare typical office use of
computers in '86 and today. And the result is that the '86 computer
was at least as fast as today's.
		Jerome
iEYEARECAAYFAknLyBQACgkQd0kWM4JG3k9v8QCfSJ5/QDkgXD/XfEa1iCT0um/5
KsgAoIrpcD1AAWOAGchj891v3xwILHa0
=mjzx
Date: 26 Mar 2009 14:40:53
Message: <49cbcc35@news.povray.org>
  Does "typical office use" include things like opening and editing
a 1600x1200 full color image for a powerpoint presentation?
  I'd like to see you doing that with the old Mac. ;)
