A quick note about something I just discovered...
When using two-pass radiosity, if you use a little focal blur during the
first pass (just a few blur samples is enough), the you can scale up the
render size on the second pass without suffering the typical artefacts (and
you don't need to use focal blur on the final pass).
I've used this trick successfully with the first pass at 320x240 and the
second at 1024x768. So, for the first pass I'm now using that in the camera:
aperture .01 blur_samples 7 focal_point <,,>
Jaime
Would jitter do the same? It seems focal blur is:
1. relatively expensive
2. introduces an artifact, as it's depth-dependent
> (and you don't need to use focal blur on the final pass).
> the second at 1024x768. So, for the first pass I'm now using that in the
> camera:
> Regards,
> Jaime
Dan Connelly nous illumina en ce 2009-01-09 13:45 -->
>> the
>> the camera:
>> Regards,
>> Jaime
With this little samples, it's not realy expensive. Also, the sampling is
normaly jittered.
What it does here, is to force the taking of some more radiosity samples during
the first pass.
You know you've been raytracing too long when you've gained twenty pounds
sitting at the computer, but can't tell because your beard covers your stomach.
Taps a.k.a. Tapio Vocadlo
> is normaly jittered.
> during the first pass.
Is the depth dependence a concern? At the focal depth, there should be no effect.
Subject: Re: Scale radiosity data with focal blur
Date: 9 Jan 2009 17:18:43
Message: <4967cd43@news.povray.org>
>> samples during the first pass.
> no effect.
Now that you mention it, I was using a focal point very close to the
camera location, so the focal blur effect must have been more or less
uniform, I suppose.
Jaime
> Regards,
> Jaime
Always a man of many tricks! :)
good to see you're back at povving!
- Did you see any speed (or quality) advantage over using a higher-resolution
image?
- How does Anti-Aliasing with jitter perform in comparison?
Date: 10 Jan 2009 10:54:55
Message: <4968c4cf$1@news.povray.org>
> higher-resolution image?
The advantage is only speed, and the quality is almost the same. I just
did 3 quick tests with the same rad settings:
1) 1024x768 for both passes as reference for quality and render time
2) first pass of only 256x192, second 1024x768 -> 38% render time, but
there are many artefacts not present on case 1.
3) same as 2, but with focal blur (7 samples) -> 65% render time, no
artefacts visible, and the image feels almost identical to case 1.
It works also to obtain better results for "scaled up radiosity", but
doesn't eliminates all the artefacts as the focal blur trick does. And
increasing the aa depth, the results were not much better, even with render
times bigger than with focal blur.
Jaime
What type of artifacts are we talking about? Black splotches? Generic "dirty"
look? Or the horizontally-smeared artifacts typical for samples gathered during
final trace?
If we're talking about the latter, then those are very strange results; maybe
there's a secret hidden in this approach that might help design a faster
pretrace algorithm.
Does changing the focal blur aperture have an effect on this?
Date: 10 Jan 2009 12:24:14
Message: <4968d9be@news.povray.org>
> "dirty" look? Or the horizontally-smeared artifacts typical for samples
> gathered during final trace?
Look at the images I just posted on p.b.i. (just forget about the ugly
compression) : the number on the file names reflect the cases I listed. Look
at the second image and you will see artefacts on the edges between
surfaces. These can be worse in "real" scenes with finer radiosity settings,
appearing as horizontal lines on the shadows.
> maybe there's a secret hidden in this approach that might help design a
> faster pretrace algorithm.
Hmmm... didn't try this, I just assumed that aperture didn't matter. Will
try it later...
Jaime
We're actually talking about two different effects here:
(1) The classic samples-taken-during-final-render artifacts, which are those you
describe as "appearing as horizontal lines on the shadows".
(2) The wrongly-colored edges seen in your second image, causing shadows or
highlights right at the edges; so far, I actually have no clear idea where they
come from, and it seems to me they're not necessarily related to an insufficient
pretrace. I currently suspect "crosstalk" between the two adjacent surfaces
meeting at the edge but haven't made much progress in eliminating them, so it's
an interesting thing for me to see that the focal blur seems to kill them very
effectively.
Maybe it's all about the strict sampling pattern of left-to-right and
top-to-bottom, which might cause edges to be "dominated" by the top and left
surfaces. As a bit of "crosstalk" cannot be avoided, this might lead to the bad
edge shading observed. Breaking up this strict pattern, as focal blur does,
might result in a better balance between the surfaces.
