POV-Ray : Newsgroups : povray.general : sun/earth/moon/day/night Server Time
11 Oct 2026 15:40:48 EDT (-0400)
  sun/earth/moon/day/night (Message 1 to 31 of 31)
Subject: sun/earth/moon/day/night
Date: 6 Jan 2009 04:42:29
Message: <49632785@news.povray.org>
Hello all,
First of all, my best wishes to all of you. And to the developers of
PovRay: keep up the good work; we're all grateful for the job you're doing.
My 5-year old son is very interested and intrigued by the interplay of
the sun/earth/moon and how this creates day, night, seasons, ... Also
the mechanism of a solar and lunar eclipse (who is casting a shadown on
who) has caught his attention.
Since I lack a mechanical model of this three body system (I remember we
had this in our geography classroom when I was in secondary school: you
could turn a handle and then by means of gears the bodies would rotate
and move), I was planning to do some animations with PovRay.
I don't want to re-invent the wheel, hence my question: is there anybody
here who has done something similar with PovRay? I would like to end up
with a small number of input files (or a single one) for which the clock
variable would both make the bodies rotate and move the camera to show
the different aspects (night/day, eclipse,...). Do you know of a site or
reference work where I could get approximate data (good enough for this
purpose of an educational animation) for the astronomy data?
Thanks for your tips!
bye,
gert
Subject: Re: sun/earth/moon/day/night
Date: 6 Jan 2009 08:33:20
Message: <49635da0$1@news.povray.org>
You might want to try Celestia, a real-time planetarium program.
Certainly, you can do the same things in POV-Ray, but there are several
caveats:
1) POV-Ray is not a real-time program. You can't preview changes or
interact with the scene in real-time. The best you can do is render
individual frames to create a movie--which can be a time consuming
process, and you'll have to start the process over from the beginning
each time you make a mistake.
2) POV-Ray can suffer from floating point/rounding errors when the
objects get too large and/or too distant.
3) POV-Ray takes a long time to master, in general; and creating scenes
is usually a laborious process.
You could also try GeoGebra, which is a real-time dynamic geometry
software. You could create representations of the planets as well as the
shadows they cast on other bodies using geometric objects. This program
is limited, however, to two dimensions.
Hope that helps.
-Mike
gvdeynde wrote:
> Hello all,
> bye,
> gert
Date: 7 Jan 2009 03:51:15
Message: <49646d03$1@news.povray.org>
Hi Mike,
Thanks for the info. I've tried Celestia but thought it might be too
complex for my son.
Concerning PovRay: I have some experience already (I'm playing with it
since version 2 or so, have modeled our house in it, did some artwork
for some websites I made, etc). So I think I can come up with something,
I was just wondering if somebody already did something close to this and
I could work further based on that...
I'll have a look at Geogebra...
thanks again,
gert
> caveats:
> Hope that helps.
> -Mike
> gvdeynde wrote:
>> Hello all,
>> doing.
>> on who) has caught his attention.
>> we had this in our geography classroom when I was in secondary school:
>> you could turn a handle and then by means of gears the bodies would
>> rotate and move), I was planning to do some animations with PovRay.
>> anybody here who has done something similar with PovRay? I would like
>> to end up with a small number of input files (or a single one) for
>> which the clock variable would both make the bodies rotate and move
>> the camera to show the different aspects (night/day, eclipse,...). Do
>> you know of a site or reference work where I could get approximate
>> data (good enough for this purpose of an educational animation) for
>> the astronomy data?
>> bye,
>> gert
Date: 7 Jan 2009 11:39:07
Message: <4964daab$1@news.povray.org>
This may not help much, but here goes...
I wanted to do something similar but not for the Earth/Moon/Sun system.
  It was for a science fiction story I was working on that takes place
on a planet that orbits a star 20 lightyears away.  This is actually a
binary planet where two approximately equal mass planets orbit each
other (or around the center of mass of the two planets) and both orbit
the star.  The two planets are tidally locked to each other.  I wanted
to discover the dynamics of this world.
I wrote a simple model in POVRay and created an animation that captured
one frame per hour for one year (143 Earth days) and clearly showed the
geometry and timing of eclipses.
Notes:
	- as was mentioned, you have to be careful about scale
	- I didn't try modeling the elliptical nature of orbits - all orbits
are simple circles
	- since I'm creating the world as a work of fiction, I have some  room
to adjust the parameters to my suiting.
I can make this model available to you if you wish.  It could be
adjusted to give an "impression" of the Earth/Moon system but couldn't
be used to give accurate predictions of eclipses, etc.
David Buck
gvdeynde wrote:
> Hi Mike,
> complex for my son.
> thanks again,
> gert
>> several caveats:
>> scenes is usually a laborious process.
>> the shadows they cast on other bodies using geometric objects. This
>> program is limited, however, to two dimensions.
>> Hope that helps.
>> -Mike
>> gvdeynde wrote:
>>> Hello all,
>>> doing.
>>> of the sun/earth/moon and how this creates day, night, seasons, ...
>>> Also the mechanism of a solar and lunar eclipse (who is casting a
>>> shadown on who) has caught his attention.
>>> school: you could turn a handle and then by means of gears the bodies
>>> would rotate and move), I was planning to do some animations with
>>> PovRay.
>>> the astronomy data?
>>> bye,
>>> gert
Date: 7 Jan 2009 14:30:01
Message: <web.496501f14590b7f0e6fcd2f30@news.povray.org>
Out of curiosity: Would such a system actually be stable in reality?
Date: 7 Jan 2009 15:12:41
Message: <49650cb9$1@news.povray.org>
Hash: SHA1
	It is: look at the Pluto-Charo pair of planets (planetoids?) in the
solar system.
		Jerome
PS: Of course, Pluto and Charo aren't 20 ligth-years away from their
sun, but that's probably just me being obtuse ;)
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkllDOYACgkQd0kWM4JG3k+h4gCeK/oOHu0ymwsNP/Bjacmu13NX
iw8AoLfXyZz3X0QgX63JRYE/ur9n8tYp
=jlwG
-----END PGP SIGNATURE-----
Date: 7 Jan 2009 16:53:33
Message: <h29am4ps1fochf1is8l69ck6dhvaeooms4@4ax.com>
Hi Gert,
Out of interest I started to model an Earth Moon Sun system in a modeller and
quickly found that it not really easy to see what is happening when you use
proper scaling. For a five year old I assume that a non realistic model would
do.
Using a modeller you can show how the moon moves round the earth before
rendering. The modeller I used is Bishop3D and as it is in Beta it is free
http://www.bishop3d.com/
http://uk.youtube.com/watch?v=wsh6l7KpMEg
OK I know that the Earth should be moving but it is just a demonstration of a
shadow :)
Regards
Date: 7 Jan 2009 17:57:37
Message: <49653361$1@news.povray.org>
You need to have the two planets separated more than the Roche Limit
otherwise the tidal forces will tear them apart.  In this case, they are
about 10x the Roche Limit.  Within that range, it should be fine over
long periods of time (billions of years) but I haven't done the
simulations to verify that.
David Buck
Date: 7 Jan 2009 18:02:33
Message: <49653489$1@news.povray.org>
Jérôme M. Berger nous illumina en ce 2009-01-07 15:13 -->
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> solar system.
> 		Jerome
It's 20 lightyears away from HERE.
A planet orbiting it's sun at a 20 lightyears radius would need to have an
extra-galactic sun, or get snatched away by nearby stars. Such a planet would
also be frozen solid, with, maybe, sone seas of liguid hydrogen and helium. It's
"year" would last several 100's of millenias.
You know you've been raytracing too long when your source files are starting to
get bigger than the image files.
     -- Matt
Date: 7 Jan 2009 18:48:09
Message: <49653f39$1@news.povray.org>
> David Buck
Based on my undergraduate level physics education, I would say the other stability
limit is that the separation of the two planets should be substantially less than the
separation of the center of mass from the star.
Stability issues primarily occur with 3-body systems: they have a habit of ejecting
one of their members.  So as long as the system is a 2-body system, where one of these
bodies is itself a 2-body system, you're okay.
Dan
Date: 7 Jan 2009 22:49:25
Message: <496577c5$1@news.povray.org>
>> Hash: SHA1
>> solar system.
>>         Jerome
> an extra-galactic sun, or get snatched away by nearby stars. Such a
> planet would also be frozen solid, with, maybe, sone seas of liguid
> hydrogen and helium. It's "year" would last several 100's of millenias.
Um, yea :-).
The star (Delta Pavonis) is about 20 lightyears from our Sun.  I don't
think a planet could orbit a star at a distance of 20 light years.  The
planets orbit their sun at a distance of 93.5 million km and the two
planets are about 47,000 km apart from each other and rotating 19.7
degrees off the ecliptic.  The Roche Limit is about 5900 km so they
won't tear each other apart.   The binary planets have a 33.6 hour day
and a year of 182 Earth days or 130 planet days.  Acceleration due to
gravity is 7.2 m/s^2 (compared to 9.8 m/s^2 on Earth).  If you're on one
planet, the other appears fixed permanently in the sky and is just over
13.6 times the size of the Earth's moon in the sky. Every year, there
are two periods (one in the spring and one in the fall) when the two
planets eclipse each other for several days in a row.
(Ok, I'm a geek :-)  )
Back to the IRTC software.
David Buck
Date: 7 Jan 2009 23:40:21
Message: <496583b5$1@news.povray.org>
David Buck wrote:
> Um, yea :-).
v^2/r = Mg/r^2 relates orbital speed to distance and solar mass.  v = 2 pi r / tau,
where tau is the orbital period, so 4 pi^2 r / tau^2 = M g / r^2 =>
tau = 2 pi * sqrt(r^3 / M g)
The Earth's orbital radius is 1.58e-5 light years.  20 light years is a factor 1.26e6
larger.  For comparable solar mass, this would yield an orbital period of 1.4 billion
years.  The age of the universe is 13.7 billion years.  So classically there's been
time for at least a few such orbits...
The problem is there could be no massive objects of comparable mass to the star within
the neighborhood defined by the length scale of the orbital radius, for example within
100 light years, or the orbit wouldn't be stable.
Dan
Date: 8 Jan 2009 02:35:00
Message: <web.4965ab7d4590b7f0ef2b9ba40@news.povray.org>
gvdeynde <gvd### [at] gmailcom> wrote:Do you know of a site or
It's good for a lot more than rough approximations, but to the best of my
knowledge, ephemeris data is the definitive source:
http://eclipse.gsfc.nasa.gov/TYPE/TYPE.html
You might try searching for interactive simulations too.  I know I've seen
models you can fly around in before, but I can't remember the name.
 - Ricky
Date: 8 Jan 2009 03:36:05
Message: <4965baf5$1@news.povray.org>
Hi all,
Thanks to all for your input.
David, yes, if you don't mind, I would like to have a look at your code.
Stephen, great simulation. Any chance of sending me the Bishop3d
file/PovRay file?
all the best,
gert
Date: 8 Jan 2009 04:50:49
Message: <d3jbm45o5a33nf25bk9o76g7pshi5g6ni5@4ax.com>
>file/PovRay file?
I'll just have to cut down the sizes of the image maps, they total about 6 megs.
The Bishop3D file is only 2K, zipped.
Regards
Date: 8 Jan 2009 06:07:55
Message: <4965de8b$1@news.povray.org>
gvdeynde wrote:
> Hi all,
> file/PovRay file?
> all the best,
> gert
See the article "Delta Pavonis Celestial Mechanics" in
povray.binaries.scene-files.
David Buck
Date: 8 Jan 2009 13:43:01
Message: <49664935$1@news.povray.org>
Hash: SHA1
>> Hash: SHA1
>> solar system.
>>         Jerome
	I know that's what he *meant*, hence the smiley and the second part
of my sentence, but that's not what he *wrote*...
		Jerome
iEYEARECAAYFAklmSV8ACgkQd0kWM4JG3k+oQwCffhmUrj6YW5Zvyuhztieje8gP
38MAoKW/fOR8ZAqPEge1mAvg+FtdxMpu
=XWeF
Date: 8 Jan 2009 15:05:46
Message: <1umcm4do305ocdrajcc7qqhck5psblk4r8@4ax.com>
>>file/PovRay file?
Bishop3D file
http://www.geocities.com/mcavoys/Bishop3D/Earth02K_4.zip
Image maps for B3D file.
http://www.geocities.com/mcavoys/Bishop3D/Maps.zip
If you unzip both files into the same directory and add that directory to the
PovRay library path it should work (I tested them) Any problems just ask either
here of at the Bishop3D forums
Regards
Date: 8 Jan 2009 19:58:29
Message: <4966a135$1@news.povray.org>
Stephen nous illumina en ce 2009-01-08 15:05 -->
>>> file/PovRay file?
> Bishop3D file
Just unzip in a sub-folder of the POV scene folder. No need to add any new path
this way.
You know you've been raytracing too long when you have ever brought your
computer to its knees by mistakenly launching 64 simultaneous frames to be
traced, while trying to maximizing the benefits of parallelizing them.
Carsten Whimster
Date: 11 Jan 2009 10:39:43
Message: <c5ep36-70a.ln1@badulaque.unex.es>
Among other things, triple_r saw fit to write:
Slightly off topic...
Has anyone seen a picture (ideally a photograph) of how a lunar eclipse
looks from the Moon (from there, it would be a solar eclipse). In total
lunar eclipses the Moon usually gets a reddish tint, apparently from
sunset-like light all around the Earth (as seen from the Moon), I'd like to
see this.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 11 Jan 2009 11:41:54
Message: <496a2152$1@news.povray.org>
I think the last camera on the moon itself was actually
with Lunochod 2 spending 5 months there in 1973, and the
images doesn't seem to be easily available (not sure if
they even had color).
So any photo would probably be taken from orbit by more
recent missions such as SMART-1, Kaguya or Chang'e-1. Being
solar powered and all that they may well have been in power
saving mode during lunar eclipes though ;)
By the way, googling for Lunochod, I arrived
at the following russian moon page:
   http://selena.sai.msu.ru/Home/Moon.htm
It contains an animation which looks distinctly POV-ish ;)
   http://selena.sai.msu.ru/Home/svechka.gif
Date: 11 Jan 2009 15:20:01
Message: <web.496a54474590b7f03dcb84c80@news.povray.org>
> see this.
I doubt whether a photograph of such an event exists:
- To date, manned missions to the moon (i.e. Apollo 8 and 10-17) have never been
carried out during lunar eclipses, and to all my knowledge, traversal of earth
shadow during Apollo missions has only occurred in earth orbit; other manned
missions have never even come close to similar distances from earth.
- To date, only very few sattelites have carried photographic film cameras
onboard, and those that did probably never left earth orbit (problem of
retrieval of the exposed film material).
- Satellites leaving earth orbit often had much farther destinations, requiring
trajectories optimized for efficiency, with not much room for the beauty of
lunar eclipses.
- Although some satellites have been deliberately "parked" on the "shadow" side
of earth at the so-called "Lagrangian Point 2" (one of 5 points at which
satellitest can be kept at a stable position relative to earth and sun with
very little effort), this point is at five times the distance of the moon. As
it happens, this is about the distance at which the sun starts to appear bigger
than the earth, probably spoiling the whole effect.
- As for any satellites that might have more or less "accidentally" happened to
cross the earth's shadow at a fitting distance, pointing any optical cameras
towards earth (and sun) during that time would have posed the danger of failing
to turn them away again in time, putting the equipment at high risk of damage.
So probably the only thing we can do to enjoy the beauty of such a sight is to
do what we're best at anyway: Fire up our imagination and inventiveness, and
then fire up POV-Ray.
(BTW, If done right, I guess this could make a tremendous scene for that
planetarium showreel project...)
Date: 12 Jan 2009 03:58:49
Message: <496b0649$1@news.povray.org>
"Jellby" <me### [at] privacynet> schreef in bericht
news:c5e### [at] badulaqueunexes...
> to
> see this.
There is a subject for an awesome POV-Ray scene.... As said already by
others, I don't think there are any photographs available.
Who takes up the gauntlet?  :-)
Date: 12 Jan 2009 05:45:00
Message: <web.496b1d304590b7f02c9ab000@news.povray.org>
I would if I had the time these days: That earth model I used in the "Not!" shot
still needs a bit of polish anyway, improving the atmosphere colors,
realistically modelling the IOR gradient and all.
My fingers are itching like hell to jump on this, actually. If I wasn't working
on radiosity code these days, that's what I'd spend the nights on: Lunar
eclipse as seen from the moon... astronauts and all included! Digging up that
half-finished Apollo spacesuit model again, polishing up the finished Apollo
Lunar Module... ah, what better setting to revive the heroes of my childhood!
Vade! Tempt me not, if you want the radiosity code to come to completion any
time soon...!
(... Man, you're lucky that realistic lunar scenes *need* radiosity, with all
that indirect light reflecting from the moon's surface...)
Date: 12 Jan 2009 07:58:06
Message: <496b3e5e$1@news.povray.org>
"clipka" <nomail@nomail> schreef in bericht
news:web.496b1d304590b7f02c9ab000@news.povray.org...
> "Not!" shot
> working
> that
> Apollo
> childhood!
> any
> time soon...!
> all
[Satanas retreats a few steps, grinning]
Well, there is an incentive for you... :-)
Date: 12 Jan 2009 12:52:22
Message: <496b8356@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:496b0649$1@news.povray.org...
>> see this.
> There is a subject for an awesome POV-Ray scene.... As said already by others,
Actually, Surveyor II took a picture of a solar eclipse from the moon.
Images were retrieved by Apollo 12 crew who also snapped a nice picture
in space (not on the moon's surface).
There is a page with good math data at
http://star-www.st-and.ac.uk/~awc/eclipse.html
(part 2).
Theory says the earth will be quite a sight as earthshine will center an
image of a planet surrounded by all the world's sunsets at the same time.
Date: 12 Jan 2009 15:20:00
Message: <web.496ba5cc4590b7f02f89246d0@news.povray.org>
Hum - I forgot about the Surveyor probe indeed (it was Surveyor 3 though, not
2). That would have been a chance to get some nice shots of a "lunar solar
eclipse".
Unfortunately, you are a bit misinformed: Apollo 12 did not retrieve any
photographic images from the probe, neither did the probe carry any
photographic camera in the first place. It had been sitting around on lunar
soil for three years already, and when it had been built, probably nobody had
expected a manned mission to land anywhere close. So all the Apollo 12 crew
took home was some parts of the probe, probably to examine some problems
experienced (including the TV camera) and learn some lessons from it.
The eclipse shot from Surveyor 3 is actually a very bad black-and-white shot,
that had been transmitted years earlier already, and - as the beautiful Apollo
12 shot indicates - does the event no justice whatsoever.
The Apollo 12 shot, on the other hand, was taken comparatively close to earth,
so it, too, can only hint at how it might look in reality from the moon.
Date: 13 Jan 2009 20:04:37
Message: <496d3a25$1@news.povray.org>
[sorry! 1st emailed instead of reply here. Out of practice using
newsgroups.]
I had made a few attempts to show the solar system or parts of it in POV-Ray
over the years. As I read others saying here, scale modeling and getting
the view right can be trouble... for me anyhow.
When I first read your post last week I was going to look for what I might
have done before but decided to start fresh again. Idea this time being to
create an "orrery" of various scales fit together into one scene file. Not
sure I succeeded but I'm posting it anyway at povray.binaries.scene-files,
less the image maps since you could easily replace them with textures or
images found online. Low resolutions okay and faster to render, I down-sized
mine to 720X360 from hi-res ones I already had.
(example: earth-map.jpg, jupiter-map.jpg)
While going to post this I saw David Buck's fictional scene at p.b.s-f. I
realize now my try at it might seem confusing at first, too. heh-heh-heh.
:^)  Since the topic of atmosphere during eclipses was brought up as I
returned to read here while refining the orrery I tried adding that without
success. Poorly done so ignoring that part might be best-- unless someone
wants to fix it.
I can't be certain I got all the elements of the orbits right, I fumbled
with the sizes and angles until it looked like the animations kept the
correct orbital inclinations; and all along writing the file out in such a
way that made sense to me yet not sure it will to everyone else. No doubt
better methods or implementations exist than what I chose.
Again, it's being posted at povray.binaries.scene-files, under the name
"solar system orrery ver1", since the text line-wrap would be a disaster if
posted here.
Date: 17 Jan 2009 03:39:36
Message: <bi7746-8s4.ln1@badulaque.unex.es>
Among other things, clipka saw fit to write:
> working on radiosity code these days, that's what I'd spend the nights on:
> Lunar eclipse as seen from the moon... astronauts and all included!
> Digging up that half-finished Apollo spacesuit model again, polishing up
> the finished Apollo Lunar Module... ah, what better setting to revive the
I've been wondering about this lunar-eclipse-from-the-moon image for some
years, so I'm looking forward to whatever you can get :)
P.S. I'm also glad this raised some interest. Another thing I've been
thinking about for years is how cool a "bird flight simulator" would be.
Think of it, instead of controlling a plane you'd control a bird, the wing
flapping frequency, the tail... there would be different kinds of birds and
different "missions" (a migration with a duck, capturing a pigeon with a
hawk...) And the scenery could be anything from a city full of buildings to
a garden with flowers (for a hummingbird)... and rendered with POV-Ray :D
Date: 5 Feb 2009 08:35:00
Message: <web.498aeab84590b7f0c0721a1d0@news.povray.org>
Just for fun, I made the calculation for a star with the same mass as the sun:
following Kepler's thrid law the planet would orbit the star once every 1.4
billion years at a speed of 26 m/s (95 km/h), which IMO is still surprisingly
fast, about 1/1000 of the speed of earth.
Like you said it would have to be a solitary star, but that shouldn't be a
problem, there's a lot of space out there. Pun intended :-)
Date: 6 Feb 2009 19:28:03
Message: <498cd593$1@news.povray.org>
stevenvh nous illumina en ce 2009-02-05 08:33 -->
As I sayd, 100's of millenias. 1.4 billions years is 1400 millenias.
You said "lots of space" out there... You bet! Over all, the galaxys "use" less
than 1% of the "space".
Agnostic: Shit might have happened; then again, maybe not.
