Is there a "tool" in PovRay I can activate to easily display the trace of
the light path from a single point on an object as reflected between 2
mirrors?
In lieu of that, can any one send or direct me to code for a nice "laser"
render that can be inserted into my code to show the effects?
Jim
"Catseye" <jpf### [at] comcast net> wrote in message
news:4948f98d$1@news.povray.org...
> mirrors?
> Jim
I think a number of people have done this sort of thing in the past, so
there may be someone with a macro lying around that will do all of this for
you. Otherwise, it's not too difficult to do by yourself using the POV-Ray
'trace' function to track each leg of the journey that the light takes.
You can specify a start and a direction for the ray and a target object
(your first mirror or a union of all of your mirror objects). The function
can return the location at which the ray hits the surface and the surface
normal at that point. You can then add a cylinder between the start point
and the point at which the ray hits the surface. A finish of ambient 1
should give you a reasonable line to test with, then you could replace that
with a transparent cylinder containing media when you've got the maths
right.
Each subsequent leg of the journey can be done the same way, using the point
at which the ray hit the previous surface as the start point for your next
trace. To get the new direction you can use a selection of the functions
available in the standard include file "math.inc". For example, the function
VPerp_To_Plane(V1, V2) can give you a line at right angles to the original
direction vector and the surface normal returned from the first trace call.
VAngleD(V1, V2) can give you the angle between them and you can use
vaxis_rotate(A,B,F) to rotate the direction vector by twice that amount
around the line at right angles to the direction vector and normal to give
you the direction vector for the next leg
Chris B.
> mirrors?
> Jim
I guess its up to me. a "nice" laser or a crappy one?
This is one of those cases where me and Google get together for answers ...
more and more this should be the case since 2008.
Google:
laser povray alphaquad
gets you:
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.479df15fa8892dc837391bc50@news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3Cweb.488108769ae7ea535083b53c0%40news.povray.org%3E/
From LegoMan and Cousin Ricky
#declare lightsaber = material {
texture
{ pigment { rgbf 1 }
finish
{ reflection { 0 0.5 fresnel } conserve_energy
specular 1 roughness 0.01
#if (1) normal { n_Sea } #end
interior
{ #if (0) ior 1.5 #end
media
emission <.1, .1, 1>
#if (1) scattering { 3, <0.004, 0.012, 0.020> } #end
method 3
intervals 1
samples 3, 3
aa_level 2
object {
cylinder { 0, 15*y, 1.5 }
hollow //material { seawater }
material { lightsaber }
translate y*9.5
rotate x*-15 translate z*-3.0 rotate x*handxrot
translate <-2.6,-8,-4.0> rotate rarmrot translate <-shoulder,14,0>
planetarium laser and code from Rune's particles
#include "hash.inc"
// ************************* WarBird *******************************
#macro laser(A,B,rad,C)
#local p_id = 0.1;
#local glow_state = 0.001; // fader
#local glow_colorturb = <0.3,0.3,0.3>; //magnitude Randomness to color
#local ColorJitter =
(<Hash2(p_id,1),Hash2(p_id,2),Hash2(p_id,3)>-<0.5,0.5,0.5>)*glow_colorturb;
#local Color =
C
*(1+ColorJitter) // Randomness to color
*(1.001-glow_state)*20 // fader
#local ColorM = max(Color.x,max(Color.y,Color.z)); // highest RGB
#local Color = Color/2;
cylinder { 0,y*vlength(A-B),rad
//sphere { 0, 1
hollow no_shadow
pigment {rgbf 1}
finish {ambient 1 diffuse 0}
interior {
media {
emission Color // color
intervals 10 // default 10
ratio 0.9//default 0.9 distributes intervals-lit and unlit areas
samples 4,8 // default 1,1
variance 1.0/128
confidence 0.9
method 2 //1,2,3adaptive
density {
//spherical cylindrical
cylindrical
density_map {
[0.0, rgb 0 ]
[0.6, rgb Color ]
[1.0, rgb 2*ColorM]
rotate <-declination(A-B)+90,0,0>
rotate <0,-rascension(A-B)+90,0>
translate B
laser(hp, Target,.2*Scale,<0,1,0>)
cylindrical light in media:
#declare laser =
light_source {
<0,0,0>,
rgb 1
cylinder
point_at <-1,0,0>
radius 0.05
falloff 0.1
tightness 0
#if (Use_Photons)
photons {reflection on refraction on}
Subject: Re: Illustrating a point ray-trace path
Date: 17 Dec 2008 18:29:20
Message: <49498b50@news.povray.org>
"alphaQuad" <alp### [at] earthlink net> wrote in message
news:web.49496f6ed2fe8b867d75e9b90@news.povray.org...
haha how did i know that you'd reply to this thread?
Couldn't have done it without ppl like you. Amazing to me that I even caught the
request.
POV gave me something to do that had some hint and allusion of meaning. Thank
you very much.
> caught the
> request.
Indeed! Same here.
#version 3.6;
#include "rad_def.inc"
global_settings {
assumed_gamma 1.0
radiosity {Rad_Settings(Radiosity_Fast, on, off)}
location <6.0, 1.5, -35.0>
direction 1.5*z
look_at <4.0, 1.0, 0.0>
// bouncing laser macro by Tim Attwood 12/20/2008
#macro Laser_Trace(mirror_object, start_location, start_direction,
beam_radius, tail_length, bounce_limit, laser_texture)
#local LOC = start_location;
#local DIR = vnormalize(start_direction);
#local bounces = 0;
#local continue = true;
#while ((continue = true) & (bounce_limit >= bounces))
#local NORM = <0,0,0>;
#local HIT = trace(mirror_object,LOC,DIR,NORM);
#if (vlength(NORM)!=0)
#local bounces = bounces + 1;
cylinder{LOC,HIT,0.02
texture{laser_texture}
#local DIR = -vaxis_rotate(DIR,NORM,180);
#local LOC = HIT;
#else
cylinder{LOC,LOC+DIR*(tail_length),beam_radius
#local continue = false;
#declare laser_red = texture{pigment{Red}finish{ambient 1}};
#declare white_cell = difference {
cylinder {
<0,0,-1>,<0,0,1>,1
open
scale <5.001,10.001,1>
pigment {Blue}finish{ambient 0}
cylinder {
<0,0,-2>,<0,0,2>,1
open
scale <5,10,1>
pigment {White}
finish {reflection 0.1 ambient 0}
box{<-0.01,0,-2>,<0.01,100,2>}
sphere {0,100 texture{pigment{Black}finish{ambient 0}}}
plane{y,-10.002 pigment {checker Gray50,Tan scale 20}finish{ambient 0}}
object {white_cell}
#local LOC = <0.0,10.1,0>; // laser start point
#local DIR = -vnormalize(LOC-<1.4,-9.6,0>); // laser start direction
Laser_Trace(white_cell, LOC, DIR, 0.02, 40, 1000, laser_red)
// entry laser beam before known location
cylinder {<0.0,10.1,0>,<1.4,-9.6,0>,0.02
translate <0.0,-10.1,0> rotate <0,0,180> translate <0.0,10.1,0>
texture{laser_red}
