POV-Ray : Newsgroups : povray.general : Lightcuts Server Time
6 Nov 2026 18:29:16 EST (-0500)
  Lightcuts (Message 1 to 28 of 28)
Subject: Lightcuts
Date: 13 Dec 2008 13:19:53
Message: <4943fcc9@news.povray.org>
So, I wonder if you guys ever came in touch with the Lightcuts Global
Illumination algorithm?
http://www.cs.cornell.edu/~kb/projects/lightcuts/
If you're on broadband, check out the video too.  It contains some
amazing animations with complex geometry and lightning being handled
very graciously.
I wonder what's the feasibility of an implementation of it for povray,
perhaps as a replacement for radiosity.  One of the apparent advantages
seems to be sharp shadows as seen in the last seconds of the video.  It
doesn't seem to do caustics, though...
It was presented at Sigraph 2005 and is currently being integrated into
Blender:
http://unclezeiv.kerid.org/
Subject: Re: Lightcuts
Date: 13 Dec 2008 14:15:00
Message: <web.4944093bfbdb531a6c22a54d0@news.povray.org>
Looks very, very, *very* promising when it comes to handling large amounts of
point or area lights.
I'm not sure whether it can be integrated into PoV-ray to do something
radiosity-like though.
Could be possible to do this in a multi-iteration approach though:
- Set up all classic light sources (point, area, spot etc. lights)
- Compile virtual light sources from all objects having an emissive term
(objects with ambient finish and - guess what! - media; hey, this may become
really good after all!); as it seems, number of light sources generated is
*not* an issue, so we can go into extremes here
That's our initial setting; to get radiosity-like effects, we can go ahead like
this:
- Compile more virtual light sources from all objects having a *diffuse* term
(objects with a diffuse surface, and simple scattering media), by sampling all
the incoming light from the initial set-up (using lightcuts of course!) and
multiplying with the object's diffuse color.
- Repeatedly re-compile all the virtual "diffuse-term light sources", now taking
into account the light coming from other diffuse sources, until we're either
confident that they are "stable", or until we hit some configurable hard
recursion limit.
Caustics could be done by running a classic photon pass first (or multiple times
in between), and creating a light source for every photon that hits a diffuse
surface. I guess it may even be possible to modify the photon pass in a similar
fashion.
Just a bunch of thoughts though. Maybe I'm missing some serious obstacles.
Date: 14 Dec 2008 03:16:45
Message: <4944c0ed$1@news.povray.org>
Would be a typical Megapov patch.... :-)
Date: 14 Dec 2008 07:53:37
Message: <494501d1$1@news.povray.org>
But why Megapov?  AFAIK, it's based on an old fork from the pov
codebase.  How many of megapov patches go the way back to pov?  Still
waiting for AOI or HDRI.
I think this should be the right time to reevaluate some things.
Radiosity is an old algorithm, from before Photon Mapping (which is a
general GI algorithm in renderers other than pov) and it's very limited
in pov:  besides the limited count, you can't, for instance, save the
radiosity and then try to take a shot of the scene from another angle,
because areas occluded from the original angle will appear awkward.
Worse:  it seems like as if pov's radiosity is simply a 2D projection
you later apply over a raytraced scene from the same angle.  Besides, it
didn't quite fare well in the new multiprocessing core.
So, how about letting it die and either go all photon mapping or try out
this new lightcuts idea?  It seems it's strong point is to quickly
render scenes made out of sheer amounts of lights, which are
approximated and /cut/ out from the final scene, but with amazing
fidelity to the original.
And, yes, advocates of unbiased rendering are likely to give a thought
too...
Date: 14 Dec 2008 08:08:02
Message: <49450532@news.povray.org>
  Photon mapping global illumination has already been tried, and it didn't
work too well. The results were much worse than the stochastic technique
currently used.
  The whole idea of the stochastic algorithm used in POV-Ray is that you
*can* save the results and then render from a different angle and have
POV-Ray only calculate the necessary additional samples for that angle.
If the save/load feature is not doing that, then maybe file a bug report?
  The specific implementation in POV-Ray might be slightly lacking in some
areas, for whatever reason, but that doesn't mean the algorithm itself is
not sound.
  You make it sound like it's a bad idea to calculate GI samples only for
the visible scene. I'd say it's the exact opposite: That's exactly what
*want* to do. If you calculated GI for the entire scene, then the Sun would
probably die before it finishes if the scene is large enough. (Besides,
how would you limit the GI calculations given that POV-Ray supports infinite
surfaces?)
  A renderer called Radiance successfully implemented the exact algorithm
which is also used in POV-Ray, and Radiance has been used for architectural
lighting simulations and other such applications which require accuracy.
If you search for Radiance pictures, you'll find out that they look quite
good.
  I'd say that rather than drop the algorithm, what's needed is a complete
rewrite. Read the original paper by Greg Ward, and study how Radiance did
it correctly and what POV-Ray is doing incorrectly, and fix the problems.
Date: 14 Dec 2008 08:26:29
Message: <49450985$1@news.povray.org>
> currently used.
Hmm, it's the method used by high end renderers like Mental Ray.
Hmm, perhaps to calculate the additional samples for the other angle
means letting always_sample on in the second phase?  Never did that and
so I discovered areas hidden from the original angle sucked from
another.  It seems messing with camera's sky also messes with the
radiosity projection onto the raytraced scene.
> the visible scene.
No, I was just wondering why I couldn't reuse a saved file that took
ages and render it from another angle with always_sample off.  Seemed to
beat the whole purpose...
Yes, I know that. "POV-Ray's radiosity is based on an idea by Greg Ward".
I always wanted to use Radiance, but it's RIB-like input language is
horrid compared to pov's and there are too many specialized command-line
tools for my liking, with no front-end of any kind.
Why stick with old ideas when new and exciting ideas building on
previous failures appear to be successful?
Date: 14 Dec 2008 09:56:02
Message: <49451e82@news.povray.org>
  Because the new ideas usually only work for polygonized scenes or, in
the case of unbiased rendering, are much slower (although may result in
better-looking images).
  Unless I understood incorrectly, the "lightcuts" algorithm is not about
global illumination, but about speeding up illumination from hundreds of
thousands of point light sources, which is a rather different thing. (Global
illumination is about light reflecting from surfaces and illuminating other
surfaces, in turn reflecting from them and illuminating yet other surfaces,
and so on. "Lightcuts" looked like an algorithm for direct illumination only.)
Date: 14 Dec 2008 11:10:00
Message: <web.49452f53fbdb531a7a798a10@news.povray.org>
Guess what: HDRI actually *is* in the beta :)
Nobody seems to have made much fuss about it, but it works. It just seems to
handle gamma a bit differently than the MegaPOV implementation, but that may be
simply due to the general gamma handling change.
And AFAIK some things like radiosity and/or photons actually made their way into
official POV via MegaPOV.
Aiming for it to be integrated into MegaPOV seems the right way for me (and
besides: Who uses standard POV anyway? :)); at least as long as we're talking
about 3.7 - for throwing old things overboard, the 4.0 would be a much better
candidate.
4.0 is still at its very basics, and is intended to head for radical changes
anyway (new SDL and all).
So getting Lightcuts into MegaPOV - as a proof that it *can* be integrated into
existing concepts, that the *POV* development community can implement it, that
it *does* give the expected performance benefits, and that it can be done
*without* sacrificing other features like reflections, caustics or all the
types of media - might give it a chance to be selected for the 4.0 *main*
lighting model. If it's never integrated into a POV patch, I guess it will at
best make it into 4.0 as an experimental feature.
So yes, going for a Lightcut-patched 3.6 (or 3.7) - ideally as part of MegaPOV -
might be *the* key to actually get it into official POV at all.
Doing it as fast as possible might be crucial on both sides: As of now, no final
decision has been made about the main lighting model for 4.0; some advocate to
stick with the existing model, while others suggest other approaches, but the
discussion seems to have come to a standstill. An approach with such
extraordinary runtime characteristics as promised by Lightcuts - if proven to
be feasible in the POV world - would most likely tip the scales. A sub-linearly
scaling algorithm - and not only that, looks like we're talking about very close
to logarithmic here - where do you get *that* in 3D rendering, where sometimes
you'd be happy if things would scale sub-quadratic?!
Date: 14 Dec 2008 16:49:49
Message: <49457f7d$1@news.povray.org>
Yes, I was in doubt too.  But in the webpage for the paper they say:
"It handles arbitrary geometry, non-diffuse materials, and illumination
from a wide variety of sources including point lights, area lights,...
and indirect illumination."  They couldn't just be plain lying.
So, I did a test using the Blender implementation:
http://img440.imageshack.us/img440/1255/lightcutstestzg0.jpg
Only lightsource is an area light outside and above the window.  So,
indeed it handles indirect illumination automatically...
It has a lightcuts panels with quite a few parameters, among them,
number of point lights generated from an area light.  The default is
immense, so I fearfully put it down to a modest 128 as well as a
indirect light factor about the same.  I think such "low" settings can
be accounted for the splotches and "cuts" seen.
OTOH, it took 44 minutes on a P4 2.66.  Not as fast as I had hoped for... :P
Next, I'll try to export to pov and play around with radiosity.  I
didn't like the radiosity in Blender, even with quite lots of
subdivision, it still looks quite ugly and not on par with the lightcuts
picture...
Date: 14 Dec 2008 17:26:09
Message: <49458801$1@news.povray.org>
Great!  Now only a few more years until mechsim, AOI, displace warps and
some others...
I never used megapov.
Is it anything other than a hope at this point?
Well, it does seem to handle indeed a huge amount of point lights
automatically generated from quite a few light sources.  But it seems
about as slow as any other GI method.  OTOH, there doesn't seem to be
any radiosity count limit.  And, I wonder if it'd be more amenable to
multiprocessing than radiosity...
Date: 14 Dec 2008 19:30:00
Message: <web.4945a492fbdb531a9ca92a700@news.povray.org>
I'd guess so. With radiosity, lots of interim results would have to be shared
beteen adjacent pixels. With Lightcuts, theoretically you'd have just the one
light source tree that would be shared, and for each pixel you would calculate
a new cut of the tree anyway, so no need for sharing this information (although
it *could* be shared among pixels calculated in the same thread, in order to
speed up finding the optimal cut. If there is any sense in doing so.)
Date: 14 Dec 2008 19:45:51
Message: <4945a8bf@news.povray.org>
  The shadow under the head doesn't make physical sense. Where is it
coming from? That shadow would indicate that there's a strong light
source above the head, but the illumination of the head does not correspond
to this. The bright area on the floor would rather obviously not cause
such a shadow.
Date: 14 Dec 2008 20:25:01
Message: <web.4945b132fbdb531a1bcd25620@news.povray.org>
> such a shadow.
I've put 3 bounces or more.  Probably some of the light in the bright area on
the floor under direct illumination bounce to the ceiling, then down again.  It
is present in the radiosity version too, though much less sharp:
http://img111.imageshack.us/img111/7218/lightcutstest3radiobm0.jpg
Date: 14 Dec 2008 20:45:00
Message: <web.4945b65efbdb531a9ca92a700@news.povray.org>
> such a shadow.
You're forgetting about all the indirect scattered light.
With the head so close to the surface, it is blocking the indirect light from
almost all directions except sideways, so it gets significantly less light
(plus, light of same intensity from sideways is actually weaker at illuminating
a surface).
The indirect lighting in this picture seems quite exaggerated to me, but apart
from that there's nothing wrong with this.
Radiosity will produce a shadow there as well. Or at least it should - if it
doesn't it's off reality.
Date: 15 Dec 2008 03:32:14
Message: <4946160d@news.povray.org>
  Also directly under the ear? The ear is so small that it's not blocking
almost anything, yet the shadow on the floor produced by the ear is very
pronounced.
Date: 15 Dec 2008 04:25:00
Message: <web.49462165fbdb531ad5b77e4a0@news.povray.org>
> pronounced.
I didn't notice in the original, but the blue square on the wall is supposed to
be a window. Assuming the outside to be very bright, I would expect the shadow
under the head. Warp is correct though; without this assumption, the shadow
isn't right.
This makes the colour of the outside completely wrong, of course - it would need
to be hundreds of times brighter to be believable.
Date: 15 Dec 2008 04:40:00
Message: <web.49462598fbdb531ac44051d10@news.povray.org>
Yes, sorry.  Blender's default background is that color.  I just didn't change
it and it looks dark outside.  It has no influence on the lighting, though.
I did provide a link to the radiosity version where I also took the time to
change the background to some more sunny-day look-alike. :)
Yes, the shadows are very sharp and pronounced and I'm not quite sure wether
it's because there's too much brightness, the Blender implementation is still
buggy or whatnot.  Don't you guys think it's funny though when we begin
wondering wether a synthetic image is correct or our own assumptions about how
it should work in real life? ;)
Date: 15 Dec 2008 06:00:02
Message: <web.4946385cfbdb531ac44051d10@news.povray.org>
Two more radiosity renderings.  Thankfully, after some half-hour of
pre-calculating, taking shots from other angles is a breeze.
http://img377.imageshack.us/img377/7061/lightcutstest4radioxv4.jpg
http://img377.imageshack.us/img377/3884/lightcutstest4radio2dh3.jpg
I increased the mesh resolution of the ground, so the shadow of the ear is more
visible, though still faint.  I'd guess it has to do with the fact that sharp
shadows are not really possible with radiosity.
Also, while not seen in none of these scenes, there's quite a bright spot in the
ceiling, no doubt contributing for the shadow below.  It is itself illuminated
by some of the ground outside (I put the floor as a plane rather than part of
the cubic room).
Date: 15 Dec 2008 12:00:01
Message: <web.49468c24fbdb531af708085d0@news.povray.org>
> pronounced.
You're talking about the left ear (the one to our right side) I guess. To me it
looks like it blocks part of the bright light coming through the window (the
blue patch on the wall), and therefore creates a very strong contrast.
Date: 15 Dec 2008 12:05:00
Message: <web.49468d58fbdb531af708085d0@news.povray.org>
> isn't right.
Depends on what is on the outside - if we're talking about a moonlit night, with
a several-hundred-kilowatts spotlight blazing into the room, then it's quite
fine I guess :)
Date: 15 Dec 2008 12:10:00
Message: <web.49468e75fbdb531af708085d0@news.povray.org>
Yuck - this radiosity implementation sucks... I'd rather have POV's artifacts
than these :)
(Would make a nice effect for some "help, the aliens are out to abduct me!" type
of scene, with the alien ship's floodlights seeping even through solid walls at
the room's corners...)
Date: 15 Dec 2008 12:17:18
Message: <4946911e$1@news.povray.org>
clipka escreveu:
> than these :)
It's vertex painting.  In order to have good radiosity, you should
subdivide all your meshes as much as you can to get good results.  Plus,
I've done the imbecile approach of having a plane for the floor that
stretches outside!  So, some of the outside vertex close to the walls
get painted white and it shows inside. :P
OTOH, after the radiosity calculations, the scene is rendered incredibly
fast, much more than pov's.  I'm still to get to grips with the right
settings, though... or perhaps not:  this lightcuts implementation
permits this kind of baking as well. :)
Date: 15 Dec 2008 13:04:13
Message: <49469c1c@news.povray.org>
> isn't right.
  It isn't right with that window. The light square on the floor is light
coming from the window. The light is not directly illuminating anything else.
  Besides, if the shadow was produced from light coming from the window,
it would be a lot more elongated to the left, and the lighting of the head
would be more pronounced.
Date: 15 Dec 2008 15:35:00
Message: <web.4946bf14fbdb531aea3236f00@news.povray.org>
> > isn't right.
Well, I was thinking it was the actual sky casting the shadow, with the bright
spot on the floor cast by a point(ish) source in the sky. But in any case,
nemesis assures us the sky doesn't cast light, so I guess that shadow's all
wrong as you originally said. Additionally, I think the darkening in the
corners is far too extreme.
Bill
Message: <web.4946bf47fbdb531aea3236f00@news.povray.org>
> > isn't right.
> fine I guess :)
Yesyes, ok :)
Date: 15 Dec 2008 15:46:43
Message: <4946c233$1@news.povray.org>
Bill Pragnell escreveu:
Coming home I'll do a povray radiosity render with the same scene and
another lightcuts render looking above to see what is causing the
shadows... from the viewport during the radiosity calculation window, it
can be seen quite a bright area in the ceiling.
Date: 15 Dec 2008 16:28:24
Message: <4946cbf8@news.povray.org>
  I don't have a problem with the shadow per se, as the ceiling and upper
walls are illuminated by the bright spot on the floor, and the ceiling and
walls probably will cause a darkening underneath the head. What bothers me
is how well-defined the shadow is. It's almost sharp. If the shadow is
caused by a large ceiling and walls, the shadow under the head should be
*very* smooth (as the ceiling would effectively be a huge area light), so
smooth that it should be almost shapeless. Such as well-defined shadow can
only be produced by a relatively small area light, which in itself would
make the head be lighted more strongly from that direction.
Date: 15 Dec 2008 20:16:43
Message: <4947017b$1@news.povray.org>
nemesis nous illumina en ce 2008-12-15 12:17 -->
> clipka escreveu:
>> artifacts
>> than these :)
Make the wall thicker! Add some thickness outside near the base. If you still
see that kind of artefacts, then the implementation is buggy
Unitarian: Shit that happens to one person is just as bad as shit that happens
to another.
