POV-Ray : Newsgroups : povray.general : POV-ray (text) editor for beginners Server Time
6 Nov 2026 18:43:39 EST (-0500)
  POV-ray (text) editor for beginners (Message 1 to 26 of 26)
Subject: POV-ray (text) editor for beginners
Date: 13 Nov 2008 20:12:24
Message: <491cd078@news.povray.org>
Hi, every night before going to bed I teach a little bit of POV-ray to
my wife.
The most annoying problem is that everytime she wants to see the scene
she has to save, go to the shell, issue the povray command with some
(for her) cryptic options and then open up an image viewer (or
imagemagick's "display") to see the result. For an animation, it's even
more complicated.
Because my target here is not teach her how to script in bash but how to
write scenes in POV-ray, I would feel much better if there was an
"integrated" editor for POV-ray with buttons to select options and start
rendering.
Any suggestion? PS I do *not* want a CAD-like or "visual" editor...
bye
as
Subject: Re: POV-ray (text) editor for beginners
Date: 13 Nov 2008 20:30:01
Message: <web.491cd42e34cbc438849303c80@news.povray.org>
> my wife.
> more complicated.
> rendering.
> bye
> as
Are you using Windows?
-Mike
Date: 13 Nov 2008 22:47:00
Message: <491cf4b4$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.491cd42e34cbc438849303c80@news.povray.org...
>> my wife.
>> more complicated.
>> rendering.
>> bye
>> as
> -Mike
From the BASH comment I assume he's in Linux of some sort.
You could try the windows version under Wine, I'm not sure
but it probably would work.
There's also POVclipse... that's a POV syntax version of Eclipse,
you could give that a try.
Date: 14 Nov 2008 02:38:40
Message: <491d2b00@news.povray.org>
Hash: SHA1
> my wife.
> more complicated.
> rendering.
> bye
> as
	You might want to try XPE: http://nextpe.sourceforge.net/
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkkdK0IACgkQd0kWM4JG3k8SfgCfQlzkkemJVEG8pyoy5N0fOntq
a6oAmwVXFPzjZHls2fzl6OqFoQvFwQht
=0BAg
-----END PGP SIGNATURE-----
Date: 14 Nov 2008 10:38:49
Message: <491d9b89@news.povray.org>
  It doesn't have to be so complicated. When I edit a povray file and want
to make a test render of it, it happens like:
- Save by pressing the saving shortcut key in the text editor.
- Alt+tab to switch to the terminal where I have been running povray.
- Up+enter (assuming I have already run povray in that terminal).
  That's it. POV-Ray shows the rendered image on an X window while it
renders it. When it's done (or I want to interrupt it), I:
- Press q to stop povray.
- Alt+tab to get back to the editor.
  If your version of povray doesn't display the image it's rendering,
you should get one which does.
Date: 14 Nov 2008 10:46:29
Message: <491d9d55$1@news.povray.org>
It's not even complicated with emacs (at least in linux).  If I have a shell window
running tcsh and an emacs window, I do:
in emacs window: cntl-S
in shell window (to repeat my last render command): !pov enter  (!p if I've not issued
any other p... commands)
    or "cntl-p" until I reach the last pov command, then enter
Lightning fast.  Well under one second.
The shell can be within an emacs window, if I prefer (which I don't).
That's it.  It's not worth worrying about shortcuts.
Dan
Date: 14 Nov 2008 10:51:26
Message: <491d9e7e$1@news.povray.org>
whoops: cntl-X cntl-S.
My fingers know what to do, anyway.. :)
Date: 14 Nov 2008 11:06:08
Message: <5395A4F713BF447391EFC1410A489558@HomePC>
Isn't there one called KPov or something for KDE?
And I believe SciTE is able to launch POV-Ray directly with a
button-press, and it does great syntax highlighting.  Configure POV to
display the output as it renders.
...Ben Chambers
www.pacificwebguy.com
Date: 14 Nov 2008 11:35:34
Message: <491da8d6$1@news.povray.org>
Dan Connelly escreveu:
An experienced emacs user going bloppers.  Just imagine a novice... :P
Date: 14 Nov 2008 11:39:53
Message: <491da9d9$1@news.povray.org>
Alessio Sangalli escreveu:
> my wife.
Ever heard of bash history?  Up arrow key to access the last command, or
CTRL+R + "word" to search for "word" in the history.  more CTRL+R to see
older entries.
Why not?  Why impose such command line pain to your wife?  Women would
certainly enjoy modelling with curves visually rather than typing like a
geek.
Date: 14 Nov 2008 11:54:03
Message: <491dad2b$1@news.povray.org>
> geek.
Everyone knows women can't type.
Date: 15 Nov 2008 03:18:41
Message: <491e85e1@news.povray.org>
>> a geek.
I'd respond with a cogent and scathing retort, but I've suddenly found
my fingers unable to locate the correct keys.
Date: 15 Nov 2008 08:12:29
Message: <slrn.ghtilm.ls2.steev@hot.pl>
U�ytkownik 'Alessio Sangalli' zaszczyci� nas tymi oto s�owami :
gedit
Syntax coloring works fine, and you can define povray invocation as
a menu option...
> as
S�awek
  ________ - Jak waskie sa korytarze w domu soltysa Wachocka?
_/ __/ __/ - ze jego pies moze merdac ogonem tylko w gore i w dol.
 \__ \__ \_______________________________________________________________
 /___/___/ S�awomir Szczyrba                          steev/AT/hot\dot\pl
Date: 16 Nov 2008 05:45:06
Message: <491ff9b2$1@news.povray.org>
Yes, SciTE is great for editing POV-Ray files.
I have the following in my /usr/share/scite/pov.properties...
command.compile.*.pov=povray +P +W320 +H240 $(FileNameExt)
command.build.*.pov=povray +P +W800 +H600 $(FileNameExt)
command.go.*.pov=povray +P +W1332 +H999 +AM2 +A $(FileNameExt)
...which then let's me launch various different qualities of renders
directly from the editor using the function key short cuts.
SciTE even shows you the povray output in a small pane to the right of
the editor, so it's easy to see mistakes in the SDL code if there are
any or to track the progress of the render.
Jonathan
Date: 17 Nov 2008 15:47:57
Message: <4921d87d@news.povray.org>
> rendering.
Get your wife a nice birthday present such as a laptop with a
user-friendly OS and install the Windows version of POV-Ray.
Do not despair if birthday is too far off, women usually
find occasion-free presents acceptable as well ;)
Date: 17 Nov 2008 16:06:34
Message: <4921dcda$1@news.povray.org>
Christian Froeschlin wrote:
> user-friendly OS....Windows
Oh, my.....
Talk to anyone in system support how "user-friendly" Windows is.
Date: 18 Nov 2008 11:36:15
Message: <4922eeff@news.povray.org>
Christian Froeschlin escreveu:
Or a nice laptop with Linux, Blender or Wings 3D and povray exporters.
Date: 18 Nov 2008 18:08:43
Message: <49234afb@news.povray.org>
Or let's go write a GUI for Linux comparable to the one in Windows.
Oh wait, better a cross-platform one, to replace the current Windows one
too. The POV-Win code is UGLY!
Date: 19 Nov 2008 06:55:27
Message: <4923feaf@news.povray.org>
> Oh, my.....
ANd put the same users on Linux, you think there would be *less* calls?
Date: 19 Nov 2008 10:47:27
Message: <4924350f@news.povray.org>
scott wrote:
>> Oh, my.....
The burden is on your statement that Windows is more user-friendly.  Asserting they
may be equal isn't good enough.
Date: 19 Nov 2008 17:56:37
Message: <492499a5$1@news.povray.org>
1. It wasn't his statement
2. I feel entirely unburdened
3. I actually like Linux (well, for work)
As the OP explicitely stated his wife finds it annoying
to have to type something on the command line, she would
very likely be happier on Windows - or Mac, heaven forbid,
but I think there is only an inofficial POV for that.
It seems such an opinion is already too much trolling ;)
Now it itches me to praise the blessing of DOS, which I
grew up with - and two of my three systems still run it.
Date: 20 Nov 2008 11:57:30
Message: <492596fa$1@news.povray.org>
Nicolas Alvarez  wrote in message <49234afb@news.povray.org>:
There are already lots of IDEs, most of them could easily get a POV mode,
and some of them already have.
Please do not waste time reinventing the wheel.
Date: 20 Nov 2008 12:50:00
Message: <web.4925a33d34cbc43881c811d20@news.povray.org>
Dan Connelly <djc### [at] yahoocom> wrote:
> scott wrote:
> >> Oh, my.....
The problem that the people in system support tend to face is not so much
windows not being user-friendly, so much as the users not being
windows-friendly (or computer-friendly for that matter)
-tgq
Date: 20 Nov 2008 12:53:40
Message: <4925a424$1@news.povray.org>
Trevor G Quayle escreveu:
>> scott wrote:
>>>> Oh, my.....
http://www.youtube.com/watch?v=pQHX-SjgQvQ
Date: 20 Nov 2008 13:45:01
Message: <web.4925af4b34cbc438b73646fd0@news.povray.org>
> scott wrote:
> >> Oh, my.....
Linux users tend to be more experienced; thus, it is true that the average Linux
user may in fact find it to be as or nearly as user-friendly as the average
Windows user finds *Windows* to be. But this is simply an example of the havoc
excessive insulation can wreak upon the mind...
And then there's the fact that there really *is* no such thing as Linux:
http://www.theregister.co.uk/2008/10/22/what_is_linux_worth/
-Mike
Date: 21 Nov 2008 19:23:33
Message: <49275105@news.povray.org>
Trevor G Quayle nous illumina en ce 2008-11-20 12:49 -->
>> scott wrote:
>>>> Oh, my.....
> -tgq
Like what you see here: http://www.rinkworks.com/stupid/
Bad spellers of the world UNTIE!
