POV-Ray : Newsgroups : povray.general : Christmas tree lights? Server Time
6 Mar 2026 00:32:38 EST (-0500)
  Christmas tree lights? (Message 1 to 5 of 5)
Subject: Christmas tree lights?
Date: 31 Oct 2008 10:32:08
Message: <490b16e8$1@news.povray.org>
I want to create Christmas tree lights for a scene that may become a
Christmas card.  I'm thinking of using the MegaPov glow feature, but because
they will be somewhat close-up, I'm not sure it's up to the task.  Ideally,
the bulb would be visible, yet still emitting some light.
Does anyone else have any experience with this?  If not, any help on which
direction I might want to pursue would be appreciated (emitting media inside
an object, etc.)  Basically, I just want a fairly realistic looking
christmas tree, but the tree and balls I've got handled.
Subject: Re: Christmas tree lights?
Date: 31 Oct 2008 15:18:20
Message: <490b59fc@news.povray.org>
So, do you want a halo around the objects? Or do you want somebody to
model the bulbs for you? If it's a halo you want, I do have experience
in that department. I've got a version of my luminous bloom code which
takes HDR images as input, and (slowly) spits out the image with halos
around the bright parts. You would have to give the bulbs (or the
filaments inside them) really high ambient values, and output the first
render to HDR format. You would need to use 3.7b or MegaPOV for the
whole process. If you wish to pursue this route, let me know and I'll
post the updated luminous bloom code (I should post it anyway).
Sam
Date: 31 Oct 2008 16:31:00
Message: <490b6b04@news.povray.org>
"stbenge" <THI### [at] hotmailcom> wrote in message
news:490b59fc@news.povray.org...
If anyone has already done it well, sure.  I wouldn't want someone to write
my code for me, though.  ;-)
Mostly, I just didn't want to reinvent the wheel here.  The problem is that
some things which look good from a distance, won't look very good on closer
inspection.
> If it's a halo you want, I do have experience in that department. I've got
> a version of my luminous bloom code which takes HDR images as input, and
> (slowly) spits out the image with halos around the bright parts. You would
> have to give the bulbs (or the filaments inside them) really high ambient
> values, and output the first render to HDR format. You would need to use
> 3.7b or MegaPOV for the whole process. If you wish to pursue this route,
> let me know and I'll post the updated luminous bloom code (I should post
> it anyway).
Later tonight, I'm planning to play around with the Megapov glow features,
and see how it looks.  At this point, I'm really not sure how they do what
they do, and whether or not they'd be suitable.  Maybe I'll use them in
conjunction with regular light sources, or maybe something else...
If I understand how you describe your luminous bloom code, if you have an
object with a really high ambient value, it will "bleed" into the
surrounding pixels.  I guess I wouldn't know for certain until I've tried
it, but that sounds kind of like what I'm after here.
Perhaps I'll end up with some combination of effects.  Time to start
experimenting...  If I come up with something good, I'll certainly share the
code and concepts with anyone who requests.
Date: 31 Oct 2008 17:18:22
Message: <490b761e@news.povray.org>
The bulbs or the halo? You have to be specific :)
I won't model the bulbs for you, but if you want to speed the process
up, you could probably model them in Blender or Wings... Blender makes
it easy to add thickness to a mesh, but if you aren't familiar with the
program, you may find yourself mired deep in a steep learning curve...
> inspection.
In that case, CSG objects may be the ticket here. A blob object or two
sor's could make a nice glass bulb shape.
The glows are nice for many things, and may in fact work for this
particular project. For instance, for an incandescent bulb you could
create a series of glows along the "filament." This would look nice for
closeup shots.
Yes, that's pretty much how it works. The HDR version of my code works
very well for stuff like this. The effect has an affinity for bright
values(eg. rgb<20,10,10>); lower, more typical values (eg. rgb<1,.5,.5>)
do not produce a very visible glow. The HDR version is slower than the
regular version which is already very slow. Plus, I never extended the
program to use more than 256 color_map entries, so you are limited to
about 227 samples max (because the samples are evenly spaced points in a
disc). I might be able to optimize the code to squeeze a few more
samples in there, since I probably used fractional loop counters ;)
Well, if you need the luminous bloom code right away I'll try to make it
presentable very soon. Otherwise I'll be taking my time. The MegaPOV
glow idea will probably work, though.
Sam
Date: 31 Oct 2008 19:46:00
Message: <490b98b8$1@news.povray.org>
news:490b761e@news.povray.org...
The bulb shape I can probably handle. The halo, light source, etc, and any
media is the challenge.
> presentable very soon. Otherwise I'll be taking my time. The MegaPOV glow
Thanks for the insight.  I'll probably just do some experimenting and post
in p.b.i and go from there.  :-)
