Tor Olav Kristensen wrote:
> Severi Salminen wrote:
>> My head is spinning. I have a fairly simple task:
>> V1 = 0,1,0 (this is a vector pointing up along y-axis)
>> V2 = user defined unit vector pointing anywhere.
>> How do I rotate V1 using rotateX(), rotateY() and rotateZ() so that it
>> equals V2?
>> This would be intersting, too:
>> What is the resulting 4x4 transformation matrix that does the same thing?
>> Actually, I'd prefer just the transformation matrix because I guess I
>> could avoid using trigonometric functions back and forth.
> You are right: No trigonometric functions are needed.
> Below is a rewritten version of the Reorient_Trans() macro.
> Follow up set to povray.general
The code below shows how the axis rotate transformation and the
reorient transformation are related.
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2008 Tor Olav Kristensen
// http://subcube.com
// Relationship between Reorient_Trans() and Axis_Rotate_Trans()
#version 3.6;
#macro Reorient_Trans(v1, v2)
#local v1n = vnormalize(v1);
#local v2n = vnormalize(v2);
#local vA = vcross(v1n, v2n);
#local Sin = vlength(vA);
#local Cos = vdot(v1n, v2n);
#local M = 1 - Cos;
#local vAn = vnormalize(vA);
#local X = vAn.x;
#local Y = vAn.y;
#local Z = vAn.z;
transform {
matrix <
X*X*M + Cos, Y*X*M + Z*Sin, Z*X*M - Y*Sin,
X*Y*M - Z*Sin, Y*Y*M + Cos, Z*Y*M + X*Sin,
X*Z*M + Y*Sin, Y*Z*M - X*Sin, Z*Z*M + Cos,
0, 0, 0
#end // macro Reorient_Trans
#macro Axis_Rotate_Trans(vA, Angle)
#local Phi = radians(Angle);
#local Sin = sin(Phi);
#local Cos = cos(Phi);
#local M = 1 - Cos;
#local X = vAn.x;
#local Y = vAn.y;
#local Z = vAn.z;
transform {
matrix <
0, 0, 0
#end // macro Axis_Rotate_Trans
Tor Olav
