Hello,
if I have *.png files, then how to generate an .avi out of it? With 25 fps.
rafal <new### [at] limcore com> wrote:
> Hello,
man mencoder
The -mf option is the one you are looking for.
> Hello,
I used this :
mencoder mf://E:\Pov\road\anim\*.png -mf w=800:h=600:fps25:type=png -of
mpeg -ovc lavc -lavcopts vcoded=mpeg4:mbd=2:trell -o
E:\Pov\road\anim\road_parametric5.mpeg
(this is rather low bitrate)
Thibaut
Thibaut Jonckheere wrote in message <48255435$1@news.povray.org>:
There is no option tu set the bitrate, you get whatever the default would
be. Furthermore, you put very few options to increase the efficiency of the
encoding. I personally use the following settings:
-ovc x264 -x264encopts
frameref=8:bframes=2:8x8dct:me=umh:subq=7:nodct_decimate:trellis=2:weight_b:direct_pred=auto:crf=20
The crf option is the overall quality.
> would be
Actually, you can set the bitrate according to the man page - it's part
of the lavcopts parameter, probably depends on the codec used.
Jim
Agreed over the few options - but I just wanted to show a simple
example, to help to get started (the documentation of mencoder is not
crystal clear about all these options, personnaly I feel somewhat
confuse...).
Anyway, here is a more complete command I used (note the vbitrate option
btw, so I guess it exists ;-) )
C:\Documents and
Settings\Thibaut\Bureau\Videotools\MPlayer-1.0rc2>mencoder mf:
//*.png -ovc lavc -lavcopts
vcodec=mpeg4:vbitrate=4000000:vpass=2:mbd=2:keyint=1
32:v4mv:vqmin=3:lumi_mask=0.07:dark_mask=0.2:mpeg_quant:scplx_mask=0.1:tcplx_mas
k=0.1:naq -mf fps=25 -nosound -o trybest.avi
Thibaut
Hash: SHA1
>> would be
I believe Nicolas meant: "there is no option to set the bitrate /in
this command-line example/"...
Jerome
+------------------------- Jerome M. BERGER ---------------------+
| mailto:jeb### [at] free fr | ICQ: 238062172 |
| http://jeberger.free.fr/ | Jabber: jeb### [at] jabber fr |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFIKeOJd0kWM4JG3k8RAjVlAKCjpJPc+myuleUxKB06t+muE8SJagCfaBac
Q+poJ+peEVoRBFmOT6hWfXA=
=lS6m
-----END PGP SIGNATURE-----
in
Ah, I see....
Jim
