POV-Ray : Newsgroups : povray.general : Random Mazes Server Time
6 Nov 2026 19:22:05 EST (-0500)
  Random Mazes (Message 1 to 13 of 13)
Subject: Random Mazes
Date: 8 May 2008 00:16:08
Message: <48227e88$1@news.povray.org>
I have been learning C# and even though this is not POV related I thought I would
share it with the group.
Enjoy.
http://209software.com/downloads/publish.htm
Subject: Re: Random Mazes
Date: 8 May 2008 06:30:03
Message: <4822d62a@news.povray.org>
  Instead of an executable, an algorithm would be more interesting.
Date: 9 May 2008 19:15:48
Message: <4824db24@news.povray.org>
> I would share it with the group.
> Enjoy.
http://209software.com/downloads/setup.exe
CGI Error
The specified CGI application misbehaved by not returning a complete set of
HTTP headers.
btw, .exe? Not everyone has windows you know. How about the source instead.
Date: 9 May 2008 20:08:59
Message: <4824e79b@news.povray.org>
> instead.
It's .NET anyway. How easy is it to compile stuff under Mono?
Date: 9 May 2008 20:20:07
Message: <4824ea37@news.povray.org>
Nicolas Alvarez wrote:
>> instead.
No idea I don't use .NET.
But normal C++ source would be even better :)
Date: 9 May 2008 20:46:43
Message: <4824f073$1@news.povray.org>
If it's not using anything windows-specific, it should run under Mono
without recompiling anyway.  (GUI stuff, of course, won't work the same.
But you could probably build it and then output it to a bitmap file
without too much trouble.)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 10 May 2008 02:27:31
Message: <48254053$1@news.povray.org>
rafal napsal(a):
>>> instead.
I like Java for Javadoc. And labeled breaks might prove useful, too.
And it doesn't need recompiling across platforms.
Linux is only free if your time is worthless
		-Jamie Zawinski
Johnny D
Date: 10 May 2008 03:48:39
Message: <48255357@news.povray.org>
Jan Dvorak <jan### [at] centrumcz> wrote:
> rafal napsal(a):
> >>> instead.
  I would still prefer the algorithm.
Date: 11 May 2008 03:09:44
Message: <48269bb8@news.povray.org>
So, any type of source seems like the best option I guess :)
Date: 11 May 2008 12:37:44
Message: <482720d8$1@news.povray.org>
rafal napsal(a):
except for Intercal and maybe Assembler :-)
the ultimate time-killer:
+a0.0 +am2 +r9
Johnny D
Date: 11 May 2008 12:44:41
Message: <48272279$1@news.povray.org>
Actually I was just sharing it as a fun little thing - part of me learning C#.
But since 100% of the comments are "Please give us all your work for free, and
by the way if you could sit down and translate it into platforms you don't use
that would be swell", I am inclined to tell you all to go pound sand.
Sorry, but I have been unemployed since January and could have used just one
person saying "cool idea, you've got something there" - rather than this.
Date: 11 May 2008 13:27:57
Message: <48272c9d$1@news.povray.org>
>> same. But you could probably build it and then output it to a bitmap
>> file without too much trouble.)
> one
Sorry if I came across that way. I was merely answering the question of
"how easy is it to run under Mono."  I should have said "one can ..."
instead of "you can."
FWIW, I love mazes. I even did an animated maze with reflective floor
and wobbly high-IOR walls you could walk around in with arrow keys. (All
pre-rendered, with a little front end to show the appropriate motions.)
I'm not sure what better algorithm you could post other than the source.
It looked easy enough to understand without needing to be translated
into any other language.  (Now, if you'd written it in Haskell or
something... ;-)
Date: 11 May 2008 14:58:55
Message: <afge24lh3d721bimjp0cfc456u774mh2sp@4ax.com>
On Sun, 11 May 2008 09:44:41 -0700, Bryan Valencia <no### [at] waycom> wrote:
I'm sorry to hear that I sympathise as I've had similar periods of
unemployment. As for the programme I did not download it because I
don't often install exectuables from the internet. That might be one
of the problems.
Regards
