Hello,
does anyone have some quick working code to create like
box { -1000, +1000 }
but deformed a bit?
Perhaps a mesh, or set of 6 highfields with function() making the "texture".
Camera will be placed inside the box btw.
In general, it is aimed to represent a simple living room.
Rafał Maj escribió:
> Hello,
> but deformed a bit?
How about just a normal perturbation?
box {
<-100, 0, -100>,
< 100, 100, 100>
color White
normal {
granite 0.1
scale 5
> box {
> <-100, 0, -100>,
> < 100, 100, 100>
> pigment {
> color White
> normal {
> granite 0.1
> scale 5
Helpfull, but I need higher quality - to deform actual shape - so that the
border betwen "walls" will not appear so straight artificial etc
Deforming actual shape = isosurface.
I think it would be a lot faster to use 6 isosurface "planes" than an
actual box (intersection of planes in a single isosurface).
Nicolas Alvarez escribió:
>> the
location <-20.0, 10.0, -10.0>
direction 1.5*z
look_at <0.0, 9.0, 0.0>
light_source {
<-10, 20, -15>
color rgb 1
#declare Granite = function { pigment { granite scale 10 } };
union {
isosurface {
function { y-Granite(x,y,z).x*0.5 }
contained_by {
box {
<-30, 0, -30>, <30, 1, 30>
max_gradient 2.2
isosurface {
function { z-Granite(x,y,-z).x*0.5 }
contained_by {
box {
<-30, 0, 0>, <30, 30, 1>
max_gradient 2.2
scale <1,1,-1>
translate z*30
isosurface {
function { x-Granite(-x,y,z).x*0.5 }
contained_by {
box {
<0, 0, -31>, <1, 30, 31>
max_gradient 2.2
scale <-1,1,1>
translate x*30
color White
Up to you to add the remaining three planes.
If you actually try it, it turns out to be slightly faster to use
function { max((y*y-1),(x*x-1),(z*z-1)) +wobble(x,y,z) }
than to use the intersection of 6 isosurface "planes" that use the same
contained_by (even though the "planes" use a lower max_gradient).
There's not a huge difference.
I guess that if you were to create a tighter contained_by for each
"plane", then you might get that to run faster, but I suspect that the
gain would not be significant.
Mike Williams
Gentleman of Leisure
Well I *am* using a tight containing box, which in my case is like 30
times smaller than the room.
I'd be interested in knowing the speed comparison between your method on
a single isosurface, and using six isosurfaces with separate planes but
*with tight containing boxes*.
And I think it will be 100 times faster to use 6 heightfields instead
of 6 isosurfaces. The heightfields can be created using the same function
as the isosurfaces.
Rafał Maj wrote:
> Hello,
> but deformed a bit?
#include "functions.inc"
global_settings { max_trace_level 20 }
background{1}
location 2
look_at 0
#local p = 2;
#local k = 0.6;
#local s = function { abs(abs(x + y) + abs(x - y) + z + z) + abs(abs(x +
y) + abs(x - y) - z - z) - 4 }
#local d1 = function { x + k*f_noise3d(p*x, p*y, p*z) }
#local d2 = function { y + k*f_noise3d(100 + p*x, 100 + p*y, 100 + p*z) }
#local d3 = function { z + k*f_noise3d(200 + p*x, 200 + p*y, 200 + p*z) }
isosurface{
function { s(d1(x, y, z), d2(x, y, z), d3(x, y, z)) }
contained_by { box{ -1.1, 1.1 } }
max_gradient 7
pigment{rgb 0.7} finish{reflection{0, 1} diffuse 1 ambient 0}
This scene renders for about 22 seconds on my computer in 640x480
resolution without anti-aliasing, which is pretty quick for me. If you
want lower/higher bumps adjust k. If you want more/less bumps adjust p.
Maxime
Maxime Marrow wrote:
> isosurface{
> max_gradient 7
The scene is slow even with a plain box { }
So I was hoping for a solution that would operate on mesh
You can create six heightfields from the same functions as the isosurface
and they may render even faster than a mesh.
// an object with 8 corners (clockwise front ABCD) (Clockwise rear EFGH)
#macro Free_Box(A B C D E F G H)
mesh {
triangle {A,B,C} //front
triangle {C,D A}
triangle {A,E,H} //left
triangle {A,D,H}
triangle {B,F,G} //right
triangle {B,C,G}
triangle {A,E,F} //top
triangle {A,B,F}
triangle {C,G,H} //bottom
triangle {C,D,H}
triangle {E,F,G} //back
triangle {G,H,E}
inside_vector <(A.x+G.x)/2,(A.y+G.y)/2,(A.z+G.z)/2>
You might want to move the inside vector outside the box
to invert it, and it's up to you to keep the walls flat.
