POV-Ray : Newsgroups : povray.general : Vector calculation/rotation problem Server Time
6 Mar 2026 17:20:35 EST (-0500)
  Vector calculation/rotation problem (Message 1 to 7 of 7)
Subject: Vector calculation/rotation problem
Date: 16 Feb 2008 09:04:58
Message: <47b6ed8a@news.povray.org>
I'm trying to create a random uniformly distributed vector through a
hemisphere positioned at the intersection point between ray and an
object. I can already create a random vector but how do I quickly/easily
rotate it based on the desired hemisphere orientation?
I use left-handed coordinatesystem: x is right, y is up, and z is forward.
Let's have a vector V which is random vector inside a hemisphere which
has a pole at 0,1,0 (just like the northern hemisphere of Earth). I want
to orient the vector inside a hemishere which has a pole pointing at
vector N. How do I do this? I'd prefer something that can be done
without expensive trigonometric functions - if possible.
PS. If this is the wrong forum, please advice.
Subject: Re: Vector calculation/rotation problem
Date: 16 Feb 2008 09:09:03
Message: <47b6ee7f$1@news.povray.org>
Example:
V = (0.71, 0.71, 0) //The random vector in "northern hemishpere")
N = (-1,0,0) //The pole I want to orientate the random vectors to)
The result is
Vnew = (-0.71, 0.71, 0)
Date: 16 Feb 2008 14:38:32
Message: <47b73bb8$1@news.povray.org>
> Example:
> The result is
Some relevant macros in transforms.inc:
vtransform(vec, trans)
Reorient_Trans(Axis1, Axis2)
Point_At_Trans(YAxis)
I don't have time to test this, but I think this will work:
   #include "transforms.inc"
   #declare P = <0, 1, 1>;
   #declare N = <-1, 0, 0>;
   #declare V = <0.71, 0.71, 0>;
   #declare Vnew = vtransform(V, Reorient_Trans(P, N));
This should also work:
   #declare Vnew = vtransform(V, Point_At_Trans(N));
Tor Olav
http://subcube.com
Date: 16 Feb 2008 19:11:07
Message: <47b77b9b@news.povray.org>
#local vX=vnormalize(vcross(vN,<vN.y,vN.z,-vN.x>));
#local vY=vnormalize(vcross(vX,vN));
#local sN=rand(YourRandomSeed);
#local sL=sqrt(1-sN*sN);
#local Angle=rand(YourRandomSeed)*360;
#local vResult=sN*vN
   + vrotate(x,y*Angle).x * vX * sL
   + vrotate(x,y*Angle).z * vY * sL ;
vResult is a vector in the hemisphere that faces in the direction of vN.
John
Date: 16 Feb 2008 22:30:58
Message: <47b7aa72$1@news.povray.org>
>> Example:
>> The result is
Hmmm... I wonder where I got the <0, 1, 1> vector from.
This is what I should have written:
   #declare P = <0, 1, 0>;
Tor Olav
http://subcube.com
Date: 17 Feb 2008 06:09:45
Message: <47b815f9@news.povray.org>
Thanks, but I'm actually interested in general solution without
resorting to functions provided by PovRay. As it is probably OT here,
I'll post the question to OT.
Date: 17 Feb 2008 19:53:12
Message: <47b8d6f8@news.povray.org>
The code below is based on John's solution (but with some
simplifications). Most of the functions special to POV-Ray
has been replaced by common functions.
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.6;
#declare vN = <2, 1, 3>;
#declare SS = seed(6457);
#declare Cnt = 20;
#declare vY =
   vN/sqrt(vN.x*vN.x + vN.y*vN.y + vN.z*vN.z);
#declare vX =
   <vY.z, 0, -vY.x>/sqrt(vY.x*vY.x + vY.z*vY.z);
#declare vZ =
   <vX.y*vY.z - vX.z*vY.y, vX.z*vY.x - vX.x*vY.z, vX.x*vY.y - vX.y*vY.x>;
cylinder { 0*y, vX, 0.03 pigment { color rgb <2, 1, 1> } }
cylinder { 0*y, vY, 0.03 pigment { color rgb <1, 2, 1> } }
cylinder { 0*y, vZ, 0.03 pigment { color rgb <1, 1, 2> } }
#declare I = 0;
#while (I < Cnt)
   #declare sN = rand(SS);
   #declare sL = sqrt(1 - sN*sN);
   #declare Angle = -2*pi*rand(SS);
   #declare vResult = sN*vY + sL*(cos(Angle)*vX + sin(Angle)*vZ);
   cylinder { 0*y, vResult, 0.01 pigment { color rgb <1, 1, 1> } }
   #declare I = I + 1;
#end // while
background { color rgb <0.0, 0.0, 0.5> }
light_source { <1, 1, 1>*100 color rgb <1, 1, 1> }
   location <3, 1, 2>
   look_at <0, 0, 0>
Tor Olav
http://subcube.com
