One question that will likely come up in the FLOSS interview on
Wednesday is how POV-Ray renders clouds. I have an answer from when I
used to write cloud textures years ago - procedural textures with shades
of gray and transparency and a gradient sphere.
Is there a better more modern way to create spectacular clouds? Many of
the clouds I'm seeing seem to go beyond the simple texturing technique I
used to use.
Thanks
David Buck
David Buck nous apporta ses lumieres en ce 2008/02/04 11:41:
> used to use.
> Thanks
> David Buck
Volumetric clouds using scattering media.
Lutheran: If shit happens, don't talk about it.
one simpler and cost-effective way to render better clouds than simple textures
is the so-called stacked sky technique as employed by Jaime Vives Piqueres:
http://www.ignorancia.org/en/index.php?page=Stacked_Planes
not as impressive as true scattering media clouds, but insanely faster! And
much better looking than just single texture.
David Buck skribis:
> used to use.
Project Tierra, an automated landscape generation macro by Jaime Vives Piqueres
has the most beautiful clouds I've ever seen in POV-ray. It contains macros for
both cumulus and cirrus clouds, and the basic technique for creating one cloud
is this (if I read the code correctly).
1. Creating a union of spheres randomly jittered about a central point.
2. Using this union object as a pigment function. (Inside = 1, outside = 0)
3. Adding some turbulence for fluffiness.
4. Using the resulting function as a density function for a scattering medium.
See for yourself at:
http://www.ignorancia.org/en/index.php?page=Project_Tierra
Personally, I like this macro so much I want to have sex with it.
Hymyly.
And there was light.
whoa! You sure know this guy has been raytracing too long! :D
"David Buck" <dav### [at] simberon com> wrote in message
news:47a7404c$1@news.povray.org...
> One question that will likely come up in the FLOSS interview on Wednesday
> is how POV-Ray renders clouds. I have an answer from when I used to write
> cloud textures years ago - procedural textures with shades of gray and
> used to use.
I tend to use my own fastclouds macro, which uses a texturing technique that
is slightly more complicated than the with povray included cloud-textures.
some examples:
http://www.povplace.com/gallery/Experiments/newfastclouds.jpg
http://www.povplace.com/gallery/Experiments/flares_test1.jpg
It's not as goodlooking, or as flexible as volumetric clouds, even stacked
planes look better (or stacked spheres, as I used here:
http://www.povplace.com/gallery/IRTC/zee.jpg ), but it renders a LOT faster
cu!
_(0x+y.5+y/2x)_(0x-y.5+y/2x) // ZK http://www.povplace.com
oh! I've seen this scene before... very good looking... stacked spheres?!
> stacked spheres?!
Concentric, I guess.
Everyone mentions volumetric clouds, but nobody gives an example,
so here's one:
http://www.oyonale.com/image.php?lang=en&mode=info&code=432§ion=2003
"Nicolas Alvarez" <nic### [at] gmail is the best com> wrote in message
news:47a75dfb$1@news.povray.org...
>> stacked spheres?!
yep, that's what I meant :)
cu!
