POV-Ray : Newsgroups : povray.general : Photon Map: Created at Lower Res than Scene? Server Time
6 Nov 2026 19:41:36 EST (-0500)
  Photon Map: Created at Lower Res than Scene? (Message 1 to 50 of 54)
Goto Latest 50 Messages Next 4 Messages >>>
Subject: Photon Map: Created at Lower Res than Scene?
Date: 26 Jan 2008 19:10:37
Message: <479bcbfd@news.povray.org>
Hi.
I have a scene, which already takes around 6 days to create the photon map
for, if it is done in the same resolution like the remaining scene.
I would like to know, if it is possible to use a lower resolution (let's
say: 400x300) for the photon map (with the "save_file" option enabled), and
then to stop and continue the scene in a high resolution (now with the
"load_file" option enabled).
Sven
Subject: Re: Photon Map: Created at Lower Res than Scene?
Date: 26 Jan 2008 19:41:16
Message: <479bd32c@news.povray.org>
It's possible. The photon map is independent from the image resolution.
Which also means that calculating the photon map when rendering at
400x300 will take exactly the same time as any other higher resolution.
Date: 26 Jan 2008 20:32:32
Message: <479bdf30$1@news.povray.org>
Sven Littkowski wrote:
> Hi.
Sure, I do it myself.  However, since the photon map is independent from
the scene resolution, you can set the image size absurdly low (like +w1
+h1) and still get a full-quality photon map.
...Ben Chambers
www.pacificwebguy.com
Date: 26 Jan 2008 23:52:51
Message: <479c0e23@news.povray.org>
Hi Ben,
but even so, based on what I heard already, meanwhile, the photon map would
still take 6 days, right?
Sven
"Chambers" <ben### [at] pacificwebguycom> schrieb im Newsbeitrag
news:479bdf30$1@news.povray.org...
>> Hi.
>> map for, if it is done in the same resolution like the remaining scene.
>> and then to stop and continue the scene in a high resolution (now with
>> the "load_file" option enabled).
> ...Ben Chambers
Date: 27 Jan 2008 02:24:36
Message: <479c31b4$1@news.povray.org>
try using image_width to choose the photon count/spacing
Sven Littkowski napsal(a):
> Hi Ben,
> Sven
>>> Hi.
>> ...Ben Chambers
Date: 27 Jan 2008 10:57:37
Message: <479ca9f1$1@news.povray.org>
Hmm... THAT sounds interesting and promising, Jan. I looked into the POV
help file, and see the keywords "image_width" and "image_height". And also
some examples, how to use them. I really think, this could shorten the
calculation time, if I can find out, how to use them properly in connection
with my photon map creation.
Jan, can you give me some more advice in this? If you like, I could post the
scene file to you. Please let me know. Thanks,
Sven
"Jan Dvorak" <jan### [at] centrumcz> schrieb im Newsbeitrag
news:479c31b4$1@news.povray.org...
>> Hi Ben,
>> would still take 6 days, right?
>> Sven
>>>> Hi.
>>>> (let's say: 400x300) for the photon map (with the "save_file" option
>>>> enabled), and then to stop and continue the scene in a high resolution
>>>> (now with the "load_file" option enabled).
>>> ...Ben Chambers
Date: 27 Jan 2008 17:02:39
Message: <479cff7f@news.povray.org>
You might decide to shoot image_width*image_height*some_constant
photons. Some_constant==1 might work well but feel free to increase for
high quality or decrease for faster render. Use the count keyword and
watch POV-ray do its best.
> Sven
>>> Hi Ben,
>>> Sven
>>>>> Hi.
>>>> ...Ben Chambers
Date: 27 Jan 2008 18:15:49
Message: <479d10a5$1@news.povray.org>
Shooting the image with those keywords... Hmm, do you mean that I need to
put these two keywords inside the camera directive? To be honest, due the
lack of experience and knowledge with these two keywords, i would just like
to ask you to give an example where and how to use these two keywords in a
scene. I think, that should help me.
Thanks, Jan.
Sven
news:479cff7f@news.povray.org...
> You might decide to shoot image_width*image_height*some_constant photons.
> Some_constant==1 might work well but feel free to increase for high
> quality or decrease for faster render. Use the count keyword and watch
>> also some examples, how to use them. I really think, this could shorten
>> the calculation time, if I can find out, how to use them properly in
>> connection with my photon map creation.
>> the scene file to you. Please let me know. Thanks,
>> Sven
>>>> Hi Ben,
>>>> Sven
>>>>>> Hi.
>>>>>> photon map for, if it is done in the same resolution like the
>>>>>> remaining scene.
>>>>>> resolution (now with the "load_file" option enabled).
>>>>> from the scene resolution, you can set the image size absurdly low
>>>>> (like +w1 +h1) and still get a full-quality photon map.
>>>>> ...Ben Chambers
Date: 27 Jan 2008 21:38:17
Message: <479d4019@news.povray.org>
global_settings{
   photons{
     count image_width*image_height
untested
> Thanks, Jan.
> Sven
>>> Sven
>>>>> Hi Ben,
>>>>> Sven
>>>>>>> Hi.
>>>>>>> remaining scene.
>>>>>> ...Ben Chambers
Date: 27 Jan 2008 21:50:18
Message: <479d42ea$1@news.povray.org>
[Posting to newsgroup since other people may be interested]
Now that you sent me the files... The scene is quite slow to render
(55pps) even without radiosity or photons. I tried with photons, and
there were very long periods where the "photons shot" counter didn't
change, which could mean POV-Ray is shooting lots of photons but
"missing the object".
What I'm suspecting is that POV-Ray is creating sub-optimal bounding
boxes. I see a lot of difference objects on your scene. POV-Ray
sometimes does a bad job bounding difference/intersection CSG.
I'm now rendering a 160x120 image to see the raytrace statistics at the
end, and see if there were a lot of misses or not. Stay tuned...
Date: 27 Jan 2008 22:05:32
Message: <479d467c$1@news.povray.org>
Ray->Shape Intersection          Tests       Succeeded  Percentage
Plane                          3224478          124068      3.85
Torus                         12394622          976314      7.88
Torus Bound                   12394622         1072053      8.65
Cone/Cylinder                103967072        15537453     14.94
CSG Intersection              95235655        24004815     25.21
Sphere                        48158288        13067745     27.13
CSG Union                     28433556        12742408     44.81
Box                          261303211       123172730     47.14
Light Buffer                 418693292       219308071     52.38
Blob                          96908476        51630734     53.28
Blob Bound                   883968592       471672540     53.36
Bounding Box                 166046777       100557601     60.56
Vista Buffer                   2803512         1912181     68.21
Blob Component               317778794       254071826     79.95
CSG Merge                     25841750        25837528     99.98
(table sorted by percentage)
Intersection wasn't as bad as I expected. Torus has a particularly low
value. Plane calculation is quite fast, so that one isn't important.
It's still possible that some manual bounding could improve things.
Date: 27 Jan 2008 22:20:05
Message: <479d49e5@news.povray.org>
Nicolas Alvarez napsal(a):
>> the end, and see if there were a lot of misses or not. Stay tuned...
torus is tested only if its bound fails. It is bounded by a tight
difference of two cyliders.
Date: 27 Jan 2008 22:27:39
Message: <479d4bab$1@news.povray.org>
Interesting fact. I knew it, now that you mention it; but I didn't
remember (been a while since I read it).
Any idea why both torus and its bounding shape have such low hit percentage?
Date: 27 Jan 2008 22:31:31
Message: <479d4c93$1@news.povray.org>
Photon count went up until a minute of shooting passed, then it got
stuck at 41294 photons shot. Been at that number for *20 minutes*.
There is clearly some bounding issue!
Date: 28 Jan 2008 00:00:29
Message: <479d616d$1@news.povray.org>
> percentage?
It seems that the number of torus bound tests is used to calculate the
success percentage. See the table, rays shot. The actual success rate
for torus in that table is 976314/1072053=91%
Date: 28 Jan 2008 01:27:13
Message: <479d75c1@news.povray.org>
Thanks!
Sven
news:479d4019@news.povray.org...
> global_settings{
>   photons{
> untested
>> like to ask you to give an example where and how to use these two
>> keywords in a scene. I think, that should help me.
>> Thanks, Jan.
>> Sven
>>>> POV help file, and see the keywords "image_width" and "image_height".
>>>> And also some examples, how to use them. I really think, this could
>>>> shorten the calculation time, if I can find out, how to use them
>>>> properly in connection with my photon map creation.
>>>> post the scene file to you. Please let me know. Thanks,
>>>> Sven
>>>>>> Hi Ben,
>>>>>> Sven
>>>>>>>> Hi.
>>>>>>>> remaining scene.
>>>>>>>> option enabled), and then to stop and continue the scene in a high
>>>>>>> ...Ben Chambers
Date: 28 Jan 2008 01:32:21
Message: <479d76f5$1@news.povray.org>
Definatively, I will stay tunes! I am eager for the result, as well as I am
in such a big need for that photon map file!
Be assured, you will like what you see, as soon as you can see the image
itself.
The object(s) even allow you to set different day or night times (which
influences the light inside the scene), as well as you have influence on the
object self (such as rotor rotation and anges, open doors, etc.).
Best greetings,
Sven
"Nicolas Alvarez" <nic### [at] gmailisthebestcom> schrieb im
Newsbeitrag news:479d42ea$1@news.povray.org...
> (55pps) even without radiosity or photons. I tried with photons, and there
> were very long periods where the "photons shot" counter didn't change,
> which could mean POV-Ray is shooting lots of photons but "missing the
> object".
> boxes. I see a lot of difference objects on your scene. POV-Ray sometimes
Date: 28 Jan 2008 06:32:49
Message: <479dbd61$1@news.povray.org>
Hi Sven!
I haven't seen your scene or know anything about it, but it could be
that two of Mike's excellent tutorials could help you with your bounding
issues:
Mike's isosurface tutorial:
http://www.econym.demon.co.uk/isotut/
Mike's holes tutorial:
http://www.econym.demon.co.uk/holetut/index.htm
HTH,
Florian
Date: 28 Jan 2008 08:41:16
Message: <479ddb7c$1@news.povray.org>
Hi Jan,
I added that line to my photon global statement, and so far, I recognize
that POV-Ray behaves very different to how it was doing the map before.
Yes, there is a clear speed bonus, I recognized that when setting POV to a
resolution of 160x120. Now I have started at 3200x2400, and wait until some
result or crash comes. The blocks of photos are now much smaller (before:
ca. 40,000 before each break, now only 320). I will keep you up to date.
Sven
"Sven Littkowski" <sven [] jamaica-focus [] com> schrieb im Newsbeitrag
news:479d75c1@news.povray.org...
> Thanks!
> Sven
>> global_settings{
>>   photons{
>> untested
>>> to put these two keywords inside the camera directive? To be honest, due
>>> the lack of experience and knowledge with these two keywords, i would
>>> just like to ask you to give an example where and how to use these two
>>> Thanks, Jan.
>>> Sven
>>>>> Sven
>>>>>>> Hi Ben,
>>>>>>> map would still take 6 days, right?
>>>>>>> Sven
>>>>>>>>> Hi.
>>>>>>>>> remaining scene.
>>>>>>>> ...Ben Chambers
Date: 28 Jan 2008 08:51:54
Message: <479dddfa$1@news.povray.org>
Thanks, Florian. I am gonna check 'em out.
Sven
"Florian Brucker" <tor### [at] torfboldcom> schrieb im Newsbeitrag
news:479dbd61$1@news.povray.org...
> Hi Sven!
> issues:
> HTH,
> Florian
Date: 28 Jan 2008 10:51:30
Message: <479dfa02$1@news.povray.org>
>> I tried with photons, and there were very long periods where the
>> "photons shot" counter didn't change, which could mean POV-Ray is
>> shooting lots of photons but "missing the object".
12 hours later, 208446 photons shot.
Date: 28 Jan 2008 12:15:16
Message: <479e0da4@news.povray.org>
My PC came to around 32,000, before it crashed. Let's see...
Sven
Newsbeitrag news:479dfa02$1@news.povray.org...
>> Photon count went up until a minute of shooting passed, then it got stuck
Date: 28 Jan 2008 12:20:46
Message: <479e0eee$1@news.povray.org>
I added autostop 0.0. It's supposed to improve speed. The manual says
"always use autostop unless it causes problems". I can't tell if it
"causes problems" until I see the final image :)
Date: 28 Jan 2008 16:04:27
Message: <479e435b@news.povray.org>
Elapsed: 17h 41m
Photons shot so far: 249561
I still see extremely long periods of the counter not moving.
Date: 28 Jan 2008 20:10:02
Message: <479e7cea@news.povray.org>
Autostop? Hmm, I just checked the help manual. Interesting! I added it to my
photon map.
Render Time: Seems, your PC renders fast, too.. Your one is even faster
since I had to run plenty other programs at the same time. I reached the
30,000s on day 3. You should reach them on the 24th hour, I think.
Then it will get exciting. Then it will be the time to see, if your system
masters the crash borderline where my system failed, or not. The countdown
is on.
Sven
Newsbeitrag news:479e435b@news.povray.org...
> Elapsed: 17h 41m
Date: 29 Jan 2008 15:50:12
Message: <479f9184$1@news.povray.org>
> Elapsed: 17h 41m
Elapsed: 1d 15h 26m
Photons shot: 578211
Date: 29 Jan 2008 20:18:51
Message: <479fd07b$1@news.povray.org>
You passed the crash borderline and are on unknown ground now. That will
become the mother of all photon map files!
Please keep on keeping me up to date - I am excited to hear more!
Big thanks, best greetings,
Sven
Newsbeitrag news:479f9184$1@news.povray.org...
>> Elapsed: 17h 41m
> Elapsed: 1d 15h 26m
Date: 29 Jan 2008 21:40:00
Message: <web.479fe300af2cf505e094060@news.povray.org>
Corageosly going where no other raytracer ever dared...
> That will
ah, the 1 GB photon map!
Date: 29 Jan 2008 21:53:31
Message: <479fe6ab$1@news.povray.org>
nemesis escribió:
>> That will
Not really. At the horribly-slow speed this is going, I saw POV-Ray only
using like 300MB of RAM, which means that's how much of the photon map
it generated. I have had my own scenes generate 1GB of photons in a few
minutes :) Let me check exactly how much RAM it's using now.
What?
8MB? And no CPU time?
IT FINISHED??
Date: 29 Jan 2008 22:03:38
Message: <479fe90a$1@news.povray.org>
It did finish! Here are some statistics.
Total rays traced: 1331912707
Biggest number shown in stats: 292325860305, the amount of tests done
against "Blob bound". Thanks POV-Ray for using 64-bit integers in stats!
2^32 rays are NOT enough for everybody :)
Roots tested: 37510258644
Number of photons shot:      1328994234
Surface photons stored:         1481333 (0.11% of total photons shot)
Priority queue insert:          1758546
Priority queue remove:          1023832
Gather function called:           37107
Gather radius expanded:               1
Peak memory used:          52514507 bytes (50MB)
Total Scene Processing Times
   Parse Time:    0 hours  0 minutes  2 seconds (2 seconds)
   Photon Time:  47 hours  5 minutes 12 seconds (169512 seconds)
   Render Time:   0 hours  7 minutes  1 seconds (421 seconds)
   Total Time:   47 hours 12 minutes 15 seconds (169935 seconds)
CPU time used: kernel 12.09 seconds, user 168811.69 seconds, total
168823.78 seconds
Image resolution was 160x120, since all I wanted was the photons. It
rendered at 6 pixels per minute.
The photon map file is only 29MB!
@Sven: I'll send you the photon map. Can I post the (tiny) image to the
newsgroup, or is the scene "secret"? :)
Date: 29 Jan 2008 22:04:18
Message: <479fe932$1@news.povray.org>
> I saw POV-Ray only
I mean 30MB of course; peak was only 50!
Date: 29 Jan 2008 23:00:01
Message: <web.479ff544af2cf505e094060@news.povray.org>
> > I saw POV-Ray only
yes, I like the fact that povray is very generous on memory consumption...
Date: 30 Jan 2008 06:07:45
Message: <47a05a81@news.povray.org>
Hi Nicolas,
first of all, thanks a lot for your render time! I appreciate it a lot! And
yes, i woukld love to get that photon map.
Wanna try a 3200 x 2400 photon map..?
Posting the Image:
sure, if you like, post it. But an image of only 160 x 120 is - emmm - not
thaaat big. I followed up the advices of some other well-informed POV users,
and used the following keywords inside the global PHOTON statement:
- count image_width*image_height
- autostop 0.0
Create a 3200 x 2400 photon map, and give a try to those keywords. They work
wonders! Might be, experimenting with their values might even bring
different optical results...
I am posting here soon a 800 x 600 version of the picture, but go ahead with
the smaller result. I would like it.
Best greetings, tons of thanks,
Sven
Newsbeitrag news:479fe932$1@news.povray.org...
>> I saw POV-Ray only using like 300MB of RAM
Message: <47a05a81$2@news.povray.org>
No, Nemesis, not quite. But this way:
"Sven's photon maps, the final frontier. These are the calculations of the
raytracer POV-Ray. Its five-year renders: To explore strange new crashes. To
seek out new pictures and new render arts. To boldly go where no render
program has gone before."
ORIGINAL
Starship Enterprise (Star Trek):
"Space, the final frontier. These are the voyages of the starship
Enterprise. Its five-year mission: To explore strange new worlds. To seek
out new life and new civilizations. To boldly go where no man has gone
before."
Sven
"nemesis" <nam### [at] gmailcom> schrieb im Newsbeitrag
news:web.479fe300af2cf505e094060@news.povray.org...
>> That will
Date: 30 Jan 2008 06:45:00
Message: <web.47a06207af2cf507b614c6a0@news.povray.org>
"to boldly go..."  yes, thanks!  All I ever got from ST was already dubbed to
portuguese...
"These are the calculations of the raytracer POV-Ray"... :)
> ORIGINAL
> before."
> Sven
> >> That will
Date: 30 Jan 2008 18:57:38
Message: <47a10ef2@news.povray.org>
Nicolas, if you want to post the pictureinside the images newsgroup, please
go ahead! i don't mind it at all! I owe you a lot of thanks!
Remember, I still need the photon map file.
Thanks again,
Sven
Date: 30 Jan 2008 19:06:44
Message: <47a11114@news.povray.org>
I rendered a 640x480 too, took a few hours :) Posting it now.
I already sent it to you... Maybe it got filtered?
Date: 31 Jan 2008 02:01:24
Message: <47a17244@news.povray.org>
That's a good idea, linking the photon quality to the image resolution.
  I would assume that if you find a good ratio for a lower resolution,
it would tend to be a  good ratio for a higher one as well?
...Ben Chambers
Date: 31 Jan 2008 02:03:16
Message: <47a172b4@news.povray.org>
>> That will
Been there, done that, crashed my PC at 2Gb utilized by POV-Ray alone :)
Note to self: 3Gb in your system doesn't get around the fact that most
XP programs are only able to address 2...
...Ben Chambers
Date: 31 Jan 2008 02:12:09
Message: <47a174c9@news.povray.org>
>>> That will
Addendum to note: Having 8GB in your system doesn't prevent Povray from
still having to use the swap space.
Ger
Date: 31 Jan 2008 06:00:00
Message: <web.47a1a928af2cf5028552b650@news.povray.org>
you guys are nuts! :P
Date: 31 Jan 2008 10:36:48
Message: <47a1eb10$1@news.povray.org>
Chambers, Ger:
Thanks for that information. I thought until now, the operating system
handles the RAM, and the programs just forward their RAM requests to Windows
which would give them, what they need.
I don't knew that programs self address the RAM.
Bad to hear that software developers don't want to work with higher RAM
addresses. Thought, if RAM is available, the programs could reach it
dynamically, independent from intented borderlines (2 GB).
Thanks for the information, greetings,
Sven
news:47a172b4@news.povray.org...
>>> That will
> Note to self: 3Gb in your system doesn't get around the fact that most XP
> ...Ben Chambers
Date: 31 Jan 2008 11:12:35
Message: <47a1f373$1@news.povray.org>
The issue is that the numbers used to address memory get too big for the
processor to handle. 32-bit pointers simply cannot reference memory
beyond 4 GB -- you need a 64-bit processor with a 64-bit operating
system and 64-bit applications to go beyond that.
Now, I may be wrong, but my understanding is that the 32-bit version of
Windows XP can't use more than 2GB *total* for the entire system.
(That's 4 GB minus 2 GB worth of addresses hard-coded in to refer to
hardware peripherals...) Microsoft helpfully released a patch that makes
memory beyond 2 GB show up as available in the information pane, but XP
still can't actually use it. :-D
Vista can handle 4 GB just fine, but that is offset by the operating
system itself using twice as much memory...
(Nice time to switch to Linux, BTW. We've had a 64-bit version of the OS
available much longer than Microsoft, and have had time to work most of
the compatibility kinks out!)
William Tracy
You know you've been raytracing too long when all your browser bookmarks
have something to do with raytracing.
    -- Taps a.k.a. Tapio Vocadlo
Date: 31 Jan 2008 11:17:09
Message: <47a1f485@news.povray.org>
> Chambers, Ger:
> Windows which would give them, what they need.
> Sven
Sven,
I think you have things mixed up. Any modern program lets the operating
system handle the memory. For a program to bypass the OS and try and do the
memory management itself is a sure way to disaster.
The difference is that the older Windows versions don't access anything
above 3GB because they can't address it. It's out of their range. The newer
versions do address it, and in my case with 64bit linux 2^128 bytes is the
theoretical limit (340282366920938463463374607431768211456 which is a LOT).
Having programs go for the "higher" ram addresses is old style DOS
programming.
And as an aside, I do have 8GB RAM and 12GB swap and still manage to have
povray crash with an "out of memory" error :)
Ger
Date: 31 Jan 2008 11:44:27
Message: <47a1faeb@news.povray.org>
I think there is a way to make it address up to 3GB; but if you have
4GB, you can't use it all unless you have a 64-bit system.
Date: 31 Jan 2008 13:57:50
Message: <47a21a2e$1@news.povray.org>
PAE lets you get around this.
Jim
Date: 31 Jan 2008 23:15:31
Message: <47a29ce3$1@news.povray.org>
Respect!   :-)
Sven
"Ger" <No.### [at] ThankYou> schrieb im Newsbeitrag
news:47a1f485@news.povray.org...
> Ger
Date: 31 Jan 2008 23:15:32
Message: <47a29ce4@news.povray.org>
Please more information on PAE. I would be very interested to hear your
experiences with it. And a link (but i am gonna search for it now, too).
Thanks!
Sven
"Jim Henderson" <nos### [at] nospamcom> schrieb im Newsbeitrag
news:47a21a2e$1@news.povray.org...
> Jim
Date: 31 Jan 2008 23:37:07
Message: <47a2a1f3@news.povray.org>
Physical (or Paged) Address Extensions.  Wikipedia has an article on it.
http://en.wikipedia.org/wiki/Physical_Address_Extension
Basically, it's very similar to the changes that led to 32-bit protected
mode.  If you've programmed in x86 assembly, you know about
segment:offset addressing.  PAE is a similar concept, but instead of
using 16-bit registers, it uses 32-bit registers.  The upshot is that you
can use it to address memory > 4 GB.
I've used it on Linux boxen that have 4 GB of memory or more (though at
least with SUSE Linux, the PAE-enabled kernels are installed if you have
> 2 GB of memory, and using it with less doesn't hurt anything.  I
believe in OpenSUSE/SLE11, they're going to just use PAE kernels
consistently as if you start with a machine with < 2 GB and then upgrade
to > 4 GB, you need to switch out the kernel currently).
Jim
 Jim Henderson, CNA6, CDE, CNI, LPIC-1
 Novell Training Services
Date: 1 Feb 2008 02:50:58
Message: <47a2cf62$2@news.povray.org>
Thanks, Jim. Hmm, sounds like it is made for Linux only. But let me research
a while on Wikipedia and so on...
Sven
news:47a2a1f3@news.povray.org...
> Jim
