Hello,
When I use double_illuminate in a radiosity scene it does nothing (it
does get double_illuminated by light_sources).
Here's a scene to illustrate:
default{finish{ambient 0}}
camera{location <3,4,5> look_at 0}
polygon{5,x,y,-x,-y,x pigment{rgb 1}double_illuminate translate z}
polygon{5,x,y,-x,-y,x pigment{rgb 1}double_illuminate translate -z}
background{rgb z}
global_settings{radiosity{}}
sphere{-y/2,0.5 texture{pigment{rgb y}finish{ambient 10 diffuse 0}}}
light_source{y/2,rgb x}
Is it a bug or it is intentional?
Jan Dvorak <jan### [at] centrum cz> wrote:
> Hello,
it's not a bug! There are no light sources in pure radiosity, so you shouldn't
expect an object to get "doubly illuminated". Use at least one light_source
together with radiosity.
It's the same for reflection: no light_sources, no reflection.
Hash: SHA1
?? Where did you see that? There is absolutely no relation between
light sources and reflections, and you *can* still get reflections
even if there are no light sources. Are you sure you didn't mean
"photons"?
Jerome
+------------------------- Jerome M. BERGER ---------------------+
| mailto:jeb### [at] free fr | ICQ: 238062172 |
| http://jeberger.free.fr/ | Jabber: jeb### [at] jabber fr |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFHN0JCd0kWM4JG3k8RAhJvAKCu+pTzyQ2NLRyAznT6MAEIyhuviQCgh+dp
R6HiqKJ0HNG8Yi8MHhDnL9Q=
=1mY/
-----END PGP SIGNATURE-----
nemesis nous apporta ses lumieres en ce 2007/11/11 12:28:
>> Hello,
You can always see an object with a high ambient value in a reflection without
any light.
Not the case with photons. No light_source = no photons.
Real Time, adj.:
Here and now, as opposed to fake time, which only occurs there
and then.
Alain napsal(a):
>>> Hello,
>> shouldn't
>> light_source
> without any light.
I use a plain white background + radiosity to light the scene. Or I use
a blue gradient and a yellowish light_source.
I would expect the front square to be illuminated by the green sphere
(ambient 10) in the example scene.
> any light.
oh! but that *is* a bug! :P
or presumibly the high ambient object is considered a light source?
=?ISO-8859-1?Q?=22J=E9r=F4me_M=2E_Berger=22?= <jeb### [at] free fr> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> "photons"?
no, I meant reflections: if there are no light sources, reflections *shouldn't*
be seen anywhere. If there are no light rays, what is tracing the reflective
images?
I remember lighting some test scene with pure radiosity and reflective materials
and getting no reflections at all. And it sounds ok to me.
nemesis napsal(a):
>> any light.
Yes. And that's the only way to make a solid object shine, AFAIK.
Hash: SHA1
>> "photons"?
> images?
In that case, if there are no light rays, what is tracing the
image? You should see a pure black image, which obviously you don't.
I'd be really interested to see such a scene if you could make one,
but you can't (unless you use the "no_reflection" keyword of
course). I have made some test scenes with pure ambient lighting
(neither light sources nor radiosity) and reflective materials and
the reflections showed just fine.
Jerome
iD4DBQFHN2dyd0kWM4JG3k8RAmCCAJj5GTkkQpTA39rdwzvMLxXtOTGRAJ4nyAkL
Ctw88J9Eu65F1dkeLI0B0g==
=zDmA
> course).
global_settings {
ambient_light 0
radiosity { brightness 1.2 }
union {
plane { y, -1 pigment { rgb 1 } finish { ambient 6 } }
sphere { -x, 1 pigment { rgb x } }
sphere { x, 1 pigment { rgb y } finish { reflection 1 }}
translate z*5
I can't see a thing. Reflections or otherwise.
yes, but you know ambient light is by itself faking a constant ambient lighting,
don't you? That's the hidden light by which povray is tracing the scene. No
lights, no reflection, nor image. nothing...
Let there be light! :)
You were talkang about light sources. Ambient light has no source.
> > any light.
Why?
true. But the point is: a raytracer works by tracing light rays. If there's
no light, there's no image.
I'm guessing that when povray sees at least ambient light enabled, it traces the
image by shooting light rays to get the basic image with the shadow areas
illuminated by constant color. I may be wrong. In any case, I don't think we
can get an image out of povray without tracing rays around. Radiosity and
photons are addons to the basic raytracing rendering framework...
> > > any light.
> Why?
> - Warp
because reflections without lights don't quite sound right...
A "light source" in POV-Ray terms is a "light_source" definition.
Surfaces (and media) can have non-black coloring even without any
light_source definitions.
ok, and how do you explain the reflections?
Well, if a surface has a non-black coloring even without light sources,
it's obviously going to reflect from reflective surfaces.
come on, warp, you know that's not the answer I want.
How is povray rendering those reflections?
If an object has a non-zero ambient, it doesn't need a lightsource to be
visible.
> visible.
that's all fine and dandy. What I'm asking for is how povray renders
reflections in the absence of traceable light rays.
nemesis napsal(a):
>> visible.
raytracers raytrace from the eye and when they hit a surface they split
or stop (or just turn around). This doesn't need any light_sources to work.
You should perhaps acquaint yourself with the basics of raytracing.
There's an intro for example here: http://en.wikipedia.org/wiki/Ray_tracing
Backwards raytracing works by sending rays from the camera towards the
scene. When a ray hits a surface, its color is calculated (from various
parameters, such as the pigment, light sources, etc). If the surface is
reflective, a new ray is spawned from that point, which can hit other
surfaces.
A surface doesn't need a light source in order to contribute color to
the ray.
>> visible.
POV-Ray traces rays from the camera to the objects. Then from the
intersection point on the object to the lightsources (if any!), to see
if there is any object on the way (for shadows), and with some
calculation based on the light angle, you get the basic object color. If
the object has ambient, it would have a non-black color even without lights.
If the object is reflective, more rays are traced from the intersection
point on the object to the other objects. That's why if one of those
rays hits an object that has ambient, it would show on the reflection
even without any light.
I should get some sleep... :P
I know raytracing works backwards, I don't know what I was thinking... sorry!
Subject: Re: radiosity vs. double_illuminate
Date: 12 Nov 2007 13:38:29
Message: <47389da5@news.povray.org>
Hash: SHA1
>> course).
You've just proved my point (if you go back to what I said but you
didn't quote). If you have neither light sources nor ambient then
you don't get an image, only pure black. This has nothing to do with
reflections. The bare minimum to get an image is to have some
ambient light, and then you will get reflections too.
Jerome
iD8DBQFHOJ2kd0kWM4JG3k8RAr2wAKC3UqHt8dOjab/T5mHmqpdJ4lAuWwCfYll/
XhuG2xbTs4afqKWHZMVxDiM=
=J/Mb
nemesis nous apporta ses lumieres en ce 2007/11/11 16:25:
>> course).
> global_settings {
> ambient_light 0
> union {
> translate z*5
It's obvious why you don't see anything: you set "ambient_light 0" in your
global_settings, whitch effectively negate your high ambient object.
The ambient_light should ONLY be used if you want to alter the coloration of the
ambient components for the whole scene.
ambient_light is multiplied with the ambient part of every finish. Anything
multiplied by zero equals zero.
Realy, in any radiosity scene lighted by ambient object, you MUST NEVER set
ambient_light to 0.
Rerun your sample scene as follow:
#default{finish{ambient 0 diffuse 1}}
union {
plane { y, -1 pigment { rgb 1 } finish { ambient 1 } }
translate z*5
Now, you can see everything. I've reduced your ambient 6 to 1 to prevent
oversaturation.
Real Time, adj.:
and then.
Jan Dvorak nous apporta ses lumieres en ce 2007/11/11 05:48:
> Hello,
> background{rgb z}
Working as expected.
The polygons are double_illuminate be the light_source (red), whitch contribute
on both faces.
They are lighted in blue from the background, giving that magenta tint.
The faces near the high ambient grees sphere are illuminated in green. They are
also affected by the other polygon, lighted in red, and, weekly, the blue
background.
You know you've been raytracing too long when you have ever brought your
computer to its knees by mistakenly launching 64 simultaneous frames to be
traced, while trying to maximizing the benefits of parallelizing them.
Carsten Whimster
> global_settings
and you realize it was intentional, don't you? The point was to prove that
without any ray sources at all, there's no *raytraced* images.
Anyways, I forgot raytracing works backwards, by shooting rays into the scene
and then, possibly, to light sources. Indeed, it can still work without light
rays, by just tracing rays to objects with high ambient values.
I forgot raytracing works backwards and was assuming the rays needed to trace
the reflections were rays coming from light sources. From there on, I assumed
when ambient lighting was present, povray automatically created a no_shadow
light_source to trace the scene. silly me...
Alain napsal(a):
>> Hello,
>> background{rgb z}
> contribute on both faces.
> They are also affected by the other polygon, lighted in red, and,
> weekly, the blue background.
As for MegaPOV 1.2.1 @ WinXP the front square doesn't get doubly
illuminated by the green sphere. Can you post your configuration, please?
Jan Dvorak nous apporta ses lumieres en ce 2007/11/13 00:25:
> Alain napsal(a):
>>> Hello,
>>> (it does get double_illuminated by light_sources).
>>> background{rgb z}
It's not double_illuminated by radiosity, and sould'nt be.
You know you've been raytracing too long when you've convinced your boss that
raytracing is really an integral part of your job title (and you really don't
work in a position that requires it).
Quietly Watching
Alain napsal(a):
>> Alain napsal(a):
>>>> Hello,
>>>> background{rgb z}
>>> green. They are also affected by the other polygon, lighted in red,
>>> and, weekly, the blue background.
How come it shouldn't?
Jan Dvorak nous apporta ses lumieres en ce 2007/11/13 10:09:
> Alain napsal(a):
>>> Alain napsal(a):
>>>>> Hello,
>>>>> background{rgb z}
>>> please?
Radiosity ignore double_illuminate, it never use samples comming from behind the
surface.
You can fake it as follow:
polygon{5,x,y,-x,-y,x pigment{rgb 1}double_illuminate translate z no_shadow}
polygon{5,x,y,-x,-y,x pigment{rgb 1}double_illuminate translate -z no_shadow}
background{rgb z}
global_settings{radiosity{count 1000 error_bound 0.9}}
#declare Offset = 1.05;
polygon{5,x,y,-x,-y,x pigment{rgb 1}double_illuminate translate Offset*z
finish{reflection 1} no_image no_shadow no_reflection}
polygon{5,x,y,-x,-y,x pigment{rgb 1}double_illuminate translate -Offset*z
This is you original scene with the following changes:
Added no_shadow on the original polygons.
Added 2 reflective polygons just outside the original ones, with no_everything.
That way, they reflect but don't show, don't have shadow and don't reflect on
each other.
Increased count, less that 1000 and you get artefacts.
Had also to reduce error_bound.
Bend the facts to fit the conclusion. It's easier that way.
This is meant to say that the POV code is written such that radiosity does not
use the double_illuminate flag, so it shouldn't be expected to act as such, not
that theoretically or conceptually it shouldn't (couldn't) be considered.
However, that brings up the question on whether it should or could be
implemented in future code (beta if it's very simple, patched versions for
those coding enthusiasts, POV4 beyond that)
Seeing as it's a feature that is present for traditional light sources, I don't
see why it shoulnd't be allowed to affect radiosity as well, but I don't know
how easy it would be to add to the source code, perhaps it's not a trivial
matter. This would be for the coders out there to decide.
-tgq
A double_illuminate feature in radiosity would make it slower because
then each radiosity ray would need to be doubled (for each regular radiosity
ray a second ray would also need to be spawned on the other side of the
surface).
Warp napsal(a):
> surface).
do you really mind? :-)
> surface).
True, but it also happens when you specify 100 samples instead of 50.
If being able to take double_illuminate into account in radiosity (it
seems that it makes sense, anyway) helps getting more realistic
pictures, it should be envisioned.
Fabien.
double_illuminate is not realistic. It doesn't correspond to any
physical phenomenon.
Subject: Re: radiosity vs. double_illuminate; interior texture
Date: 14 Nov 2007 04:57:55
Message: <473ac6a3$1@news.povray.org>
Warp napsal(a):
It does correspond to any surface that is thin enough to be translucent
but thick enough not to be transparent. A good example is a paper
(although the light path translute-diffuse reflect-translute is much
weaker than the direct reflection the double_illumination effect is very
strong if the paper is backlit).
Try taking two pieces of paper, the bottom one having been written on.
You only see the top one. Then backlight them - you can see clearly what
is written on the bottom side, which means paper is either a bit
transparent or a bit double_illuminated. Now lift the top one. You will
see the bottom paper's projection blur srongly, which means that paper
is translucent, not transparent. And that's what double_illuminate is for.
However, I do see a bit of unrealism:
- It's an object property. It should belong to a texture.
- It should be possible to regulare the amount of double_illumination.
Right now it is 1:1.
My idea is a back_diffuse keyword in the finish statement.
[diffuse]*[direct lighting*]+[back_diffuse]*[backlight*]=total
illumination. back_diffuse defaults to diffuse if double_illuminate is
set and 0 if unset. It causes a warning if both appear.
*including radiosity
- Povray should consider every texture layer, not just the top one.
-- Also I think that the default inside texture shoud be the outside one
*in the reverse order* (imagine gluing a few stickers onto a glass.
Which one do you see from the back side, the top one?). Or even forbid
interior_texture completely (it is more realistic but it reduces
artistic possibilities). But that's another chapter.
Date: 14 Nov 2007 05:22:47
Message: <473acc76@news.povray.org>
No, it doesn't. Just take any material you want and compare its
illumination on the side facing the light and on the opposite side.
The illumination is totally different. With double_illuminate the
illumination on both sides will be *identical*. This corresponds to
nothing in nature.
The only reason why double_illuminate exists in povray is because it's
so laughably easy to implement (it's a 1-liner: 1 single 'if' statement;
or more precisely, one additional condition in an existing 'if' statement),
and it can be used in certain situations to eg. alleviate some rendering
artifacts, as well as other purposes. It's not even intended to be a
physically accurate feature.
Emulating the illumination on the backside of a paper in a physically
accurate way would be quite laborious and slow.
double_illuminate might be a somewhat acceptable approximation in some
situations, assuming you are not seeing both sides at the same time (in
which case it would be very unrealistic).
Date: 14 Nov 2007 13:30:21
Message: <473b3ebd$1@news.povray.org>
Warp napsal(a):
> nothing in nature.
Read the "However, I do see a bit of unrealism" part.
