Is there any way to change the color that's rendered outside of the
circular image in a fisheye projection? I like the smooth dithering at
the border, but I'd like the corners to be light gray.
Subject: Re: change color of corners in fisheye?
Date: 24 Aug 2007 11:24:54
Message: <46cef846@news.povray.org>
Sorry about the from: address in the original article; I hadn't set up
the group yet.
Larry
From the source code for povray 3.6.1, the outside color is hard-coded to
black. The relevant file is render.cpp. It looks to be fairly easy to
patch povray's source code to make this outside color specifiable. Most of
the work would be for adding parsing of a new keyword in the SDL. Maybe
"outside_background" similar to "background"? (further discussion on
details probably should go in the unoffical patches forum)
Lacking an immediately available patch to do this, you are stuck having to
add your outside color in GIMP/Photoshop/whatever.
darenw <Gre### [at] comcast net> wrote:
> Most of
Yet another new keyword to the already-cluttered namespace? Please no.
Especially not when the keyword would be specific to one single feature
of one single camera type.
How about this syntax? That'd be better than a new keyword.
CAMERA_TYPE:
perspective | orthographic | fisheye [color]| ultra_wide_angle |
omnimax | panoramic | cylinder CylinderType | spherical
Thanks, Daren. I guess if I do actually change it, I'll take the "easy" way
out and compile it hard-coded, rather than adding an option.
Tim Attwood nous apporta ses lumieres en ce 2007/08/27 15:15:
> CAMERA_TYPE:
No new keyword, just an optional colour parameter defaulting to black. Clean,
simple (at least aparently), elegant solution.
An idea is not responsible for the people who believe in it.
Wait a minute... You mean it's *black* instead of *transparent*? Have
you tried rendering with +ua?
Hash: SHA1
The last time I tried fisheye with alpha, the top and left of the
background was transparent, and the bottom and right parts were black.
Fisheye + alpha seems buggy.
William Tracy
afi### [at] gmail com -- wtr### [at] calpoly edu
> ok I may be dumb here
Yeah, maybe.
-- Warp
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHACoPcCmTzQ++ZncRAoEcAJ4sFKTiR8AXqSXBpx5979MhnRZtIACeIuYY
PzezwI7pXjcQQNATq45Xrkc=
=MmFt
-----END PGP SIGNATURE-----
Time to submit a formal bug report?-)
Hash: SHA1
Is the POV development team still interested in bugs against 3.6?
William Tracy
You know you've been raytracing too long when your source files are
starting to get bigger than the image files.
-- Matt Amos
iD8DBQFHARJIcCmTzQ++ZncRAvPLAKCWRdHCUfF2vuusWStdAdJaBjKkWgCfWwOP
yVHBWfQqC/4rAVRqmo8yojw=
=LkxO
William Tracy nous apporta ses lumieres en ce 2007/10/01 11:29:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> William Tracy
Yes, if just not to port those bugs in the new version.
Don’t be irreplaceable. If you can’t be replaced, you can’t be promoted.
