POV-Ray : Newsgroups : povray.general : Fog > Light > Shadows Server Time
6 Nov 2026 20:19:38 EST (-0500)
  Fog > Light > Shadows (Message 1 to 16 of 16)
Subject: Fog > Light > Shadows
Date: 17 May 2007 03:34:04
Message: <464c056c@news.povray.org>
Hi all
   Need a little help and advice if possible.
   I'm creating a scene that uses ground fog, and I'm getting blue shadows
cast from my objects. This doesn't look right to me, but then again, I can't
say that I've ever seen a shadow in fog. I'm using one area_light with
colour rgb 0.6.
   What would be the normal behaviour of light and then shadows in a fog
scene? What would be the best way to approach this, (as in, should there be
shadows at all, and what colour should they be if yes)?
      ~Steve~
Subject: Re: Fog > Light > Shadows
Date: 17 May 2007 06:04:06
Message: <464c2896$1@news.povray.org>
St. nous apporta ses lumieres en ce 17 / 05 / 2007 03:33:
> Hi all
> colour rgb 0.6.
>       ~Steve~
If you look in the documentation, you'll see that fog don't interact with light.
How does your shadows look without the fog in your scene? Dou you use a blue
fill light? Is your fog coloured? All of those can make the shadows blue.
EVERYTHING HAS A GENDER
You may not know this but many nonliving things have a gender...
A Web Page is Female, because it's always getting hit on.
Date: 17 May 2007 07:21:48
Message: <464c3acc$1@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:464c2896$1@news.povray.org...
> light.
> blue fill light? Is your fog coloured? All of those can make the shadows
> blue.
    I've posted a couple of examples in p.b.i Alain. The shadow without the
fog looks normal to me, (maybe too dark though), and I'm not using a fill
light. My fog colour is the same as my light colour, rgb 0.6. I'm just
wondering if it's to do with the height of my light, as it's only 70 units
high. Would it be better if I used something that more resembles the sun?
    ~Steve~
> Alain
Date: 17 May 2007 09:24:38
Message: <464c5796$1@news.povray.org>
>I'm just wondering if it's to do with the height of my light, as it's only
>70 units
> high.
   Hmm, no, it's not the height, that just sharpens the shadow.
    ~Steve~
Date: 17 May 2007 09:37:53
Message: <464c5ab1$1@news.povray.org>
>> 70 units
>> high.
Is it possible to post a minimal scene that reproduces the blue
shadow..? I'm curious, now.
Date: 17 May 2007 10:01:04
Message: <464c6020$1@news.povray.org>
"Mike Raiford" <mra### [at] hotmailcom> wrote in message
news:464c5ab1$1@news.povray.org...
> Is it possible to post a minimal scene that reproduces the blue shadow..?
> I'm curious, now.
  I think it's my assumed_gamma Mike. I've just tried it with 2.2 which
makes the whole image too dark (but the shadow looks ok), and 1, and that's
better, but still too dark, (now with a darker blue shadow). At .75, the
overall image looks fine, (the right brightness, contrast, etc.), apart from
the blue shadow.
  Hmm, what to do, what to do...
   ~Steve~
  global_settings {
  assumed_gamma .75 max_trace_level 60 }
fog {
  fog_type   2
  distance   75
  colour      rgb 0.6
  fog_offset 0.005
  fog_alt    0.2
  turbulence 1
  turb_depth .5
light_source {
  0*x
  colour rgb 0.6
  area_light
  <8, 0, 2> <2, 0, 8>
  4, 4
  adaptive 0
  jitter
  circular
  translate <30, 70, -30>
Date: 17 May 2007 11:08:38
Message: <464c6ff6@news.povray.org>
>> I'm curious, now.
> the blue shadow.
>    ~Steve~
Hm. The code you included with this post doesn't exhibit much of
anything, just a gray fog with a darker gray background.
What version of POVRay are you using?
Date: 17 May 2007 12:16:27
Message: <464c7fdb$1@news.povray.org>
news:464c6ff6@news.povray.org...
> Hm. The code you included with this post doesn't exhibit much of anything,
  That's all there is apart from Wings models and some PovTree's. As it is
now, the scene looks quite good and I'm happy with it, I'm just not getting
the assumed_gamma thing. It's confusing me because it should either be 2.2
or 1 (from what I've read). FWIW, nearly all of my images over the last two
years use a low assumed_gamma. Where am I going wrong with this?
      Yes, sorry, 3.5.
    ~Steve~
Date: 17 May 2007 22:49:10
Message: <464d1426@news.povray.org>
Are you using radiosity? A blue sky
can tint the fog blue if you are using
radiosity.
What are the textures? Are any reflective?
Date: 18 May 2007 02:44:01
Message: <464d4b31$1@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> wrote in message
news:464d1426@news.povray.org...
> radiosity.
     No radiosity and I've removed my sky_sphere - no difference.
     The textures are image maps with bump mapping and the only thing that's
reflective is a small model which I don't think would make a difference.
     I've settled for having the assumed_gamma at 1.2, which makes the
scene/shadow better, but darker overall.
      ~Steve~
Date: 22 May 2007 12:42:51
Message: <46531d8b@news.povray.org>
St. wrote:
> Hi all
Steve,
Does your fog use color filtering? If yes, try to use it without. In
addition to raising the assumed_gamma, try increasing the intensity of
your light to compensate. Failing that, make sure all your objects are
hollow, as this can sometimes result in weird fog effects, not just
complete absence. Beyond these things, there are a bunch of other things
you could try. The first that comes to mind is a transparent (and
hollow) sphere around the camera with a transmit greater than 1. This
will bump up the contrast of the image, and may give you the results you
want (at the expense of render time). The good thing about POV-Ray is
that there are usually a number of ways to arrive at a desired result.
Try anything that sounds like it might be useful!
~Sam
Date: 23 May 2007 08:02:30
Message: <46542d56$1@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:464c7fdb$1@news.povray.org...
> getting the assumed_gamma thing. It's confusing me because it should
> either be 2.2 or 1 (from what I've read). FWIW, nearly all of my images
> over the last two years use a low assumed_gamma. Where am I going wrong
> with this?
assumed_gamma should be 1 for the best simulation of light. Povray will
gamma correct the image from the "assumed" gamma to the "actual" gamma which
is stored in one of it's ini files. The ini file value is 2.2 so if you want
no gamma correction use the (default) assumed_gamma 2.2. But, light by
definition has linear gamma, whereas monitors have non-linear gamma (50%
grey is not half the brightness of white on a monitor), so assumed_gamma 1
tells pov to do all it's maths as if they have a gamma of 1, then to
implicitly correct that to a gamma of 2.2 for the image. It's VERY counter
intuitive!
I've tried your source with a simple scene and I can't get any blue.
assumed_gamma won't be the cause, it will just be adjusting the brightness
of the error. Has anything in the scene got negative colour values? e.g.
negative ambient light?
Tek
http://evilsuperbrain.com
Date: 26 May 2007 05:17:48
Message: <4657fb3c$1@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:46531d8b@news.povray.org...
> you could try. The first that comes to mind is a transparent (and hollow)
> sphere around the camera with a transmit greater than 1. This will bump up
> the contrast of the image, and may give you the results you want (at the
  AHA! Thank you for this tip Sam! I've tried it and it works, well, it's
given me the extra option of adjusting both the transmit (around the camera)
and the assumed_gamma at the same time, and I've found a combination that
takes a lot of the blue away whilst leaving a nice contrast. Brilliant!  :o)
   ~Steve~
> ~Sam
Date: 26 May 2007 05:17:49
Message: <4657fb3d@news.povray.org>
news:46542d56$1@news.povray.org...
>> with this?
> which is stored in one of it's ini files. The ini file value is 2.2 so if
> you want no gamma correction use the (default) assumed_gamma 2.2. But,
> light by definition has linear gamma, whereas monitors have non-linear
> gamma (50% grey is not half the brightness of white on a monitor), so
> assumed_gamma 1 tells pov to do all it's maths as if they have a gamma of
> 1, then to implicitly correct that to a gamma of 2.2 for the image. It's
> VERY counter intuitive!
     Hmm, now I get it, thanks Tek, I think I'll leave it at 1 from now on
and use Sam' trick too.
    No, not a negative ambient light, but my ground texture is negative,
would that also create that blue in combination with the fog? I'll have a
play and see what happens.
      ~Steve~
> Tek
Date: 26 May 2007 05:30:13
Message: <4657fe25@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:4657fb3d@news.povray.org...
Yep, grey fog - yellow ground texture = blue
Povray's accurately calculating something impossible!
Tek
Date: 26 May 2007 10:48:38
Message: <465848c6$1@news.povray.org>
news:4657fe25@news.povray.org...
   Ok, now we're getting closer, and if I play with my texture some more, I
should be able to eliminate it altogether and get something satisfactory.
      TY.   :)
    ~Steve~
> Tek
