POV-Ray : Newsgroups : povray.general : Storing height_field mesh between frames of an animation Server Time
6 Nov 2026 20:27:39 EST (-0500)
  Storing height_field mesh between frames of an animation (Message 1 to 14 of 14)
Subject: Storing height_field mesh between frames of an animation
Date: 10 Mar 2007 20:34:16
Message: <45f35c98$1@news.povray.org>
Hi all,
I am using a heightfield in an animation that takes about 5 seconds to
process for each frame. Is there any way to store the heightfield mesh
in memory between frames, or perhaps write it to a file (although that
won't provide much speed up I think)?
Perhaps it is just my ignorance and it is possible, but it would be
really nice to be able to operate on POV-Ray's internal data structures
directly using SDL.
Cheers.
Subject: Re: Storing height_field mesh between frames of an animation
Date: 11 Mar 2007 09:16:36
Message: <45f40f44@news.povray.org>
scam nous apporta ses lumieres en ce 10-03-2007 20:34:
> Hi all,
> directly using SDL.
> Cheers.
If your heightfield is generated from a function, you can save it to a file
during the first frame. Then, you reload it for each subsequent frame. It should
be faster then recreating it everytime.
You can also preprocess it and save is as a heightfield image file, use hf_16 to
get beter vertical resolution. Save as a TGA file. That's the way it was dome
before the use of function was implemented.
Create the heightfield with an amplitude of 1 unit in a plane perpendicular to
the camera. Use an orthographic camera. Apply this texture:
texture{gradient z }finish{ambient 1}}
Change the gradient orientation if needed.
Everything can be filed under "miscellaneous".
Date: 11 Mar 2007 12:11:35
Message: <45f43847@news.povray.org>
  There's no way of storing a heightfield in a file. You can store a mesh,
but a mesh is not the same thing as a heightfield (lighting is different).
Date: 11 Mar 2007 17:35:01
Message: <web.45f482e0da84c92558a931fb0@news.povray.org>
How feasible would it be to write a patch whereby you could store an object
(like a mesh or heightfield) in memory, and then reference that object's
memory address as opposed to the object in your scene file?
If a function could be written that could store any povray object/data
structure in memory for later use I think many people would be able to find
a use for it.
Date: 11 Mar 2007 20:41:13
Message: <45f4afb9$1@news.povray.org>
scam wrote:
> Hi all,
I understand the situation, but I don't see what the problem is.
Unless you meant five minutes (still not bad for an animation) or five
hours (which would be something worth worrying about).
John
Date: 11 Mar 2007 20:46:01
Message: <45f4b0d9$1@news.povray.org>
Sure you can.  You have POV-Ray render the height_field with a gradient
texture running from rgb <0,0,0> to rgb <1,1,1>, with the hf_gray
setting on.  The high parts of the height_field are white, and the low
parts are black.  The height_field is saved as a picture in the render
output file.
Oddly enough, this is what Alain described.
If the original poster is generating a large height field from a
function or pigment pattern (which I did for a recent IRTC entry), he
can try breaking up the height_field into several smaller sections (of
equal precision, or he'll get cracks between sections), and test them to
see which are on-camera and which aren't.
Regads,
John
Date: 11 Mar 2007 22:15:00
Message: <web.45f4c4f9da84c92558a931fb0@news.povray.org>
> output file.
But won't the image file need to be converted back into a mesh at parse
time?
Just to clarify, I have 5000x5000 pixel png image that I have generated in
another program. When POV-Ray parses my scene it spends 5-10 seconds
processing the image, converting it into a mesh (which is what I believe
height_field does). Would this approach actually speed things up in my
case?
> Regads,
> John
This sounds promising, although most of the height_field is visible
throughout the animation.
Thanks for the suggestions all.
Date: 12 Mar 2007 08:08:46
Message: <45f550dd@news.povray.org>
> setting on.
  That's not a heightfield, that's an image file. The heightfield will
need to be generated from it. There's no advantage.
Date: 12 Mar 2007 08:10:00
Message: <45f55127@news.povray.org>
  Such a patch exists/existed for MegaPOV.
  POV-Ray 3.7 has been restructured in a way that will most probably easily
allow this in the future.
Date: 12 Mar 2007 09:14:06
Message: <45f5602e$1@news.povray.org>
Hmmm, that sounds very handy. I don't suppose you can remember the name
of the patch? I had a look on the MegaPOV site (both official patches
and other patches) but couldn't spot it. Thanks for your help by the way.
Date: 12 Mar 2007 13:10:01
Message: <45f59779$1@news.povray.org>
> time?
That is at least 25 MB, even if it is compressed to like 12 MB, which do
take a second or two to read from disk alone - if you have a fast disk and
the file is stored linearly on disk!
Heightfields in POV-Ray are not converted to meshes.
	Thorsten
Date: 12 Mar 2007 18:04:52
Message: <45f5dc94$1@news.povray.org>
Thorsten Froehlich nous apporta ses lumieres en ce 12-03-2007 14:10:
>> time?
> 	Thorsten
Somebody know how to make a virtual drive in windows? That way, assuming that
you have enough RAM, the access will get a huge boost.
"The way England treats her prisoners, she doesn't deserve to have any."
        --Oscar Wilde
Date: 12 Mar 2007 20:01:21
Message: <45f5f7e1$1@news.povray.org>
>>setting on.
There is if an image-based height field parses faster than a
formula-based one.
John
Date: 13 Mar 2007 08:20:26
Message: <45f6a51a@news.povray.org>
Alain  wrote in message <45f5dc94$1@news.povray.org>:
That is not a good idea. If the file is read twice and there is enough
memory, the OS will keep it in memory, and the second read does not require
disc access. If there is not enough memory, the OS needs to free memory, and
discarding a cached file to re-read it later is cheaper than swapping
something out and later in.
