POV-Ray : Newsgroups : povray.general : Hothouse glass Server Time
24 May 2025 17:29:17 EDT (-0400)
  Hothouse glass (Message 1 to 10 of 11)
Subject: Hothouse glass
Date: 8 Mar 2007 10:37:42
Message: <45f02dc6$1@news.povray.org>
Imagine you are standing in a hothouse. The glass is painted white but lets
sunlight pass through in a diffused way. How can you simulate this in
POV-Ray? I have been experimenting in several directions but the results are
totally different from what I want. Anybody an idea how to solve this?
Alternatively, how do you simulate sunlight passing through a piece of white
cloth? With objects standing in the way casting shadows that you can see on
the other side?
Thanks a lot!
Subject: Re: Hothouse glass
Date: 8 Mar 2007 11:23:52
Message: <45f03898$1@news.povray.org>
> the other side?
I know of two ways to do that.
The cheapest in terms of computation time is to use the keyword
double_illuminate. In a way, it allows the light to go through your
object, and to influence radiosity computation, for example. You get to
view shadows cast by objects on the layer as well. But it can cause
problems if you need to view the layer from the outside and from the inside.
The other, more physically faithful way is to use a thin layer of
scattering media, with a very high density. It's difficult to get right,
though, because you'll probably need to tweak the media parameters to
get a good looking surface that renders in a reasonnable time.
In both cases you need radiosity to have a lighting inside the hothouse
from the sun...
Hope this helps
Vincent
Date: 8 Mar 2007 11:25:00
Message: <web.45f037f1d230b81dbe7bfb550@news.povray.org>
It is a bit difficult to imagine the exact effect you are looking for but
Have you checked to design glass with normals? I mean I would try with
something like
pigment{rgbf<1,1,1,.9>}
normal{granite 2 scale .001}
(the rest of finish and interior properties)
I dont know what would happen but seems that it would let light pass through
the windows in a diffuse way, isnt it?
Date: 8 Mar 2007 11:30:00
Message: <web.45f03961d230b81d731f01d10@news.povray.org>
> the other side?
Have you tried double_illuminating polygonal windows/cloth, then using
high-quality radiosity? Would require quite a bit of parameter-juggling but
seems feasible off the top of my head.
Bill
Date: 8 Mar 2007 19:19:40
Message: <45f0a81c$1@news.povray.org>
kike nous apporta ses lumieres en ce 08-03-2007 11:21:
> something like
Don't forget to set the ior in the interior. Any object behind the "glass" will
get the effect. The light will go trough straight as an arrow unless you also
use photons. You will need to use some aa.
Replace the light shining trough with a large area_light to give blured shadows.
You can use averaged normals whitch will give you a smoother result. If you use
photons, the averaged normals will multiply your photons count, so, only apply
that to one face (difference of 2 box, one with the normals and one flat) and
keep the number of normals relatively low.
No matter how good she looks, some other guy is sick and tired of putting up
with her shit.
	Men's Room, Linda's Bar and Grill, Chapel Hill , NC
Date: 9 Mar 2007 03:32:12
Message: <45f11b8c@news.povray.org>
"Alain" <ele### [at] netscapenet> schreef in bericht
news:45f0a81c$1@news.povray.org...
>> something like
>> through
> will get the effect. The light will go trough straight as an arrow unless
> you also use photons. You will need to use some aa.
> shadows.
> you use photons, the averaged normals will multiply your photons count,
> so, only apply that to one face (difference of 2 box, one with the normals
> and one flat) and keep the number of normals relatively low.
I did exactly what you (Kike and Alain) suggest here before ptting the
question to the forum. Nice to see that we follow the same track. However,
although quite acceptable, it does not show the glass panes as being painted
white. They are more like frosted glass windows (very nice effect by the
way).
Date: 9 Mar 2007 03:40:19
Message: <45f11d73$1@news.povray.org>
Vincent:
I am going to try both options. And see where that brings me. For a hothouse
the media solution would be impractical I think. I am working on a
geodesic-like dome with very many panes.
Bill:
double illumination is something I shall try, as also suggested by Vincent.
I already discovered (with the frosted glass I came up with first) that high
quality radiosity is essential indeed.
Thanks a lot, both of you!
Subject: Re: Hothouse glass: a very acceptable solution
Date: 9 Mar 2007 04:15:55
Message: <45f125cb$1@news.povray.org>
Following the answers to my question, I give you here the solution I find
very near to my intentions. Who knows, you may need it yourselves?
//---code started---
#version 3.6;
#include "rad_def.inc"
global_settings {
  assumed_gamma 1.0
  radiosity { Rad_Settings(Radiosity_Fast,off,off) }
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  look_at   <-0.6, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  0*x
  color rgb 1.0
  area_light
  <8, 0, 0> <0, 0, 8>
  4, 4
  adaptive 0
  jitter
  circular
  orient
  translate <-300, 30, 300>
plane {
  y, -1
  pigment { color rgb <0.7,0.5,0.3> }
sphere {
  0, 0.5
      radial
      frequency 8
      color_map {
        [0.00 color rgb <1.0,0.4,0.2> ]
        [0.33 color rgb <0.2,0.4,1.0> ]
        [0.66 color rgb <0.4,1.0,0.2> ]
        [1.00 color rgb <1.0,0.4,0.2> ]
    finish{
      specular 0.6
  translate -0.5*y
cone { <0, 1, 0>, 0.0, <0, -1, 0>, 0.5
  pigment {rgb <1,0,0>}
  translate <-3, 0, 3.5>
#declare MatGlass =
material {
      color rgbt <1.0, 1.0, 1.0, 0.4>
    normal {
      granite , 0.05
      scale  0.001
    finish {
      ambient 0
      diffuse 1
      brilliance 5
      specular 0.6
      roughness 0.001
      conserve_energy
      reflection {
        0.1 , 0.1
        fresnel  on
        falloff  1.0
        exponent 1.0
        metallic 0.0
  interior {
    ior 1.5
    dispersion 1.02
    //fade_distance 1.0
    //fade_power 1001
polygon {
  5, // number of points
  <-0.5, 0>, <0.5, 0>, <0.5, 1>, <-0.5, 1>, <-0.5, 0>
  material {MatGlass}
  double_illuminate
  scale 2
  rotate -45*y
  translate <-1, -1, 1>
//---code ended---
Date: 9 Mar 2007 05:09:16
Message: <45f1324c$1@news.povray.org>
Good result !
One minor thing is that you use ior in a polygon, which does not
simulate accurately a glass layer. What happens is that the direction of
a ray going through your polygon changes only once, while it changes
twice when going to an actual window. This is caused by the fact that
the polygon does not really have a finite inside... A ray "entering" the
polygon never exits.
If you want to keep the micronormals, and still be able to see the
object outside where they truely are, you could keep a polygon of
"paint" inside a thin block of perfectly transparent glass. Something
such as this:
#declare MatGlassBody =
material {
       color rgbt t
     normal {
       granite , 0.05
       scale  0.001
     finish {
       ambient 0
       diffuse 1
       brilliance 5
       specular 0.6
       roughness 0.001
       conserve_energy
       reflection {
         0.1 , 0.1
         fresnel  on
         falloff  1.0
         exponent 1.0
         metallic 0.0
   interior {
     ior 1.5
     dispersion 1.02
     //fade_distance 1.0
     //fade_power 1001
#declare MatGlassLayer =
material {
union{
     polygon {
       material {MatGlassLayer}
       double_illuminate
     box {
       <-0.5, 0, -0.001>, <0.5, 1, 0.001>
       material {MatGlassBody}
   scale 2
   rotate -45*y
Though it does have strange effects with micronormals, disturbs
radiosity, and renders slower... Depends on the level of realism you
want to achieve, and on your scene; if there is nothing to be seen
outside, the problem will not appear...
Regards
Vincent
Date: 9 Mar 2007 07:58:40
Message: <45f15a00@news.povray.org>
"Vincent Le Chevalier" <gal### [at] libertyALLsurfSPAMfr> schreef in
bericht news:45f1324c$1@news.povray.org...
> Good result !
> One minor thing is that you use ior in a polygon, which does not simulate
> accurately a glass layer. What happens is that the direction of a ray
> going through your polygon changes only once, while it changes twice when
> going to an actual window. This is caused by the fact that the polygon
> does not really have a finite inside... A ray "entering" the polygon never
> exits.
> If you want to keep the micronormals, and still be able to see the object
> outside where they truely are, you could keep a polygon of "paint" inside
> a thin block of perfectly transparent glass. Something such as this:
Thanks a lot! That might be useful, but not for now. I build my dome with
the Dome plugin in Moray, where the faces are automatically made of meshes,
so I cannot really do as you say. The easy way out of course, is not use the
ior in that case, but then the effect is lost. But for any other
construction with glass I shall keep this in mind.
