Is there any way to apply a linear twist to an isosurface?
What I'm after is to twist the heart iso, by about 30 degrees, (+/- 15)
along the Y axis.
Hash: SHA1
> along the Y axis.
Replace x by (x * cos (f (y)) + z * sin (f (y))
Replace z by (-x * sin (f (y)) + z * cos (f (y))
Where f is a function that defines the way you want the surface to
twist (the simplest being K*y for some constant K).
Jerome
+------------------------- Jerome M. BERGER ---------------------+
| mailto:jeb### [at] free fr | ICQ: 238062172 |
| http://jeberger.free.fr/ | Jabber: jeb### [at] jabber fr |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
iD4DBQFFh6Idd0kWM4JG3k8RAvd0AJiagT8lHXsA0eBixWRAozGS8TawAJ4oBbo1
4ZEwfkyQZMASWwlP5vDOqQ==
=T0fP
-----END PGP SIGNATURE-----
Instead of replacing them, wouldn't it be simpler to call the function
with those parameters?
#ifndef (SolidHeart)
#ifndef (TwistHeart)
// Original untwisted version
#declare Heart_Function = function { f_torus
(y-pow(abs(x),Sharpness)*Bend, z*1, x, 0.8,0.1) }
#else
//Twisted version
#declare K = 1; //Not sure where to set this yet, try 1.0
#declare f = function {K*y}
#declare Twist_x = function(x,y,z,f) //<-- Errors here with "expected
parameter identifier, function identifier found instead"
{x * cos (f (y)) + z * sin (f (y))}
#declare Twist_z = function(x,y,z,f)
{(-x * sin (f (y)) + z * cos (f (y))}
#declare Heart_Function = function { f_torus (y-pow(abs(x * cos (f
(y)) + z * sin (f (y))),Sharpness)*Bend,
cos (f (y))*1),
sin (f (y))),
0.8,0.1) }
#else
#declare Heart_Function = function { f_sphere
(y-pow(abs(x),Sharpness)*Bend, z*2, x, 0.6 ) }
Hash: SHA1
Replace this line with:
#declare Twist_x = function(x, y, z)
You can't pass a function identifier as a parameter to another
function, but you don't need to to be able to call it (huh, does
that sentence make sense?).
Jerome
iD8DBQFFiSdtd0kWM4JG3k8RAonfAJ91MyMpKoIaopYBBFFfHQ3B8jLriwCgklTx
yztdKmeOg8vou6y2VdCXH4E=
=vYKm
I guess not :) I'm still lost. Here's the current implementation
#else
#declare K = 1;
#declare Twist_x = function (x,y,z)
{x * cos (f (y)) + z * sin (f (y))} <-- "Invalid
number of parameters, 1 supplied, 3 required.
#declare Twist_z = function (x,y,z)
(y-pow(abs(Twist_x),Sharpness)*Bend,
(Twist_z*2),
(Twist_x,
0.8,0.1) }
#else
Hash: SHA1
The problem is in the declaration for f. Try one of the following
instead:
#declare f = function {K*x}
or
#declare f(y) = function {K*y}
Jerome
iD8DBQFFiaAad0kWM4JG3k8RAqoAAKCSVOVlop8PR1C/SnG41ZPLxY9PpwCgmcYj
jZBew4IDM7tRDhN0j2gxWs0=
=pKXr
> instead:
> or
> #declare f(y) = function {K*y} <-- This one errors, wants an '=' not '('
#declare K = 1;
#declare Twist_x = function (x,y,z) {( ( x * cos (f(y))) + (z * sin
(f(y))) )}
#declare Twist_z = function (x,y,z) {( (-x * sin (f(y))) + (z * cos
(f(y))) )}
Twist_z,
Twist_x,
0.8,0.1) }
Very frustrated.. :(
Hash: SHA1
>> instead:
>> or
Uh, yes sorry it should have been:
#declare f = function (y) {K*y}
> #declare K = 1;
> (f(y))) )}
> (f(y))) )}
> Twist_z,
> Twist_x,
> 0.8,0.1) }
Why? Didn't the code you just posted work?
Jerome
iD8DBQFFiidld0kWM4JG3k8RAh3DAJ0dF0xytvmN7MlW5BoEXTxc/yN1tQCfc0jJ
N45qh28DOPfPJCP7b0mc+94=
=c0cs
Nope, it errors out, I'm not finding the error messages, or even where it's
pointing to when it errors, to be all that helpful.
Perhaps K3DSurf can help since it can generate formulas for twisted
isosurfaces from an original one. You can then "see" the result before
using the generated twisted iso in your code. Supported deformations are
twisting and scaling for isosurfaces and parametric surfaces.
Cheers,
Taha
I have tweaked a bit some parts, but this works as it should:
#declare Bend=0.5;
#declare Sharpness=0.8;
#declare SolidHeart = 0;
#declare TwistHeart = 1;
#if (!SolidHeart)
#if (!TwistHeart)
function { f_torus (y-pow(abs(x),Sharpness)*Bend, z*1, x, 0.8,0.1) }
#else
//Twisted version
#declare K = 1; //twist angle
#declare f = function (y){K*y}
#declare Twist_x = function (x,y,z){( x*cos(f(y)) + z*sin(f(y)))}
#declare Twist_z = function (x,y,z){(-x*sin(f(y)) + z*cos(f(y)))}
function { f_torus (y-pow(abs(Twist_x(x,y,z)),Sharpness)*Bend,
Twist_z(x,y,z)*1,Twist_x(x,y,z), 0.8,0.1) }
#else
"Thomas de Groot" <t.d### [at] inter nlDOTnet> wrote in message
news:458b98d3@news.povray.org...
I see! Thanks so much. I was fumbling in the dark there.
