Is there any way to apply a linear twist to an isosurface?
What I'm after is to twist the heart iso, by about 30 degrees, (+/- 15)
along the Y axis.
Hash: SHA1
> along the Y axis.
Replace x by (x * cos (f (y)) + z * sin (f (y))
Replace z by (-x * sin (f (y)) + z * cos (f (y))
Where f is a function that defines the way you want the surface to
twist (the simplest being K*y for some constant K).
Jerome
+------------------------- Jerome M. BERGER ---------------------+
| mailto:jeb### [at] free fr | ICQ: 238062172 |
| http://jeberger.free.fr/ | Jabber: jeb### [at] jabber fr |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
iD4DBQFFh6Idd0kWM4JG3k8RAvd0AJiagT8lHXsA0eBixWRAozGS8TawAJ4oBbo1
4ZEwfkyQZMASWwlP5vDOqQ==
=T0fP
-----END PGP SIGNATURE-----
Instead of replacing them, wouldn't it be simpler to call the function
with those parameters?
#ifndef (SolidHeart)
#ifndef (TwistHeart)
// Original untwisted version
#declare Heart_Function = function { f_torus
(y-pow(abs(x),Sharpness)*Bend, z*1, x, 0.8,0.1) }
#else
//Twisted version
#declare K = 1; //Not sure where to set this yet, try 1.0
#declare f = function {K*y}
#declare Twist_x = function(x,y,z,f) //<-- Errors here with "expected
parameter identifier, function identifier found instead"
{x * cos (f (y)) + z * sin (f (y))}
#declare Twist_z = function(x,y,z,f)
{(-x * sin (f (y)) + z * cos (f (y))}
#declare Heart_Function = function { f_torus (y-pow(abs(x * cos (f
(y)) + z * sin (f (y))),Sharpness)*Bend,
cos (f (y))*1),
sin (f (y))),
0.8,0.1) }
#else
#declare Heart_Function = function { f_sphere
(y-pow(abs(x),Sharpness)*Bend, z*2, x, 0.6 ) }
Hash: SHA1
Replace this line with:
#declare Twist_x = function(x, y, z)
You can't pass a function identifier as a parameter to another
function, but you don't need to to be able to call it (huh, does
that sentence make sense?).
Jerome
iD8DBQFFiSdtd0kWM4JG3k8RAonfAJ91MyMpKoIaopYBBFFfHQ3B8jLriwCgklTx
yztdKmeOg8vou6y2VdCXH4E=
=vYKm
I guess not :) I'm still lost. Here's the current implementation
#else
#declare K = 1;
#declare Twist_x = function (x,y,z)
{x * cos (f (y)) + z * sin (f (y))} <-- "Invalid
number of parameters, 1 supplied, 3 required.
#declare Twist_z = function (x,y,z)
(y-pow(abs(Twist_x),Sharpness)*Bend,
(Twist_z*2),
(Twist_x,
0.8,0.1) }
#else
Hash: SHA1
The problem is in the declaration for f. Try one of the following
instead:
#declare f = function {K*x}
or
#declare f(y) = function {K*y}
Jerome
iD8DBQFFiaAad0kWM4JG3k8RAqoAAKCSVOVlop8PR1C/SnG41ZPLxY9PpwCgmcYj
jZBew4IDM7tRDhN0j2gxWs0=
=pKXr
> instead:
> or
> #declare f(y) = function {K*y} <-- This one errors, wants an '=' not '('
#declare K = 1;
#declare Twist_x = function (x,y,z) {( ( x * cos (f(y))) + (z * sin
(f(y))) )}
#declare Twist_z = function (x,y,z) {( (-x * sin (f(y))) + (z * cos
(f(y))) )}
Twist_z,
Twist_x,
0.8,0.1) }
Very frustrated.. :(
Hash: SHA1
>> instead:
>> or
Uh, yes sorry it should have been:
#declare f = function (y) {K*y}
> #declare K = 1;
> (f(y))) )}
> (f(y))) )}
> Twist_z,
> Twist_x,
> 0.8,0.1) }
Why? Didn't the code you just posted work?
Jerome
iD8DBQFFiidld0kWM4JG3k8RAh3DAJ0dF0xytvmN7MlW5BoEXTxc/yN1tQCfc0jJ
N45qh28DOPfPJCP7b0mc+94=
=c0cs
Nope, it errors out, I'm not finding the error messages, or even where it's
pointing to when it errors, to be all that helpful.
