POV-Ray : Newsgroups : povray.general : Glass texture and interior problem Server Time
7 Mar 2026 11:37:05 EST (-0500)
  Glass texture and interior problem (Message 1 to 6 of 6)
Subject: Glass texture and interior problem
Date: 18 Dec 2006 22:14:30
Message: <45875916$1@news.povray.org>
Well, things are going better, but I have a problem with my glass texture.
I posted the scene file in scene-files, and the image in images.
What's happening is that the red is exactly what I want, but the blue, which
is the same texture, is barely visible.. Not sure what I need to do to fix
this.
The two objects are using exactly the same texture.
The relevant bits below, compressed
#declare Col_Sapphire_06 = color rgbf  <0.0784, 0.1706, 1.0000, 0.99>;
#declare Col_Ruby_06     = color rgbf  <1.0000, 0.1706, 0.0784, 0.99>;
#declare Glass_Interior = interior { ior 2.5
                                     caustics 1.0
#declare Glass = texture { pigment { rgbf <0.98, 1.0, 0.99, 0.99> }
                           finish { ambient 0.0 //0.10 // As if from
scattered light in the scene
                                    diffuse 0.0 //0.10 // reflections from
light sources
                                    brilliance 0.0 // higher makes more
metallic appearance
                                    #ifndef (Phong_Off)
                                      phong 1.0
                                      phong_size 50 // higher = more
polished
                                      metallic 0.5 // 0 - 1
                                    reflection { .01 // mirror-like quality
, min max
                                                 fresnel on
                                                 metallic 0 // 0-> 1
                                    specular 0.25 //Similar to phong, all
over the surface
                                                   // too much spec looks
like pool balls
                                    roughness .02 //This gives a nice shine,
0.00005 - 1.0 (rough)
                                    conserve_energy
// Ruby glass
#declare Ruby_Glass = texture { Glass
                                pigment { Col_Ruby_06 }
// Saphire glass
#declare Saph_Glass = texture { Glass
                                pigment { Col_Sapphire_06 }
#declare M_Ruby_Glass = material { texture {Ruby_Glass}
                                   interior {Glass_Interior}
#declare M_Saph_Glass = material { texture {Saph_Glass}
Subject: Re: Glass texture and interior problem
Date: 19 Dec 2006 16:10:01
Message: <web.458853d7fde9e5dae6efd0310@news.povray.org>
That's a pretty cool picture.
The black background conspires with the dark blue to make the red much more
apparent. Pick a lighter background colour like a neutral gray, or go all
the way to white.
Colour-wise, <0.0784, 0.1706, 1.0000> is somewhat different from <1.0000,
0.1706, 0.0784>, I mean, apart from the obvious hue change. In The Gimp the
red <255,40,20> looks significantly brigther to me than the blue <20,40,255>
(I obtained these values by multiplying your colour vector by 256). It could
be just monitor settings, though. :p
Date: 19 Dec 2006 18:43:50
Message: <45887936@news.povray.org>
"Grassblade" <nomail@nomail> wrote in message
news:web.458853d7fde9e5dae6efd0310@news.povray.org...
> more
> the way to white.
I tried white as background, and as sky sphere, looked like hell.
Also, both background and sky sphere seemed to illuminate the scene pretty
powerfully. I had my single light set to 0.00 and ambient set globally to 0.
> the
> <20,40,255>
> could
Yeah, it looks ok on my monitor, but not nearly as bright as the red.
I will post another version that uses just the hearts, and the exact same
material in blue looks fabulous.
 Must be the lighting angles?
Date: 20 Dec 2006 03:47:14
Message: <4588f892@news.povray.org>
"dave vanhorn" <mic### [at] gmailcom> wrote in message
news:45887936@news.povray.org...
    Dave, I tried your original code with black background and turned rad
and photons off. The blue to me, looked better.
    ~Steve~
Date: 20 Dec 2006 07:03:12
Message: <45892680$1@news.povray.org>
Hash: SHA1
> the way to white.
	It's not just your monitor settings: perceptually, the same value
is significantly darker if it's blue than red (and green is the
brightest). When computing the equivalent brightness for a colour,
you should use the following coefficients:
In the Gimp on a PC (Macs have different values):
brightness = blue * 0.11 + green * 0.54 + red * 0.35
In Povray the coefficients should be gamma corrected:
brightness = blue * 0.02 + green * 0.71 + red * 0.27
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (GNU/Linux)
iD8DBQFFiSaAd0kWM4JG3k8RAtrNAJwN1la6adHtxe+T+y3Dl+NUvCCNrgCgh9wS
1iwgrJOOZ3ALTWvr0yFfeBg=
=t9co
-----END PGP SIGNATURE-----
Date: 20 Dec 2006 23:13:37
Message: <458a09f1$1@news.povray.org>
I know about the perceptual difference, but the same material really lights
up at a different angle. But, that won't work with the scene.
