POV-Ray : Newsgroups : povray.general : Infinity symbol Server Time
6 Nov 2026 20:58:19 EST (-0500)
  Infinity symbol (Message 1 to 24 of 24)
Subject: Infinity symbol
Date: 10 Dec 2006 20:19:48
Message: <457cb234@news.povray.org>
Has anyone done one of these, either by CSG or isosurface?  I've been
playing with stretched rings, but they just don't look right.
Subject: Re: Infinity symbol
Date: 10 Dec 2006 21:10:03
Message: <457cbdfb@news.povray.org>
I'd also be interested in how to do a mobius strip.
Date: 11 Dec 2006 04:20:16
Message: <457d22d0@news.povray.org>
"dave vanhorn" <mic### [at] gmailcom> wrote in message
news:457cb234@news.povray.org...
Not as a CSG or an isosurface, but have you considered using the text
object.
Depending upon what you want it for, an 8 on it's side may serve your
purposes.
camera {location <0,0,-1>}
light_source { <1, 2, -20> color rgb 1}
text {
  ttf "times.ttf","8",0.2, 0
  pigment {color rgb 1}
  scale <0.5,1,1>
  rotate z*90
  translate 0.3*x
Chris B.
Date: 11 Dec 2006 05:10:00
Message: <web.457d2d48acb37f29f1cb1e660@news.povray.org>
> object.
> purposes.
> text {
>   scale <0.5,1,1>
>   rotate z*90
>   translate 0.3*x
> Regards,
> Chris B.
I found the infinity symbol in the following Windows Fonts, code U+221E. If
it is of any help.
ZTZhongsong
NSimSun
New Gulim
MingLiu
Date: 11 Dec 2006 05:31:39
Message: <457d338b$1@news.povray.org>
"Chris B"  wrote in message <457d22d0@news.povray.org>:
Real mathematicians would use CMSY10.
Date: 11 Dec 2006 05:33:35
Message: <457d33ff$1@news.povray.org>
"dave vanhorn"  wrote in message <457cb234@news.povray.org>:
An infinity symbol is not a 3D object, so the question is: how do intend to
make it 3D? Do you want it infinitely thin? Flat but thick? Round?
You can do something easy with a sphere sweep:
  sphere_sweep {
    b_spline
    9,
    <-2, -2, 0>, 0.2,
    < 0,  0, 0>, 0.2,
    < 2,  2, 0>, 0.2,
    < 2, -2, 0>, 0.2,
    < 0,  0, 0>, 0.2,
    <-2,  2, 0>, 0.2,
    <-2, -2, 0>, 0.2,
    < 0,  0, 0>, 0.2,
    < 2,  2, 0>, 0.2
Date: 11 Dec 2006 05:36:45
Message: <457d34bd$1@news.povray.org>
"dave vanhorn"  wrote in message <457cbdfb@news.povray.org>:
That can be done with a parametric object:
  parametric {
    function { (1 + v * sin(u / 2)) * cos(u) }
    function { v * cos(u / 2) }
    function { (1 + v * sin(u / 2)) * sin(u) }
    <0, -0.2>, <2 * pi, 0.2>
    contained_by { box { <-1.5, -1.5, -1.5>, <1.5, 1.5, 1.5> } }
This one is infinitely thin. If you want some thickness, you have to design
a path for the v parameter.
BTW, is it not possible to use vectorial arithmetics for parametric objects?
Date: 11 Dec 2006 09:00:46
Message: <457d648e$1@news.povray.org>
> design
Thanks, I'll check that out.
All my pov experience previous has been with CSG, this is new to me.
> objects?
No idea.
Date: 11 Dec 2006 09:02:23
Message: <457d64ef$1@news.povray.org>
> object.
> purposes.
Thanks,  I did think of this last night, but the text ends up as a very
harsh object, I haven't found any way to round the corners, or otherwise
soften the appearance.
Something like a sphere sweep would be ideal.
Date: 11 Dec 2006 09:03:25
Message: <457d652d$1@news.povray.org>
I'll give that a try too, thanks.
That's pov for ya, there's usually at least three ways you didn't think of,
to do something.  :)
Date: 11 Dec 2006 09:15:00
Message: <web.457d66c7acb37f29c150d4c10@news.povray.org>
Posted in binary scene-files.
-tgq
Date: 11 Dec 2006 09:20:01
Message: <web.457d68d6acb37f29c150d4c10@news.povray.org>
> -tgq
Hmm, don't know where my original response went...
Anyways, I posted a series of macros I did about 4 years ago.  There is a
mesh2 mobius strip with uv_mapping support and a macro for a mobius built
of a user-defined object.  Hope this is of some use for you.
-tgq
Date: 11 Dec 2006 13:31:03
Message: <457da3e7@news.povray.org>
The simplest CSG would probably be for example, a union of spheres
along the shape. The shape of infty symbol
is the lemniscate - see e.g.
http://mathworld.wolfram.com/Lemniscate.html
there you can find the parametric equations for it.
Date: 11 Dec 2006 13:41:23
Message: <457da653@news.povray.org>
...or you can even try to slice a toric section of a torus...
Date: 11 Dec 2006 14:21:58
Message: <457dafd6@news.povray.org>
I don't see it on the server yet, my email is mic### [at] gmailcom if you
don't mind sending it direct.
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.457d68d6acb37f29c150d4c10@news.povray.org...
>> -tgq
> -tgq
Date: 11 Dec 2006 14:22:04
Message: <457dafdc@news.povray.org>
// e.g. like this:
//===========8<=============
camera {location  -z}
#local R1=0.6;
#local R2=0.55;
#local r1=0.3;
#local r2=0.22;
#local p=r1*1.05;
#local dp=0.001;
#local infty=difference{
   torus{R1,r1}
   torus{R2,r2}
   plane{z,p}
   plane{-z,-p-dp}
#object{infty
   pigment{rgb y}
Date: 11 Dec 2006 14:44:59
Message: <457db53b$1@news.povray.org>
Scaling the vertical component down to +/- 1, and making it a little thinner
got me to where I need to be.. Thanks!  :)
"Nicolas George" <nicolas$george@salle-s.org> wrote in message
news:457d33ff$1@news.povray.org...
> to
>  sphere_sweep {
>    b_spline
>    9,
>    <-2, -2, 0>, 0.2,
>    < 0,  0, 0>, 0.2,
>    < 2,  2, 0>, 0.2,
>    < 2, -2, 0>, 0.2,
>    < 0,  0, 0>, 0.2,
>    <-2,  2, 0>, 0.2,
>    <-2, -2, 0>, 0.2,
>    < 0,  0, 0>, 0.2,
>    < 2,  2, 0>, 0.2
Date: 11 Dec 2006 15:02:34
Message: <457db95a@news.povray.org>
Why couldn't we have had povray in geometry class... :)
> // e.g. like this:
> #local R1=0.6;
> #local R2=0.55;
> #local r1=0.3;
> #local r2=0.22;
> #local p=r1*1.05;
> #local dp=0.001;
>   torus{R1,r1}
>   torus{R2,r2}
>   plane{z,p}
>   plane{-z,-p-dp}
> #object{infty
>   pigment{rgb y}
Date: 11 Dec 2006 15:40:00
Message: <web.457dc1c1acb37f29c150d4c10@news.povray.org>
> >> -tgq
> > -tgq
It should be in p.b.scene-files (entitled mobius macro):
http://news.povray.org/povray.binaries.scene-files/message/%3Cweb.457d66a665d69017c150d4c10%40news.povray.org%3E/#%3Cwe
Let me know if you still don't see it.
-tgq
Date: 11 Dec 2006 17:26:59
Message: <457ddb33@news.povray.org>
dave vanhorn nous apporta ses lumieres en ce 2006-12-11 14:20:
> I don't see it on the server yet, my email is m i c r o b r i x@g m a i l.c o m if
you
You should always obfuscate your e-mail address. Adding spacesm, or dots, or
dashes, or ??? is a possibility, as well as adding anything that is easily
notisable by somebody but not by a harvest bot.
This NG is prety clean, but you never know. Beter be to prudent than sory with
an inbox overflowing with spam.
At the feast of ego everyone leaves hungry.
	Bentley's House of Coffee and Tea, Tucson, AZ
Date: 11 Dec 2006 17:30:53
Message: <457ddc1d$1@news.povray.org>
Stephen nous apporta ses lumieres en ce 2006-12-11 05:04:
>> object.
>> purposes.
>> text {
>>   scale <0.5,1,1>
>>   rotate z*90
>>   translate 0.3*x
>> Regards,
>> Chris B.
> it is of any help.
> ZTZhongsong
> NSimSun
> New Gulim
> MingLiu
It should be present in most unicode fonts sets at the same place.
> Stephen
Also in arialuni.ttf (same code) and in symbols.ttf
War is an instrument entirely inefficient toward redressing wrong; and
multiplies, instead of indemnifying losses.
Thomas Jefferson
Date: 11 Dec 2006 21:02:34
Message: <457e0dba@news.povray.org>
It showed up here about an hour ago, thanks.  Still playing with things..
I have this taking so long to run, that I only have looked at the pretraces
in the last two days..
The heart isosurface has a glitch that I'm trying to take out without making
it too hideously long to trace.
Date: 12 Dec 2006 06:16:20
Message: <457e8f84$1@news.povray.org>
[off topic, but I did not start it:)]
Alain  wrote in message <457ddb33@news.povray.org>:
Or not. The e-mail in my From: is valid, bot strangely, spambots seems to be
unable to see it, because although I use it on Usenet since several years, I
only got 5 spams through it last month, out of a total of almost 25000 spams
on my various addresses. Of course, the part after the dollar is not a valid
address; the administrator of the MX server tells me it produces a lot of
bounces.
Date: 12 Dec 2006 11:30:01
Message: <web.457ed868acb37f29f1cb1e660@news.povray.org>
> Alain
So it is, I missed it when I was looking. It’s also in Times New Roman as
well ∞
