Has anyone done one of these, either by CSG or isosurface? I've been
playing with stretched rings, but they just don't look right.
I'd also be interested in how to do a mobius strip.
"dave vanhorn" <mic### [at] gmail com> wrote in message
news:457cb234@news.povray.org...
Not as a CSG or an isosurface, but have you considered using the text
object.
Depending upon what you want it for, an 8 on it's side may serve your
purposes.
camera {location <0,0,-1>}
light_source { <1, 2, -20> color rgb 1}
text {
ttf "times.ttf","8",0.2, 0
pigment {color rgb 1}
scale <0.5,1,1>
rotate z*90
translate 0.3*x
Chris B.
> object.
> purposes.
> text {
> scale <0.5,1,1>
> rotate z*90
> translate 0.3*x
> Regards,
> Chris B.
I found the infinity symbol in the following Windows Fonts, code U+221E. If
it is of any help.
ZTZhongsong
NSimSun
New Gulim
MingLiu
"Chris B" wrote in message <457d22d0@news.povray.org>:
Real mathematicians would use CMSY10.
"dave vanhorn" wrote in message <457cb234@news.povray.org>:
An infinity symbol is not a 3D object, so the question is: how do intend to
make it 3D? Do you want it infinitely thin? Flat but thick? Round?
You can do something easy with a sphere sweep:
sphere_sweep {
b_spline
9,
<-2, -2, 0>, 0.2,
< 0, 0, 0>, 0.2,
< 2, 2, 0>, 0.2,
< 2, -2, 0>, 0.2,
< 0, 0, 0>, 0.2,
<-2, 2, 0>, 0.2,
<-2, -2, 0>, 0.2,
< 0, 0, 0>, 0.2,
< 2, 2, 0>, 0.2
"dave vanhorn" wrote in message <457cbdfb@news.povray.org>:
That can be done with a parametric object:
parametric {
function { (1 + v * sin(u / 2)) * cos(u) }
function { v * cos(u / 2) }
function { (1 + v * sin(u / 2)) * sin(u) }
<0, -0.2>, <2 * pi, 0.2>
contained_by { box { <-1.5, -1.5, -1.5>, <1.5, 1.5, 1.5> } }
This one is infinitely thin. If you want some thickness, you have to design
a path for the v parameter.
BTW, is it not possible to use vectorial arithmetics for parametric objects?
> design
Thanks, I'll check that out.
All my pov experience previous has been with CSG, this is new to me.
> objects?
No idea.
> object.
> purposes.
Thanks, I did think of this last night, but the text ends up as a very
harsh object, I haven't found any way to round the corners, or otherwise
soften the appearance.
Something like a sphere sweep would be ideal.
I'll give that a try too, thanks.
That's pov for ya, there's usually at least three ways you didn't think of,
to do something. :)
Posted in binary scene-files.
-tgq
> -tgq
Hmm, don't know where my original response went...
Anyways, I posted a series of macros I did about 4 years ago. There is a
mesh2 mobius strip with uv_mapping support and a macro for a mobius built
of a user-defined object. Hope this is of some use for you.
-tgq
The simplest CSG would probably be for example, a union of spheres
along the shape. The shape of infty symbol
is the lemniscate - see e.g.
http://mathworld.wolfram.com/Lemniscate.html
there you can find the parametric equations for it.
...or you can even try to slice a toric section of a torus...
I don't see it on the server yet, my email is mic### [at] gmail com if you
don't mind sending it direct.
"Trevor G Quayle" <Tin### [at] hotmail com> wrote in message
news:web.457d68d6acb37f29c150d4c10@news.povray.org...
>> -tgq
> -tgq
// e.g. like this:
//===========8<=============
camera {location -z}
#local R1=0.6;
#local R2=0.55;
#local r1=0.3;
#local r2=0.22;
#local p=r1*1.05;
#local dp=0.001;
#local infty=difference{
torus{R1,r1}
torus{R2,r2}
plane{z,p}
plane{-z,-p-dp}
#object{infty
pigment{rgb y}
Scaling the vertical component down to +/- 1, and making it a little thinner
got me to where I need to be.. Thanks! :)
"Nicolas George" <nicolas$george@salle-s.org> wrote in message
news:457d33ff$1@news.povray.org...
> to
> sphere_sweep {
> b_spline
> 9,
> <-2, -2, 0>, 0.2,
> < 0, 0, 0>, 0.2,
> < 2, 2, 0>, 0.2,
> < 2, -2, 0>, 0.2,
> < 0, 0, 0>, 0.2,
> <-2, 2, 0>, 0.2,
> <-2, -2, 0>, 0.2,
> < 0, 0, 0>, 0.2,
> < 2, 2, 0>, 0.2
Why couldn't we have had povray in geometry class... :)
> // e.g. like this:
> #local R1=0.6;
> #local R2=0.55;
> #local r1=0.3;
> #local r2=0.22;
> #local p=r1*1.05;
> #local dp=0.001;
> torus{R1,r1}
> torus{R2,r2}
> plane{z,p}
> plane{-z,-p-dp}
> #object{infty
> pigment{rgb y}
> >> -tgq
> > -tgq
It should be in p.b.scene-files (entitled mobius macro):
http://news.povray.org/povray.binaries.scene-files/message/%3Cweb.457d66a665d69017c150d4c10%40news.povray.org%3E/#%3Cwe
Let me know if you still don't see it.
-tgq
dave vanhorn nous apporta ses lumieres en ce 2006-12-11 14:20:
> I don't see it on the server yet, my email is m i c r o b r i x@g m a i l.c o m if
you
You should always obfuscate your e-mail address. Adding spacesm, or dots, or
dashes, or ??? is a possibility, as well as adding anything that is easily
notisable by somebody but not by a harvest bot.
This NG is prety clean, but you never know. Beter be to prudent than sory with
an inbox overflowing with spam.
At the feast of ego everyone leaves hungry.
Bentley's House of Coffee and Tea, Tucson, AZ
Stephen nous apporta ses lumieres en ce 2006-12-11 05:04:
>> object.
>> purposes.
>> text {
>> scale <0.5,1,1>
>> rotate z*90
>> translate 0.3*x
>> Regards,
>> Chris B.
> it is of any help.
> ZTZhongsong
> NSimSun
> New Gulim
> MingLiu
It should be present in most unicode fonts sets at the same place.
> Stephen
Also in arialuni.ttf (same code) and in symbols.ttf
War is an instrument entirely inefficient toward redressing wrong; and
multiplies, instead of indemnifying losses.
Thomas Jefferson
It showed up here about an hour ago, thanks. Still playing with things..
I have this taking so long to run, that I only have looked at the pretraces
in the last two days..
The heart isosurface has a glitch that I'm trying to take out without making
it too hideously long to trace.
[off topic, but I did not start it:)]
Alain wrote in message <457ddb33@news.povray.org>:
Or not. The e-mail in my From: is valid, bot strangely, spambots seems to be
unable to see it, because although I use it on Usenet since several years, I
only got 5 spams through it last month, out of a total of almost 25000 spams
on my various addresses. Of course, the part after the dollar is not a valid
address; the administrator of the MX server tells me it produces a lot of
bounces.
> Alain
So it is, I missed it when I was looking. It’s also in Times New Roman as
well ∞
