> Can a programmer distribute this product (povray)
> with a seperate project that explains it uses povray to generate pictures
> (like logo) and not make money off it?
> Is it legal?
> JohnnyL
Basically, yes.
All that is required is a statement that POV is in your distribution (at
install)
and that POV is free, and available from www.povray.org
There is no requirement that your software be free.
"JohnnyL" <lut### [at] operamail com> wrote in message
news:web.457b747521612df63b3f2090@news.povray.org...
> Is it legal?
> JohnnyL
Hi Johnny,
The license covering the distribution of POV-Ray softare is at
http://www.povray.org/distribution-license.html.
I think you'd need to read clause 3 to answer your question.
Unless your plans come under any of the specific terms of that clause (e.g.
3.1c - educational institutions), then I believe you would need to get
written permission.
Chris B.
> Is it legal?
Unless POV-Ray is just an optional inclosure to your product (see
distribution license 4.1.d.i-ii) you need to obtain a written permission
by the POV-Team. You can use the email address given in the license
text to make such an inquiry.
The purpose of these regulation is to ensure the users of such a product
are prominently made aware that POV-Ray is included with the product,
provides parts of its functionality and is available for free.
http://www.imagico.de/ (Last updated 15 Oct. 2006)
In article <elgnme$uu5$1@chho.imagico.de>, chr### [at] gmx de says...
es
> > Is it legal?
> Christoph
This one does bug me a tad. If you completely redid POV-Ray to make it
an includable library, which had its "own" render window that "must" be
used as the installed component, "can't" be hidden by the developer and
which, as part of its initialization, automatically displayed a test
render and a scrollable disclaimer, including a statement that this is
not an original, etc., etc., would that "cover" the requirement?
The limitations of the current implementation make integration iffy, use
frustrating and the results less than exciting. Its probably actually
easier, if you know the math, to code a look alike product, than use
POV-Ray as part of any sort of package, optional or not. And its
certainly not too helpful in cases where removing it "would" break the
product. Then again, trying to use Moray with "anything" other than POV-
Ray would break that too. Its only "how" they integrate that is the
issue and how easily some change in the interface that "does" exist can
break it that effects the rules. And, given how easy it was to break
compatibility between Moray and the latest POV-Ray version, this is
hardly a crowning achievement of POV-Ray development. lol
I mean, why "can't" you adjust the design for a specific task, making
clear that this is "not" the original, as long as it still does what is
needed to comply with all the notices. Is it only the presumption that
any closer integration *can't* comply? All that's needed is something in
the dialog function that makes it "ignore" or "reset" any attempt to
change its "visible" property, until "after" a certain amount of time
has passed or someone has scrolled through the disclaimers and clicked
"OK". Same result as having it 100% external and throwing yet another
application window over the top of everything when it starts. And again,
if the point is to prevent people making POV-Ray a "dependent" part of
their own application that is manditory, Moray is already basically
breaking that rule as would any GUI modeler that only exports to and
uses POV-Ray as its target renderer.
Point is, does the anti-library issue make sense, if sufficient
requirements exist, to make sure that the "rest" is adhered to? Last
time I sort of asked this the answer was an unsatisfactory, "No you
can't do that because it 'would' somehow break the disclaimer
requirements..." I don't get why that "must" be true at all. Non-
conformity is non-conformity, regardless of if some clown creates a
library version then doesn't show any of that or they code some hacks
into their own application like to do it:
run "povray"
a= findwindow "povray"
setwindowposition "a",nonvisible & minimized
They are still breaking the rules, no matter "how" they hide it. Why is
hiding the whole thing with a hack "less" egregious than making it more
integratable and failing to include a way to show the needed information
in their own application? The argument against library design is just
one of, "Its easier for someone to cheat.", not one of, "This way people
can't cheat.", so I just don't get why its more of a problem. Hell, if
anything, I could create the above hack in five minutes and have it
working, compared to the days it would take to do what a lot of people
would like to be able to.
Anyway. Hope you really think about what I am saying here and don't just
come back with the usual, "You just can't do it 'period'.", argument. :p
void main () {
call functional_code()
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
I don't really see your point here. The POV-Ray license requires a
custom version to be a fully functional version of POV-Ray. The reason
for this is to prevent anyone from crippling POV-Ray to just perform a
certain limited task. The user who gets a custom version of POV-Ray
should always be able to do everything possible with the official
version as well. For the same reason the license does not allow to
disguise the fact that POV-Ray is used in a program system.
As far as practical problems of using POV-Ray in combination with other
programs is concerned - you seem to be very focussed on the GUI versions
of POV-Ray. The license no way requires a distributed POV-Ray
executable to have a GUI and in the Unix frontend the GUI/render window
has always been optional.
-- Christoph
In article <457e602e$1@news.povray.org>, chr### [at] gmx de says...
Well, there was some level of confusion at one point when either I or
someone else mentioned it. So.. If someone made an ActiveX enabled one,
which can run stand alone or as a library, then as long as some method,
like I mentioned, is employed to make sure people know its POV-Ray, then
that is OK?
In other words, if it functioned exactly as it does now under Windows,
but you could also call it with:
a = createobject("application.povray")
b = a.renderwindow
b.parent = me.frame
b.render ("myscene.pov")
Then, and this is where I am suggesting the means of compliance, you
code the interface so that:
1. "renderwindow" cannot be resized smaller than needed to display the
required licencing elements.
2. "renderwindow" connot be "hidden" until after those are displayed.
3. "a.render" will not operate at all, unless you have at least one
instance of "renderwindow" in operation.
4. Possibly set of the initial license info display as something you
have to do an "decline" or "accept" type thing on, so they have to at
least look at it.
See, the idea is to both comply with the requirements, but also
integrate the engine closely enough with what is going to use it that it
is nearly invisible. Currently the only method to do that tends to be a
tad flaky and became broken between versions. The idea is to provide an
alternate wrapper, that provides complience, less obtrusive operation
and better integration.
I would also, for my use, consider an additional optional "sandbox.ini"
file, which would let you disable certain features, like radiosity,
which might create excessive render times if used, so that, for my use,
the engine **seems** to be limited to faster operations that allow
closer to real time operation. I.e., scenes that take a minute or less
to generate, not 30 minutes to 30 days, etc. However, editing the
sandbox or even deleting it would "re-enable" anything disabled. Using
it in "stand alone" mode would simply ignore the sandbox settings.
Point is, finding a way to comply with the requirements without breaking
the rendering engine (and the rules) or recoding it, while "still"
getting what you want out of it for the specific task you need it for.
The last few times anyone even suggested some sort of closer integration
the answer wasn't, "If you make sure they know what it is and it does
everything it normally would.", it was, "No you absolutely cannot." I
want to know how flexible the rules really are and if you can comply,
how ever convoluted the solution, without throwing the whole thing out
as totally unworkable and starting from scratch. What I propose above
would "seem" to me to make sense. I want to know if it does to the
people that coded it.
NOTE: In case you are wondering, the idea is to, maybe, allow small
scene files, dependent on local libraries of some pre-made stuff, to be
sent by text based games, so that some level of 3D stills or simple
animations would be possible. This mandates a sandbox that can
"disable" things which, while nice for real renders, are time hogs
otherwise. It also mandates some level of usable integration, which is
barely possible when it works with the current method and not entirely
practical for some uses. At the least it has serious issues with initial
startup of the engine, which causes different problems depending on
which starts first, as well as issues with multiple copies, either of
the engine or of applications trying to talk to it. The existing method
to solve it only partly addresses the issue imho, while real instancing
of it as an object solves most of the problems, except the memory issue
that then crops up.. But, its possible to allow one "stand alone"
instance and one "object" instance or other permutations too, just not
with it as it stands.
Mind you, I am buried in doing some other things at the moment, so the
issue is mostly mute, for right now, but eventually I am going to have
to either find out "if" the idea of viable or start trying to figure out
how the heck to code one myself, should I start working on it again in
the future. lol
void main () {
else
> that is OK?
The source license is absolutely clear that it is not allowed to link
POV-Ray (or parts of it) to another program (linking referring to the
programming meaning of having another program directly call functions
from the POV-Ray code). You are free to extend the existing means of
POV-Ray to communicate with other programs though as long as these
extensions don't contradict the intent of the license.
> b = a.renderwindow
> b.parent = me.frame
I don't know the programming language this is written in but it pretty
much looks like this functionality (i.e. starting a render and
displaying the results) is supported by existing communication means of
all official POV-Ray versions. And if you for some reason don't like
the existing means of doing this you can modify them to better suit your
needs (you could for example add a feature to have the render results
sent via some network protocol *).
I didn't really understand the rest of your posting (the 'sandbox' stuff
etc.) - it seems to me you are talking about limitations of the POV-Ray
rendering engine and not about the License.
*) note this is neither a legal advise not an official statement of the
POV-Team, just my personal interpretation based on the fact that this is
already possible indirectly via operating system mechanisms or separate
tools.
-- Christoph
In article <45810709@news.povray.org>, chr### [at] gmx de says...
> > b = a.renderwindow
> > b.parent = me.frame
Well, its not "quite" the same. ActiveX has advantages that static
methods don't. But, its nice to know this is allowed, though it gets a
bit more complicated. Technically an ActiveX wraps the whole
application, not just an extension loaded into it, which is what the
current system does. Still, its nice to clear up how and if that was
acceptable. Now, some others may have "intended" something like this,
but described it wrong, thus creating confusion that led to them being
told "No, you can't do that." Needless to say, this confused me a bit,
since I didn't see how a more stable method (at least more stable on
Windows) was a "bad" thing.
Well, in some ways it "is" about the license. The license says clearly
that you can't provide an incomplete and partially functional version.
This idea is intended to side step that.
Let me explain. A client application I use also uses Lua and a
"sandbox". This is done to limit and safeguard the machine from code
that "might" be dangerous. Since the scripts are created by the clients
users and tied to a set of plugins, someone could add dangerous code to
a plugin, which the other users would never know about, while thinking
they got something that provides beneficial features. For example, the
IO library functions. In Lua you can declare your own functions that
override the "existing" ones, so the solution to preventing something
from adding code like this:
io.run "del c:\windows"
is to place, in the "sandbox" a function like:
def function io.run {
When anyone tries to execute the io.run function in a script the
"sandbox" version is called, which doesn't do anything.
Now, the idea for POV-Ray would be a bit different. Lets say I dont'
want anyone using Isosufaces at all and I want to "restrict" the use of
reflection with refraction, since those things tend to cause serious lag
in scene generation. And maybe also limit mesh sizes to reduce render
times. The sandbox.ini might look like:
[forbid]
isosurface
[limit]
mesh:10000
[restrict]
reflection:ior
When run normally the sandox it ignored entirely. When used from the
activeX connection it would look at the sandbox and a scene that
contained these would generate errors and refuse to produce the scene if
you violated any of those rules. The engine and the normal environment
would still be 100% functional, but limits could be placed on what could
be done through the activeX connections.
The reason this is a licensing issue is that it technically allows you
to provide an partially disabled version, within the limits of how you
are using it, while *still* providing a complete version, when used as
though it was just the stand alone version. Think of it like a more
complex version of the render level commands, which let you decide what
things the engine should "not" render, when doing test renders. Though,
I suppose, since that already exists, this is just a more specific form
of the same thing.
void main () {
else
> methods don't.
Well - since you don't give any concrete example here this is difficult
to comment on. Note however that apart from license issues any such
non-portable approach would be
No, see 2.2-f of the source license:
"If that directive is not present, the Modified Version must work in the
same way as the Licensed Version."
Any unofficial version should by default work exactly like the official one.
Now what you described is just an extension of the quality switch in
POV-Ray. Nothing prevents you from implementing this *inside POV-Ray*
(if it is turned off by default). You can also pre-process a scene with
a separate program to disable certain parts. But having an external
hook to switch POV-Ray into an incompatible, crippled mode would violate
the above part of the license as well as section 1.6:
"[...] Modification to these APIs or other officially supported
communication mechanisms (or the addition of any new code or feature)
for the purpose of avoidance (or to assist others to avoid) the intent
of this or any other POV license is expressly prohibited."
Once central purpose of the POV-Ray source license is to avoid
modifications of POV-Ray to impose limits to the users concerning their
use of POV-Ray.
In article <em35ps$uuv$1@chho.imagico.de>, chr### [at] gmx de says...
> > methods don't.
ne.
> use of POV-Ray.
Hmm. Well, its a bit of gray line in this case. The purpose of
implementing such a limit is to "hopefully" automatically apply limits
that prevent parse times or render times that would exceed any
reasonable time limit. If you are looking at a game that incorporates
this as a rendering system, but you don't *absolutely* need "real time",
which isn't practical, as in, 30 seconds to "at most" a minute thirty.
Allowing things that in combination are "certain" to produce longer
times is not a great idea. Mind you, one could simply leave it entirely
open and let the scene maker deal with how to decrease the render and
parse times.
In principle the sandbox is just another ini. Its one "specific" to the
this implementation as a inlined rendering engine, but not "required" by
the program in any other context. Ironically, your argument seems to
imply that adding it as something that works in "all" contexts is more
acceptable, since it becomes a "rendering setting", than when limited to
one specific use?
Ok, how about this. Allow the sandbox to act like that, but instead make
the ActiveX command have two forms:
pov.render ("myscene.ini") - Functions just like the "existing"
interface.
or
pov.render ("myscene.ini", False) - Functions as above.
pov.render ("myscene.ini", True) - Uses the sandbox limits.
Its just extending the capabilities then, even in the interface, since
the default behavior is "indistinguishable" from the normal one, right?
In principle, one option going to the issue with ActiveX vs. other
methods, you can do with ActiveX one thing you "can't" with the existing
method, even if it is platform independent. With ActiveX I could have
open (presuming I didn't mind the lag and memory issues):
1. Regular copy, rendering a big file.
2. ActiveX instance that is generating an image with low render
settings.
3. ActiveX instance that is generating a longer render time version of
2, along with other queued images, with higher quality settings.
and, I don't have the "keep single instance because the program running
both version 2 and 3 can't tell who they hell they are talking to. I
understand that "is" an issue with the current system, which is why
Moray requires you run it only in "single instance" version. There is no
way for the OS, the program making the calls, etc. to "know" which one
it is dealing with. ActiveX has one big advantage in that each instance
is uniquely identified in the OS. And, just to be clear, while this may
not "technically" be cross platform, there are implementations of things
like Mono that "are" available under Linux and support the same sort of
unique identification and instancing systems. While it may have been
true in the past that there was no "better" option, this isn't exactly
true now.
void main () {
else
