POV-Ray : Newsgroups : povray.general : Basic Clouds, Smoke, Fire and Explosions Tutorial Server Time
20 May 2025 15:40:44 EDT (-0400)
  Basic Clouds, Smoke, Fire and Explosions Tutorial (Message 1 to 9 of 9)
Subject: Basic Clouds, Smoke, Fire and Explosions Tutorial
Date: 6 Dec 2006 23:21:46
Message: <457796da$1@news.povray.org>
Warp's contribution reminded me to get this on-line.
http://www.geocities.com/evilsnack/tut01.htm
John
Subject: Re: Basic Clouds, Smoke, Fire and Explosions Tutorial
Date: 7 Dec 2006 03:38:45
Message: <4577d315$1@news.povray.org>
"John VanSickle" <evi### [at] hotmailcom> schreef in bericht
news:457796da$1@news.povray.org...
Thanks John!! Very useful indeed! Those are the little things that make
POV-life so enjoyable :-)
Date: 7 Dec 2006 03:45:00
Message: <web.4577d37d12246f72f1cb1e660@news.povray.org>
> Regards,
> John
it properly when time permits. It deserves the time.
Date: 7 Dec 2006 04:45:00
Message: <web.4577e25712246f723976a8750@news.povray.org>
Very good!  Specially the smoke and explosion! :)
But, John, i don't think that fire is much realistic.  You can get a much
better result by making the absorption media colors in the density map the
inverse of what they are in the emission block.  That way, the absorption
media will absorb the inverted color and let go the same color as in the
emission block.
You may try the modification i did:
#macro denFireBall( is_emitting )
density{
  spherical
  turbulence .3 lambda 3
  #macro fac( colr )
        #if (is_emitting)
                (colr)
        #else
                (1-colr)
  density_map {
    [.01 rgb 0]
    [.01 rgb fac(<1,0,0>)]
    [1/4 rgb fac(<1,.5,0>)]
    [2/4 rgb fac(<1,1,0>)]
    [3/4 rgb fac(<1,1,1>)]
sphere { 0,2 hollow no_shadow
  texture { pigment { rgbt 1 } }
  interior {
    media { emission 2
      //density { denFireBall }
      denFireBall( yes )
    media { absorption 2
      denFireBall( no )
Date: 7 Dec 2006 05:54:51
Message: <4577f2fb@news.povray.org>
  What I would like to see added to that tutorial: Flames and smoke
raising up (from a burning source, as it usually happens in real life),
perhaps taking into account winds and air turbulence and such.
  And btw, if the fire looks bad against blue background, why don't use
a background which will make it look good?-)
Date: 7 Dec 2006 16:39:35
Message: <45788a17$1@news.povray.org>
I was lazy and used the same background for each one :-)
John
Date: 8 Dec 2006 02:10:00
Message: <web.45790ec612246f729356f54f0@news.povray.org>
From the tutorial: "Glowing gases cast shadows"
Now you've done it.   Now I'm going to have to go play with a flashlight and
a candle!
Charles
Date: 8 Dec 2006 19:49:32
Message: <457a081c@news.povray.org>
> a candle!
It's one of the ways that astronomers use to identify the chemical
make-up of the cooler outerlayers of the sun.
Most of the time the shadows that are cast by glowing gases go unnoticed
because the glowing is the brightest (and often only) light source.
John
Date: 11 Dec 2006 18:22:58
Message: <457de852@news.povray.org>
That would be in the *advanced* tutorial :-)
John
