POV-Ray : Newsgroups : povray.general : Warn About Naming Conflicts? Server Time
24 May 2025 23:40:16 EDT (-0400)
  Warn About Naming Conflicts? (Message 1 to 10 of 38)
Subject: Warn About Naming Conflicts?
Date: 5 Dec 2006 14:44:50
Message: <4575cc32@news.povray.org>
OK, as an offshoot from another thread here, perhaps an even simpler
solution to the problem exists.  What if, everytime you #declare an
object which has already been #declare'd, the parser gives you a warning
telling you what was re#declare'd and where?
This would not apply to #local items, only to globals.  It would take
some work to convert a lot of the current include files, but it would be
much safer overall.
...Chambers
Subject: Re: Warn About Naming Conflicts?
Date: 5 Dec 2006 19:10:00
Message: <web.457608a63c5677586cccd0@news.povray.org>
> much safer overall.
> ...Chambers
file this idea under that thread too, Ben. :)
but then, suppose this works:  people actually look at the warnings if
things go noticeably wrong.  What happens next is that they will have then
to rename some stuff in their own files or, if they are out of luck, in
someone else's file if they include 2 or more files which happen to share
some names but are not related.
This is too much of a problem and a simple alias together with the include
declaration in the first place would not permit that to happen.  Giving a
unique prefix identifier of your own to include files is much better than
having to go through the files renaming stuff.  That and local scoping for
included items should go a long way into making povray SDL a lot more
sturdy and capable for handling large catalogues of objects and textures...
Date: 5 Dec 2006 20:34:24
Message: <45761e20@news.povray.org>
#declare Index = 0;
#while(Index < 10000)
  #declare TheObject = sphere { <Index, 0, 0>, 1 pigment { rgb 1 } };
  ... (do something with TheObject) ...
  #declare Index = Index+1;
  How many warnings do you get?
Date: 6 Dec 2006 05:05:26
Message: <457695e6$1@news.povray.org>
Warp wrote:
> #declare Index = 0;
> #end
#local index = 0;
#while (index < 10000)
   #local TheObject = sphere { <index, 0, 0>, 1 pigment {rgb 1} };
   #local index = index+1;
No warnings at all :)
That's why I said it would take some work to get a lot of the current
include files to work with this; of course, the behavior could be
switched off via a command-line option (or an ini file option).
Basically, you would only use #declare for items that truly need to be
global in scope, rather than using it out of habit.  Of course, I also
like the idea I put forward of container objects, but this seemed like
an easier solution to implement.
...Chambers
Date: 6 Dec 2006 06:30:47
Message: <4576a9e7@news.povray.org>
> Warp wrote:
> > #declare Index = 0;
> > #end
> #local index = 0;
> #end
  The problem is that my version is completely valid and there's nothing
wrong with it, and there's no reason why someone wouldn't write code like
that. Issuing ten thousand warnings on it makes no sense.
Date: 6 Dec 2006 12:16:03
Message: <4576fad3$1@news.povray.org>
Hi!
> #local index = 0;
> #end
This is not always possible: Imagine calling a include file inside a
loop, where the include file uses a global variable that has to be
changed for every run:
#local index = 0;
#while (index<10000)
	#declare This_Is_Used_By_The_Include = Some_Function(index);
	#include "someinclude.inc"
	#local index = index + 1;
You'll always have to rely to some extent on the 3rd-party programmer,
even if you use real OOP-languages like C++ or Java.
Florian
Date: 6 Dec 2006 13:29:26
Message: <45770c06@news.povray.org>
That's true, it IS completely valid, which is why the warnings could be
disabled.  The real question is not what is valid now, but what
practices would work best to discourage namming conflicts.
...Chambers
Date: 6 Dec 2006 13:31:07
Message: <45770c6b$1@news.povray.org>
> #local index = 0;
> #end
> Regards,
> Florian
This is certainly possible now, however it goes back to the old practice
of using an include file as a macro, rather than including a file once,
and calling a macro inside of it.  IMNSHO, this practice should be
discourage anyway, so I would consider it a bonus ;)
...Chambers
Date: 6 Dec 2006 16:00:01
Message: <web.45772edc3c56775f1fd3ead0@news.povray.org>
i double that! :)
Date: 6 Dec 2006 18:04:06
Message: <45774c66@news.povray.org>
Florian Brucker nous apporta ses lumieres en ce 06/12/2006 14:13:
> Hi!
>> #local index = 0;
>> #end
> #local index = 0;
> #end
> Regards,
> Florian
What HORRIBLE piece of code! Do that then wonder why your scene takes so much
time to parse and why it gobbles up your memory. Beter to use a real macro.
Al Gore is proof that Tennessee has a sense of humor.
