Hello,
I have similar scene:
#declare Pig = pigment {
image_map { ... something }
#declare Tex = texture {
pigment {Pig}
#declare Poly = polygon {
texture {Tex}
... a lot of Polys used later in the scene ...
I seems, that image_map is copied for every "Poly" placed into the scene
and it leads to high memory requirements ... Is any way how to have only
one instance of image_map into the scene?
Thanks
Vaclav
In fact its normal cause you place a number of polygon with texture ..
you will be able to reduce memory usage by grouping all polygons of same
texture , then applying the texture on them ..
for exemple:
instead of doing that
#declare index=0;
#while(index<1000) object {my_polygone texture {my_texture}} #declare
index=index+1; #end
which use a lot of memory (cause texture is loaded each time) you should do
that
#declare index=0; union { #while(index<1000) object {my_polygon}
#declare index=index+1;#end texture {my_texture} }
"Vaclav Cermak" <dis### [at] disnel com> a écrit dans le message de
news:4541bf9c$1@news.povray.org...
> Hello,
> pigment {Pig}
> texture {Tex}
> Thanks
> Vaclav
Sure, but this does not work, I need imagemap properly aligned with each
polygon ....
V.
do you just call your abjects ..or did you do CSG with them ?
news:4541ddcf$1@news.povray.org...
> polygon ....
> V.
You must check these then ..
Avoid to call image_map when you are in a loop..
.... try to not read on Hard disk your image map by storing
it in a variable away from a loop
If you have multiple objects
use #local statement for each object which will appear, or used one time ..
store your pigment and texture , by a #declare
#undef each not required elements..(if #local not possible)
HOLLOW your objects ...
else that the price to pay multiple textured object ...
"Penelope20k" <pen### [at] caramail fr> a écrit dans le message de
news:4541cff2$1@news.povray.org...
> for exemple:
> #declare index=0;
> index=index+1; #end
do
> that
> > Hello,
> > pigment {Pig}
> > texture {Tex}
> > Thanks
> > Vaclav
Penelope20k nous apporta ses lumieres en ce 27/10/2006 06:54:
Can you tell me HOW or WHY adding "hollow" to an object could affect how much
memory it use? hollow have only one effect: it enable an object to contain some
media, nothing else.
Zen Buddhism: What is the sound of shit happening?
> memory it use?
It doesn't. It's just the keyword which causes the weirdest confusions
in people, for whatever reason.
Warp nous apporta ses lumieres en ce 29/10/2006 06:44:
>> memory it use?
I know that. I asked the question to Penelope20k, who, aparently is confused
about the keyword.
Maybe peoples expect it to, somehow, affect how the object is treated in CSG or
how it's get rendered, or that it may affect it's aspect.
WARNING: The consumption of alcohol may cause pregnancy.
