POV-Ray : Newsgroups : povray.general : Tips for Short Code Contest Server Time
25 May 2025 05:32:07 EDT (-0400)
  Tips for Short Code Contest (Message 1 to 5 of 5)
Subject: Tips for Short Code Contest
Date: 12 Oct 2006 14:22:41
Message: <452e87f1@news.povray.org>
After tyring to get a few scenes into 256 bytes for Paul Bourke's short code
contest, here's a few tips I've stumbled on to squeeze the last bits from
the sdl.
1. What Camera?
It helps to remove the camera declaration out of the scene. The default
camera is located at <0,0,0> and looking at <0,0,1>. If you must move the
camera, the camera will continue to look in the +z direction from it's new
location, the equivalent of 'camera{location loc look_at loc+z}'. This
prevents having to use 'look_at <a,b,c>'
2. Colors
In SCC round 3, Tek noted
(http://local.wasp.uwa.edu.au/~pbourke/rendering/scc3/final/swokwz_l.pov -
at the bottom) that the direction vectors can be used for colors.
 x = <1,0,0> (red)
 y = <0,1,0> (green)
 z = <0,0,1> (blue)
What's even better is that you can throw out the rgb reference if you use
vectors, i.e.:
 'pigment{color x}' = 'pigment{color rgb <1,0,0>}'
3. Vector Substitution
A constant 'C' will be interpreted as '<C,C,C>' if the parser needs a
vector. This can be quite useful since '1-z' is equivalent to '<1,1,0>',
but with less than half the bytes.
4. Spaces Are Optional
Brackets, braces, and parentheses are not the only characters that help
remove spaces. Povray does not require spaces before pound signs ('#'),
(sometimes) does not need spaces after numbers, and (sometimes) does not
need spaces before decimal points ('.'). The following will parse:
#macro a(b)#if(b<5)box{-1,1scale.5translate y-3pigment{color x}}#end#end
5. Reorder The Math
Watch for leading minus signs: they can sometimes be placed elsewhere in the
equation. For example '-x+1' can also be '1-x'. Also, place numbers last to
combine with #4 above and remove a space, i.e. 'translate 3+y pigment{color
x}' -> 'translate y+3pigment{color x}'
6. Isosurfaces
If you're using isosurfaces, don't forget that the default bounding box is
'contained_by{box{-1,1}}'. If your bounding box is the same size or smaller
(suck up that rendering time hit), remove the contained_by directive if you
don't need it.
7. Scaling
When scaling in only one axis, it's customary to make all the other scaling
factors be one because scaling by zero is illegal, i.e. 'scale <1,1,10>'.
Povray converts all zero scaling factors to ones, so use 'scale 10*z'.
Mike
http://povray.tashcorp.net
Subject: Re: Tips for Short Code Contest
Date: 12 Oct 2006 21:07:21
Message: <452ee6c8@news.povray.org>
Mike Kost <con### [at] povraytashcorpnet> wrote:
> 1. What Camera?
  Usually putting a camera statement at all is a waste of space. Translating
the scene usually takes less space. And yes, you can often use tricks to
avoid the 'translate' keyword too.
> vectors, i.e.:
  Why not 'pigment{rgb x}'?
  This is not just a "short code trick", it should be basic knowledge right
from the documentation.
  Again not even a "trick", but basic info straight from the documentation.
  That's not even the shortest way of doing that ;)
Date: 12 Oct 2006 22:10:00
Message: <web.452ef46fb1f80888fb5a6f0@news.povray.org>
> > vectors, i.e.:
Even though this is valid, it gives me the creeps for some reason, x is x,
red is red...
Not necessarily all tricks, but often ignored, skipped over or forgotten...
Best I can do:
#macro a(b)#if(b<5)box{y-3.5y-2.5pigment{rgb x}}#end#end
-tgq
Date: 12 Oct 2006 23:08:30
Message: <452f032d@news.povray.org>
> red is red...
  You are not a programmer then? ;)
  I think of 'x' as '<1, 0, 0>', not as "the x axis". Since '<1, 0, 0>' is
a valid and normal color (in a similar way as eg "#FF0000" is a valid normal
color in html), then 'x' is one too.
  This actually makes understanding things like "x+y" easier. You have
to think about that as "<1, 0, 0> + <0, 1, 0>", not as "the x axis plus
the y axis", which would be quite confusing.
> Best I can do:
  Much better. :P
Date: 13 Oct 2006 19:14:52
Message: <45301dec@news.povray.org>
>> 1. What Camera?
>> new location, the equivalent of 'camera{location loc look_at loc+z}'.
>> This prevents having to use 'look_at <a,b,c>'
>   Translating
>> vectors, i.e.:
>   right
Good suggestion for 'rgb x' instead of 'color x'.
Whether this is basic knowledge or not, I'm interested in encouraging
entries in the short code contest. If someone hasn't read the documents
closely for syntax structure, it's helpful to know it.
>   documentation.
No, but it got the point across.
Mike
