http://george.ph.utexas.edu/~schreck/schreck/cologram/ (link courtesy of
Brian McConnell)
This guy uses POV-Ray to create some sort of stereoscopic images. He calls
them "colograms" but there's probably a more common term for this technique
(it looks like lenticular prints without the lens).
The cool thing is that it can be done at home using a regular printer.
G.
It's seems to be the polarized light technique or something
Polarized light? Isn't it just a simple occlusion technique where
you see just part of the image at a certain angle?
> - Warp
It seems so. Sort of like a poor man's version of the little hologram cards
that you could get in cereal boxes and such with the ridged plastic front.
I may have to try it some time...
-tgq
> > - Warp
Yes, a sort of lenticular-like image/effect without the need for a plastic
lenticular screen in front. Didn't know that was possible. Thanks for
posting the link!
I assume there's a somewhat low limit to the number of images that can be
combined (less than with a lenticular print, which uses a kind of lens-like
refraction to pick out each individual image, I believe.)
Ken W.
ooops! I forgot to put some irony in my post...
yeeees indeed, it is a simple lenticular technique without lens but light
from back (ingenious imo)
sorry it was so late and I was tired ;-)
"Trevor G Quayle" <Tin### [at] hotmail com> wrote in message
news:web.4513463bb2c58e128fb5a6f0@news.povray.org...
>> - Warp
> cards
> -tgq
This thread provoked me to wondering whether this masking technique or the
lenticular prints technique could be wrapped around a cylinder to give a 360
degree rotatable 3D stereoscopic image. I figure that it should be possible
to adjust the print line spacing and interlacing to compensate for the
distortion of wrapping it into a cylinder, but I've never seen anything but
flat ones.
Anyone ever seen or tried anything like this?
Chris B.
Chris B nous apporta ses lumieres en ce 22/09/2006 08:10:
>>> - Warp
>> cards
>> -tgq
> flat ones.
> Regards,
> Chris B.
In that case, the needed offset will vary with your distance to the cylinder and
wether you are vewing the middle part of the visible section, nearly
perpendicular, or near the edge, grazing angle. This mean a variable distortion.
If it wasn’t for the last minute, nothing would get done.
