POV-Ray : Newsgroups : povray.general : Render Panoramic photo for use in a sky box? Server Time
31 Oct 2026 20:31:35 EDT (-0400)
  Render Panoramic photo for use in a sky box? (Message 1 to 7 of 7)
Subject: Render Panoramic photo for use in a sky box?
Date: 20 Sep 2006 07:43:47
Message: <45112973@news.povray.org>
I have found a few panoramic photos on the web
http://www.philohome.com/panogallery/holidays.htm
How could I use POV to render 6 square tiles that I could then use to map
this image onto the insides of a cube and not loose the effect -
essentially I want to end up with a skybox
Subject: Re: Render Panoramic photo for use in a sky box?
Date: 20 Sep 2006 08:21:23
Message: <FUliKEA4FTEFFwe+@econym.demon.co.uk>
Since those photos already are cylindrical, it makes more sense to use a
cylindrical sky rather than a box:
cylinder {-y,y,1
    image_map {
       jpeg "mariegalante.jpg"
       interpolate 2
       map_type 2
    translate -y/2
    scale <1,pi,1>
  finish {ambient 1}
  scale 1000
The "map_type 2" makes the image_map cylindrical
The "translate -y/2" makes the image run from -y/2 to +y/2 instead of
from 0 to y.
The scale <1,pi,1> scales the image so that the height matches the
width.
The "finish {ambient 1}" prevents shadows being cast onto the sky
backdrop.
Mike Williams
Gentleman of Leisure
Date: 20 Sep 2006 08:54:47
Message: <45113a17@news.povray.org>
The final images are not for use in povray, will be used to texture the
inside of a cube in an opengl app
Date: 20 Sep 2006 09:22:43
Message: <451140a3@news.povray.org>
   Look at Paul Bourke site: I seem to remember it had an include file
for this...
http://local.wasp.uwa.edu.au/~pbourke/projection/
Jaime
Date: 21 Sep 2006 01:27:22
Message: <451222ba$1@news.povray.org>
Here's what I use for that:
#declare camloc = <0,0,0>;
 location camloc
 right x
 up y
 direction z
 angle 90
 #if (frame_number = 0)
  look_at camloc + x
 #else #if (frame_number = 1)
  look_at camloc + -x
 #else #if (frame_number = 2)
  look_at camloc + y
 #else #if (frame_number = 3)
  look_at camloc + -y
 #else #if (frame_number = 4)
  look_at camloc + z
 #else #if (frame_number = 5)
  look_at camloc + -z
 #end #end #end #end #end #end
With command line arguments +kfi0 +kff5 .
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Sep 2006 02:04:52
Message: <45122b84@news.povray.org>
"Slime" <fak### [at] emailaddress> a écrit dans le message de news:
451222ba$1@news.povray.org...
why not?
#switch(frame_number)
#case (0)
  look_at camloc + x
 #case(1)
  look_at camloc + -x
 #case(2)
  look_at camloc + y
 #case(3)
  look_at camloc + -y
 #case(4)
  look_at camloc + z
 #case(5)
  look_at camloc + -z
Marc
Date: 21 Sep 2006 03:33:24
Message: <45124044$1@news.povray.org>
> why not?
No reason. Never got in the habit of using #switches in povray.
 - Slime
