I am trying to convert a 3D Studio Max mesh (a cargo ship) into a
povray-compatible mesh. I have tried multiple tools for this including
blender, poseray and a variety of on-line conversion tools. But all of
these tools don't load the ship properly - the decks, hull and rudder
are not in the proper place - the hull is below and forward of the
decks, the rudder is positioned far behind the ship.
I've also tried "fixing" the mesh in blender with no luck. But the
really weird thing is that the mesh loads fine and looks fine when I use
a demo of 3D Studio Max or nugraf the model looks fine. Unfortunately,
these demo's are crippled as to not export a usable model.
BTW, this is the model I'm trying to convert. Any help is appreciated:
http://www.the3dstudio.com/product_details.aspx?id_product=820
Bryan
> Bryan
I see there is a 3ds version on that site as well. You'll probably have
better luck with that. I haven't found a good .max converter.
RG
I've some experience in translating meshes.
Send it to me and I'll see what I can do to help you.
Norbert Kern
>> including blender, poseray and a variety of on-line conversion tools.
>> But all of these tools don't load the ship properly - the decks, hull
>> and rudder are not in the proper place - the hull is below and forward
>> of the decks, the rudder is positioned far behind the ship.
>> Bryan
> RG
I've tried both, the .max is completely unconvertable, and the .3ds is
the one with the errors.
Bryan
"Bryan Heit" <bjh### [at] NOSPAMucalgary ca> wrote in message
news:448b0429$1@news.povray.org...
>> RG
> I've tried both, the .max is completely unconvertable, and the .3ds is the
Have you tried loading the .3ds file into Wings3D? I believe Wings
will keep the geometry in the right places once opened, (and if not, which
I've never known, you could replace them fairly easily).
And then export .obj > PoseRay > PoV-Ray...
Worth a try.
~Steve~
> Bryan
>>>RG
> Worth a try.
> ~Steve~
I tried to load it into wings, but it did not work. For some reason
wings would load the file without error, but never actually show the
mesh. Norbert Kern was kind enough to convert it to .obj for me, and
whatever he did worked perfectly.
Bryan
news:448c6b20$1@news.povray.org...
>>>>RG
>> which I've never known, you could replace them fairly easily).
>> Worth a try.
>> ~Steve~
> I tried to load it into wings, but it did not work. For some reason wings
> would load the file without error, but never actually show the mesh.
> Norbert Kern was kind enough to convert it to .obj for me, and whatever he
Hi Bryan
Thanks for letting me know that - very interesting as I'm an avid Wings
user. I'm glad you've got it sorted out through our very own Norbert Kern,
and wait in anticipation to see the render of that cargo ship! (It did look
impressive when I viewed the thumbnail!)
~Steve~
> Bryan
St. wrote:
> Hi Bryan
> Regards,
> ~Steve~
It's not as impressive as in the thumbnail which was on the webpage.
Problem was that I was use the mesh in a rather large animation, so in
the interest of speed I dropped all of the graphics which came with the
mesh, didn't use much in terms of textures (aside from pigments), and
just used the most simple of colouring to detail the ship. This
actually wasn't bad for the effect I was going for - I'm using the
animation for an "educational" DVD about some local dive sites, so we
don't want the animations of the wrecks to look too much like a good
boat, and rather want them to look a little beat up.
I'll see if I can find webspace to put up the animation, but it's fairly
large.
Bryan
PS: The animation is for this artificial reef:
http://www.artificialreef.bc.ca/OurReefs/GB_Church/index.htm
