Hi.
One more relatively stupid question: since so many years I use POV-Ray, but
I never took much usage of pigment_maps. I just want to have a sphere which
is filled in the center with one color, which becomes to another color ath
the sphere's surface.
I cannot use gradient x, y or z, as that creates a color shift only along
one axis. How do I create a spherical color shift?
Just removing the gradient creates nothing than a black sphere, also
something I don't want.
Greetings, and thanks,
Sven
"Sven Littkowski" <sve### [at] jamaica-focus com> a écrit dans le message de news:
4478b500@news.povray.org...
> Hi.
but
which
> Sven
You gave the answer : keyword is spherical pattern
http://www.povray.org/documentation/view/3.6.1/394/
Marc
Marc,
thanks for your hint! I truly don't new about that keyword. Well, I tried
out, but have no success yet. What do I wrong?
sphere
< 0.0, 0.0, 0.0 > 1.0
pigment
spherical
pigment_map
[ 0.0000 Clear ]
[ 1.0000 Blue ]
finish { ambient 0.0 }
scale 1.0075
Sven
Still not functioning. A bug? It only seems to function if the surface is a
color, such as Blue (at 0.0000). But Clear at 0.0000 does make everything
transparent.
Sven
sphere
pigment
spherical
pigment_map
[ 0.0000 Clear ] // Surface
[ 0.0001 Blue ]
[ 0.0001 Blue ]
[ 1.0000 Clear ] // Center
scale 1.0075
A sphere is a surface, nothing else. Objects in povray aren't solid.
What you probably want is media inside the sphere, like this:
camera { location -z*5 look_at 0 angle 35 }
sphere
{ 0, 1 hollow
pigment { transmit 1 }
interior
{ media
{ emission 1
density
{ spherical density_map
{ [0 rgb 0]
[1 rgb z]
Sven Littkowski wrote:
> Marc,
> sphere
> pigment
> spherical
> pigment_map
> [ 0.0000 Clear ]
> [ 1.0000 Blue ]
> scale 1.0075
> Sven
Well, you're only showing the surface of the object. As Warp said, you
probably want media inside it.
However, to see the effect of the pattern more easily, try this:
location -z*3
look_at 0
intersection {
sphere {0, 2}
box {<-2,-2,0>, 2}
spherical
color_map {
[0 color rgb y]
[1 color rgb z]
finish {ambient 1 diffuse 0}
This will show quite clearly a transtion from green to blue (you don't
need any lights to see it either, because of the ambient) and hopefully
allow you to grasp the function better.
Also, you might wonder why I used a sphere with a radius of 2: to allow
you to see the effect of the function past the boundary (distance 1 from
origin). If you'd like a repeating pattern, replace spherical with
onion, and rerender. You'll see the pattern repeated twice.
...Chambers
