POV-Ray : Newsgroups : povray.general : texture_map question Server Time
6 Nov 2026 21:38:12 EST (-0500)
  texture_map question (Message 1 to 4 of 4)
Subject: texture_map question
Date: 25 May 2006 03:23:08
Message: <44755b5c$1@news.povray.org>
I'm trying to use an object pattern to apply a texture_map.  Actually I'm
failing to use an object pattern with a texture_map.
Can anyone show me a working sample, I've tried RTFlippin'M but either I'm
not reading it right or I'm not right in my reading.
Thanks
POV Tips and Hints at ...
http://povman.blogspot.com/
Subject: Re: texture_map question
Date: 25 May 2006 04:42:24
Message: <44756df0@news.povray.org>
"POVMAN" <s### [at] acom> a écrit dans le message de news:
44755b5c$1@news.povray.org...
> Thanks
Is that what you are looking for?
#declare Boule=sphere {0.0, 1} // object WITHOUT material and WITH a well
defined inside
  plane {
  y, 0
      texture{object {Boule
                 texture{pigment{color rgb 0}}  // outside object
                 texture{pigment{color rgb 1}} // inside object
//Marc
Date: 25 May 2006 04:56:27
Message: <4475713b$1@news.povray.org>
Less suscinct
but also possible:
plane {
         z 1
                 pigment_pattern {
                         object { T
                                  pigment {rgb 0 }
                                  pigment {rgb 1 }
                 texture_map {
                         [0 pigment {rgb Cyan }]
                         [1 pigment {rgb Red }]
OR
#declare Fn_O =
function {
                  object { T
                          pigment {rgb 0 }
                          pigment {rgb 1 }
plane {
         z 1
                 function { Fn_O (x,y,z).gray }
                 texture_map {
Date: 25 May 2006 05:52:41
Message: <44757e69@news.povray.org>
> defined inside
>  plane {
>  y, 0
Yes, thank you very much.  I wasn't putting the textures inside the object
braces.  Doh!
