POV-Ray : Newsgroups : povray.general : Any tool to transform objects to meshes Server Time
6 Nov 2026 21:37:53 EST (-0500)
  Any tool to transform objects to meshes (Message 1 to 24 of 24)
Subject: Any tool to transform objects to meshes
Date: 19 May 2006 15:38:46
Message: <446e1ec6@news.povray.org>
Hi!
Is there any tool or way to create meshes out of objects (such as unions,
basic shapes, differences or intersections)?
Greetings,
Sven
Subject: Re: Any tool to transform objects to meshes
Date: 19 May 2006 19:48:52
Message: <446e5964@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote in message
news:446e1ec6@news.povray.org...
> Hi!
unions,
http://jgrimbert.free.fr/pov/patch/tessel/index.html
cu!
Date: 19 May 2006 19:55:53
Message: <446e5b09@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> schrieb im Newsbeitrag
news:446e5964@news.povray.org...
Hi Zeger,
thanks for that link. I opened it, and I see there a number of images and
some kind of functions. But there is no further description or explanation
which could help me to understand the contents better. Can you give me some
information?
Thanks,
Sven
Date: 20 May 2006 03:25:22
Message: <446ec462$1@news.povray.org>
news:446e5b09@news.povray.org...
> Hi Zeger,
and
explanation
some
> information?
uhm, it's the tesselation-patch, a POV-Ray patch that allows you to
tesselate any object.
Never tried it though
cu!
Date: 20 May 2006 10:40:19
Message: <446f2a53@news.povray.org>
I am still looking for a way to transform POV-Ray objects (such as unions,
basic shapes, differences or intersections) to POV-Ray meshes.
Who can help?
Sven
Date: 20 May 2006 11:47:42
Message: <446f3a1e@news.povray.org>
  It's not possible, at least not currently.
Date: 20 May 2006 13:21:01
Message: <446f4ffd$1@news.povray.org>
Shh, don't tell Moray 3.5 that...
Tim Cook
Version: 3.12
Date: 20 May 2006 16:34:09
Message: <446f7d41@news.povray.org>
  It can convert POV-Ray SDL to meshes?
Date: 20 May 2006 19:28:55
Message: <446fa637$1@news.povray.org>
It can convert POV primitive-based CSG objects into meshes.  Yes, you
have to build them in Moray, but when you render it before converting to
mesh, it's still a POV object.  That's what was quoted and to which I
responded, nothing about POV SDL.  *wink*
Tim Cook
Version: 3.12
Date: 20 May 2006 20:37:17
Message: <446fb63d@news.povray.org>
Sven Littkowski wrote:
> Hi!
> Greetings,
> Sven
There's a way to do it in povray's SDL, which is kinda clunky.
It essentially would turn this:
http://flickr.com/photos/pterandon/32127796/in/set-110545/
into this:
http://flickr.com/photos/pterandon/30766135/in/set-110545/
I'd have to find out where and if I've published my own code for this.  But
it involved the trace function and the makemesh macros.
Date: 20 May 2006 22:14:29
Message: <446fcd05$1@news.povray.org>
A "Make_Mesh" macro? Hmmm, that sounds quite interesting! I am going to
research on that macro! Thanks, Greg!
Sven
"Greg M. Johnson" <pte### [at] thereallycommononethatstartswithaYcom> schrieb
im Newsbeitrag news:446fb63d@news.povray.org...
> But
Date: 21 May 2006 03:14:34
Message: <4470135a$1@news.povray.org>
Hash: SHA1
> into this:
	It should be possible to implement the marching cubes algorithm [1]
in SDL using an object pattern. This would probably give better
results (in particular, the arms wouldn't be attached to the sides
of the body).
		Jerome
[1] http://www.exaflop.org/docs/marchcubes/
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2.2 (GNU/Linux)
iD8DBQFEcBNad0kWM4JG3k8RAgRCAKCzRWez30Q7EJS96PlJhZsGsqx2MgCfVRno
yGyl60uOSYucZ+C4ka36QEg=
=hC31
-----END PGP SIGNATURE-----
Date: 21 May 2006 03:25:05
Message: <6b50721g0s2uhchqjhjc2t8inkt8eddohp@4ax.com>
On 20 May 2006 16:34:09 -0400, Warp <war### [at] tagpovrayorg> wrote:
Moray 3.5 can!!!! convert POV-Ray primitives with help of 3DWin plugin
for Moray.
Moray triangulates (evaluates) internally primitives.
-tb
Date: 21 May 2006 06:41:10
Message: <447043c6@news.povray.org>
"Thomas Baier" <NOS### [at] stmuccom> a écrit dans le message de
news: 6b50721g0s2uhchqjhjc2t8inkt8eddohp@4ax.com...
> for Moray.
Actually Moray can export primitives and evaluated CSGs to mesh without
3DWin.
In Moray, the" transform to mesh" feature is based on the display triangles
and quads so you can set the wireframe division in the "advanced" tab of the
configuration (Alt+O) settings.
Moray exports the result as mesh or mesh2 if you want.
Marc
Date: 21 May 2006 07:51:15
Message: <44705433$1@news.povray.org>
Question to those who work with meshes:
my current scene has a long huge pole (diameter 600 units=meters, from -200z
to +1800z) and many vertical cylinders with spheres at their ends inside
which are cut at the huge main cylinder's edge (intersection or difference).
The rendering speed is torturing slooow.
Having this transformed to a mesh, would it render faster?
Greetings,
Sven
Date: 21 May 2006 08:02:54
Message: <447056ee$1@news.povray.org>
news:44705433$1@news.povray.org...
> from -200z to +1800z) and many vertical cylinders with spheres at their
> ends inside which are cut at the huge main cylinder's edge (intersection
> or difference). The rendering speed is torturing slooow.
> Greetings,
> Sven
Hi Sven,
If you're cutting a lot of holes in your main cylinder, then you may be
running into the problem that Mike Williams has covered in his tutorial at
http://www.econym.demon.co.uk/holetut/index.htm.
Chris B.
Date: 21 May 2006 08:08:01
Message: <44705821@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> a écrit dans le message de news:
from -200z
difference).
> Greetings,
> Sven
Likely : calculing lot of differences with a huge object is time consuming,
rendering it as a mesh is very faster.
are your vertical cylinder with sphere all the same?.
If yes, you could make one difference with a short cylinder and multicopy it
all along (with rotations  around z) to build a long cylinder
Marc
Date: 21 May 2006 09:06:09
Message: <447065c1$1@news.povray.org>
Sven Littkowski nous apporta ses lumieres en ce 21/05/2006 07:51:
> Greetings,
> Sven
Is your camera inside that object? Are all those protuding elements like buildings
constructed on
the iner face? Try to use an union instead. If you don't see the outer part, there
won't be any
difference, but will render much faster.
You can also give some thickness to the cylinder wall by differencing it from a
slightly larger one.
Feminism: Men are shit.
Date: 21 May 2006 10:49:56
Message: <44707e14$1@news.povray.org>
Hi!
Please have a look to  the "SciFi: Preview XX: Imperial Carrier" (inside the
"povray.binaries.images" newsgroup) to see the large bays of a starship.
These bays cause that slowing in the render procedure.
Greetings,
Sven
"Sven Littkowski" <sve### [at] jamaica-focuscom> schrieb im Newsbeitrag
> Greetings,
> Sven
Date: 21 May 2006 11:42:56
Message: <44708a80@news.povray.org>
44707e14$1@news.povray.org...
> Hi!
the
> Greetings,
Because they are CSG? waaa I understand.... you could speed up your render
by 100 at least.
why not to declare a union of theses bays  and use them for an
object_pattern  texture_map ?
Marc
Date: 21 May 2006 12:57:30
Message: <44709bfa@news.povray.org>
Hmmm, how would that be done? I have not yet ever used such as an
object_pattern  texture_map.
About the scene:
- most of the cylinders are randomly placed,
- all cylinders have different sizes,
- all cylinders have a texture of map_type 2 (cylinder-type texture).
Marc, can you write more information about such object_pattern
texture_maps?
Greetings, thanks,
Sven
"M_a_r_c" <jac### [at] wanadoofr> schrieb im Newsbeitrag
news:44708a80@news.povray.org...
> by 100 at least.
Date: 21 May 2006 13:30:27
Message: <4470a3b3@news.povray.org>
44709bfa@news.povray.org...
> texture_maps?
> Greetings, thanks,
> Sven
For object_pattern
http://www.povray.org/documentation/view/3.6.1/386/
for texture_map
http://www.povray.org/documentation/view/3.6.1/353/
something as
#declare Bays=union{all_your_bays}//you must declare your bays as an
textureless object (a union in this case)
#declare Overall_texture=texture{
                                                    object{Bays
texture{your_texture}//the NOT bay texture
texture{Bay_texture}//the bay texture
Marc
Date: 22 May 2006 05:24:53
Message: <44718365@news.povray.org>
You might try the "CSG To Mesh" thread in the p.t.s-f group that I posted a
long while ago under another name...  oh, my secrets out.
POV Tips and Hints at ...
http://povman.blogspot.com/
Date: 22 May 2006 22:34:17
Message: <447274a9$1@news.povray.org>
Hi J.. -ah, Povman!
Thanks a lot for your maybe golden hint. I downloaded the .pov file but have
not tried it out yet, because I am at the end of this day. I am going to
render fantastic worlds in my dreams very soon.
Thanks a lot, please expect my feedback! Best greetings,
Sven
"POVMAN" <s### [at] acom> schrieb im Newsbeitrag news:44718365@news.povray.org...
> a long while ago under another name...  oh, my secrets out.
