POV-Ray : Newsgroups : povray.general : Scene Optimization Server Time
7 Mar 2026 20:39:40 EST (-0500)
  Scene Optimization (Message 1 to 5 of 5)
Subject: Scene Optimization
Date: 11 May 2006 15:21:45
Message: <44638ec9@news.povray.org>
Greetings.
What tricks, rules and hints do you know to optimize a complex or any other)
scene in order to prevent unneccessary slowing down of the rendering?
In fact, I have a complex scene in which I have a union (of cylinders and
sphere) being inside a big cylinder (which I made of a difference of a big
with a small cylinder or through an intersection with a big cylinder).
However, that slows down so much.
Let me show you the part of my scene which seems to slows down.
Sven
#declare BayTowers=intersection
 union
  cylinder { < 0.0, -330.0, 0.0 > < 0.0, -300.0, 0.0 > 100.0 texture {
Blau } texture {InnenAufbaut } translate < 0.0, 0.0, 450.0 > }
  sphere { < 0.0, 0.0, 0.0 > 100.0 scale < 1.0, 0.3, 1.0 > translate <
0.0, -300.0, 0.0 > texture { Dunkelblau } texture { InnenOben } translate <
0.0, 0.0, 450.0 > }
0.0, 0.0, 450.0 > scale < 1.0, -1.0, 1.0 > }
Blau } texture {InnenAufbaut } translate < 0.0, 0.0, 1150.0 > }
0.0, 0.0, 1150.0 > scale < 1.0, -1.0, 1.0 > }
  cylinder { < 0.0, -330.0, 0.0 > < 0.0, 330.0, 0.0 > 100.0 texture { Blau }
texture {InnenAufbaut } translate < 330.0, 0.0, 100.0 > }
texture {InnenAufbaut } translate < 330.0, 0.0, 700.0 > }
  cylinder { < 0.0, -330.0, 0.0 > < 0.0, -150.0, 0.0 > 70.0 texture { Blau }
texture {InnenAufbaut } translate < 270.0, 0.0, 200.0 > }
texture {InnenAufbaut } translate < 270.0, 0.0, 600.0 > }
texture {InnenAufbaut } translate < 270.0, 0.0, 200.0 > scale < 1.0, -1.0,
1.0 > }
texture {InnenAufbaut } translate < 270.0, 0.0, 600.0 > scale < 1.0, -1.0,
1.0 > }
  cylinder { < 0.0, -330.0, 0.0 > < 0.0, -200.0, 0.0 > 50.0 texture { Blau }
texture {InnenAufbaut } translate < 240.0, 0.0, 250.0 > }
texture {InnenAufbaut } translate < 240.0, 0.0, 550.0 > }
texture {InnenAufbaut } translate < 240.0, 0.0, 250.0 > scale < 1.0, -1.0,
1.0 > }
texture {InnenAufbaut } translate < 240.0, 0.0, 550.0 > scale < 1.0, -1.0,
1.0 > }
  cylinder { < 0.0, -330.0, 0.0 > < 0.0, -170.0, 0.0 > 150.0 texture {
Blau } texture {InnenAufbaut } translate < 250.0, 0.0, 400.0 > }
Blau } texture {InnenAufbaut } translate < 250.0, 0.0, 400.0 > scale <
1.0, -1.0, 1.0 > }
  #declare Turn=0;
  #declare Diameter=seed(1);
  #declare Tall=seed(2);
  #declare Wide=seed(3);
  #declare Deep=seed(4);
  #while(Turn<100)
   #declare MyDiameter=70.0*rand(Diameter);
   #declare MyTall=50.0*rand(Tall);
   #declare MyWide=(-100.0)+(200.0*rand(Wide));
   #declare MyDeep=1600.0*rand(Deep);
   cylinder
    < 0.0, 0.0, 0.0 > < 0.0, MyTall, 0.0 > MyDiameter
    texture { Blau }
    texture { InnenAufbaut }
    translate < MyWide, -330.0, MyDeep >
   sphere
    < 0.0, 0.0, 0.0 > MyDiameter
    translate < MyWide, -330.0+MyTall, MyDeep >
   cylinder
    < 0.0, MyTall+((MyDiameter/10)*3), 0.0 > < 0.0,
MyTall+((MyDiameter/10)*3)+0.1, 0.0 > MyDiameter/3
   cylinder
MyTall+((MyDiameter/10)*3)+0.11, 0.0 > MyDiameter/3.25
   cylinder
    texture { Blau }
   sphere
   cylinder
    < 0.0, 0.0, 0.0 > < 0.0, MyTall+MyDiameter+0.1, 0.0 > MyDiameter/3
    texture { HellBlau }
   cylinder
    < 0.0, 0.0, 0.0 > < 0.0, MyTall+MyDiameter+0.11, 0.0 > MyDiameter/3.25
   #declare Turn=Turn+1;
  #declare Turn=0;   // Gesamte verbindungslose Seite
  #declare Diameter=seed(5);
  #declare Tall=seed(6);
  #declare Angle=seed(7);
  #declare Deep=seed(8);
  #while(Turn<300)
   #declare MyDiameter=50.0*rand(Diameter);
   #declare MyTall=30.0*rand(Tall);
   #declare MyAngle=180.0*rand(Angle);
   union
    sphere
     translate < 0.0, MyTall/2, 0.0 >
    cylinder
     < 0.0, -(MyTall/2), 0.0 > < 0.0, MyTall/2, 0.0 > MyDiameter
     texture { Blau }
    sphere
     translate < 0.0, -MyTall/2, 0.0 >
    cylinder
     < 0.0, -MyTall-MyDiameter-0.1, 0.0 > < 0.0, MyTall+MyDiameter+0.1, 0.0
 > MyDiameter/3
    cylinder
     < 0.0, -MyTall-MyDiameter-0.11, 0.0 > < 0.0, MyTall+MyDiameter+0.11,
    rotate < 0.0, 0.0, MyAngle >
    translate < 0.0, -330.0, MyDeep >
    rotate < 0.0, 0.0, -MyAngle >
  #declare Turn=0;   // Vordere Verbindungsseite
  #declare Diameter=seed(9);
  #declare Tall=seed(10);
  #declare Angle=seed(11);
  #declare Deep=seed(12);
  #while(Turn<60)
   #declare MyDeep=200.0*rand(Deep);
   union
    sphere
    cylinder
     texture { Blau }
    sphere
    cylinder
 > MyDiameter/3
    cylinder
  #declare Turn=0;  // Hintere Verbindungsseite
  #declare Diameter=seed(13);
  #declare Tall=seed(14);
  #declare Angle=seed(15);
  #declare Deep=seed(16);
  #while(Turn<200)
   #declare MyDeep=1000.0*rand(Deep);
   union
    sphere
    cylinder
     texture { Blau }
    sphere
    cylinder
 > MyDiameter/3
    cylinder
  #declare Diameter=1;
  #declare Width=85.0;
  #declare Height=260;
  #declare Turn=0;  // Leitlichter
  #while(Turn<=1600)
   #declare Runde=0;
   #while(Runde<360)
    cylinder { < -Width, Height, Turn > < Width, Height, Turn > Diameter
pigment { LightBlue } finish { ambient 1.0 } rotate < 0.0, 0.0, Runde > }
    #declare Runde=Runde+36;
   #declare Turn=Turn+100;
  light_source
   < 0.0, 0.0, 800.0 > color White / 2
   fade_distance 1000.0
   fade_power 2
 cylinder { < 0.0, 0.0, -200.01 > < 0.0, 0.0, 1800.01 > 330.0 texture {
Blau } texture { Innen } }
Subject: Re: Scene Optimization
Date: 11 May 2006 18:00:28
Message: <4463b3fc$1@news.povray.org>
See the POV-Ray Speed Guide at the POV-Wiki:
	http://povray.tirnalong.com/ow.asp?SpeedGuide
HTH,
Florian
Date: 11 May 2006 21:57:19
Message: <4463eb7f$1@news.povray.org>
Sven Littkowski nous apporta ses lumieres en ce 11/05/2006 15:21:
> Greetings.
> Sven
When most of the elements of an union share the same texture(s), it's better to assign
that texture
to the union instead of each element. This will save memory and can save some time. In
your case,
you can assign Blau and InnenAufbaut to the whole thing as it looks like the ones that
are used the
most. Saving memory can prevent the use of the swap file, thus providing dramatic
speed improvement.
You use loops to create unions of 100's to 1000's objects, spliting those to only
contain objects
that use a common texture can help. Use several similar loops, one for each texture
familys. Don't
forget to reinitialize the random streams.
Using layered textures increase rendering time, look if you can create single layer
textures to
replace the layered ones.
If one synchronized swimmer drowns, do the rest have to drown too?
Date: 12 May 2006 10:17:48
Message: <4464990c$1@news.povray.org>
Hi Alain,
thank you very much for your rersponse, and yes, you are right so far, I use
for each cylinder an own texture. Simply, because I use that map_type which
twists the texture around the cylinder. I am not sure if that would work if
I apply it only to the entire union.
Sven
"Alain" <ele### [at] netscapenet> schrieb im Newsbeitrag
news:4463eb7f$1@news.povray.org...
>> Greetings.
>> other) scene in order to prevent unneccessary slowing down of the
>> rendering?
>> big with a small cylinder or through an intersection with a big
>> cylinder). However, that slows down so much.
>> Sven
> better to assign that texture to the union instead of each element. This
> will save memory and can save some time. In your case, you can assign Blau
> and InnenAufbaut to the whole thing as it looks like the ones that are
> used the most. Saving memory can prevent the use of the swap file, thus
> providing dramatic speed improvement.
> to only contain objects that use a common texture can help. Use several
> similar loops, one for each texture familys. Don't forget to reinitialize
> the random streams.
> single layer textures to replace the layered ones.
> Alain
Date: 13 May 2006 14:01:20
Message: <44661ef0$1@news.povray.org>
Sven Littkowski nous apporta ses lumieres en ce 12/05/2006 10:17:
> Hi Alain,
> Sven
As the sample don't show any maping or warp, I assumed that the textures could apply
to the whole
set of objects.
Does the spheres use spherical_warp in the textures? If not, you can at least combine
those.
If you start swaping, and you can't reduce the memory use, adding more RAM can bring
HUGE speed
improvement if it can prevent the swaping. Also, unloading some unused processes will
free up some
memory. BE CAREFUL whitch one you kill, removing the wrong one may crash the system,
but a reboot
will cure it without any harm.
AAAAAA: American Association Against Acronym Abuse and Ambiguity.
