POV-Ray : Newsgroups : povray.general : printing in color Server Time
10 Jul 2026 04:32:43 EDT (-0400)
  printing in color (Message 1 to 7 of 7)
Subject: printing in color
Date: 11 May 2006 11:41:22
Message: <44635b22@news.povray.org>
I need to print the code for a  POV scene for use in a large catalog display
(SIGGRAPH) and wonder if there is any way to print out the code in color,
using the display colors. I need the image to be better quality than a
simple 72-dpi screen capture so figured I could print it out then rescan it
at 300 dpi. Any suggestions or ideas would be appreciated - color would
really be preferable.
Thanks much.
Dennis
dhm### [at] comcastnet
http://www.dennismiller.neu.edu
Subject: Re: printing in color
Date: 11 May 2006 13:18:14
Message: <446371d6$1@news.povray.org>
"Dennis Miller" <dhm### [at] comcastnet> wrote in message
news:44635b22@news.povray.org...
>display (SIGGRAPH) and wonder if there is any way to print out the code in
>color, using the display colors. I need the image to be better quality than
>a simple 72-dpi screen capture so figured I could print it out then rescan
>it at 300 dpi. Any suggestions or ideas would be appreciated - color would
> Thanks much.
> Dennis
The Windows version has a 'Use colors' option when you print (the default).
Worked fine for me.
Chris B.
Date: 11 May 2006 13:23:29
Message: <20060511182355.143c1762@mekanori.mon.istic.org>
> code in color, using the display colors. I need the image to be
> better quality than a simple 72-dpi screen capture so figured I could
> print it out then rescan it at 300 dpi. Any suggestions or ideas
> would be appreciated - color would  really be preferable.
If the colours don't actually have to be the same as in the Windows
POV-Ray editor, open the scene file with Vim and do :hardcopy (or
:hardcopy >file.ps). It will print with (colour) syntax-highlighting by
default, if it detects that the printer is capable of colour and/or
greyscale. (If it doesn't, you can :set printopts=syntax:y to force it.)
I suspect one of the many POVing Emacs users will tell you how to do the
same thing in Emacs.
"Follow the enemy and try to prevent  the enemy carrying away the guns."
On 25th Oct 1854, Lord Raglan, on a hill, can see one set of guns;  Lord
Lucan, down in the valley,  sees a different, better defended,  set, and
leads the Light Brigade in its fateful charge. http://surreal.istic.org/
Date: 11 May 2006 15:48:03
Message: <446394f3$1@news.povray.org>
Hmmm, my default prints in b & w  - where do you find the Use Colors option?
thanks much.
D.
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:446371d6$1@news.povray.org...
>>than a simple 72-dpi screen capture so figured I could print it out then
>>rescan it at 300 dpi. Any suggestions or ideas would be appreciated -
>> Thanks much.
>> Dennis
> default).
> Worked fine for me.
> Regards,
> Chris B.
Date: 11 May 2006 15:53:36
Message: <44639640$1@news.povray.org>
Totally weird, as
1.10.1.1.5
says the printout is always monochrome!!
best.,
D.
>> Thanks much.
>> Dennis
> default).
> Worked fine for me.
> Regards,
> Chris B.
Date: 11 May 2006 17:10:13
Message: <4463a835$1@news.povray.org>
news:44639640$1@news.povray.org...
> Totally weird, as
> 1.10.1.1.5
> best.,
> D.
We may have a different version. I have 3.6. The help on mine only goes up
to 1.7 and a search on 'print' doesn't return anything.
Anyway. My printout prints in colour. When I go File, Print, the top option
on the left says 'Use color', which was already selected.
I've also got PrimoPDF (which appears as a printer but generates PDF files)
and that generates a PDF file in colour.
Furthermore, when I cut and paste from the PDF file into Word it retains the
right colours (though if I cut and paste straight from POV-Ray it loses
them).
I tried Powerpoint too and that pastes the PDF content as colour so long as
you paste special and select 'Formatted Text'
If you want you could post the source file and I could generate a colour PDF
file for you (probably best to use povray.binaries.scene.files for that).
Chris B.
Date: 11 May 2006 18:50:48
Message: <4463bfc8$1@news.povray.org>
Thanks very much for the offer. I just noticed that I was using 3.5 and a
lot has changed in that print menu! So I got 3.6 and worked it out.
Thanks again for your offer.
Best.
D.
news:4463a835$1@news.povray.org...
>> Totally weird, as
>> 1.10.1.1.5
>> best.,
>> D.
> option on the left says 'Use color', which was already selected.
> files) and that generates a PDF file in colour.
> the right colours (though if I cut and paste straight from POV-Ray it
> loses them).
> as you paste special and select 'Formatted Text'
> PDF file for you (probably best to use povray.binaries.scene.files for
> that).
> Regards,
> Chris B.
