POV-Ray : Newsgroups : povray.general : Render Window: Selection Lasso rather than Selection Rectangle Server Time
1 Nov 2026 00:01:21 EDT (-0400)
  Render Window: Selection Lasso rather than Selection Rectangle (Message 1 to 14 of 14)
Subject: Render Window: Selection Lasso rather than Selection Rectangle
Date: 1 May 2006 17:56:07
Message: <445683f7$1@news.povray.org>
Greetings.
My suggestion to all POV-Ray developers: the render window should be
featuring a selection lasso rather than the conventional selection
rectangle. That would make it possible to limit a new selection rendering to
only the areas really needed, while the conventional selection rectangle
might very often contain areas not desired to render again (as rendering
unimportant areas slows down unneccessarily).
Sincerely,
Sven
Subject: Re: Render Window: Selection Lasso rather than Selection Rectangle
Date: 1 May 2006 18:56:20
Message: <ev3d525uhl58kg8ckme3vvns1q4ng0fh8g@4ax.com>
Hi Sven.
A common practice is to use #declare and #if statements in your scene to control the
rendering of
certain objects or groups of objects.  For example, you may declare something like
this at the top
of your scene:
#declare draw_sphere true;
Then have an #if statement in your scene to control rendering of the object:
#if ( draw_sphere )
  ... code for the sphere goes here ...
I often use this technique to control detailed vs. simple textures also.
Kyle
Date: 2 May 2006 02:41:21
Message: <4456ff11@news.povray.org>
"Kyle" <hob### [at] gatenet> schreef in bericht
news:ev3d525uhl58kg8ckme3vvns1q4ng0fh8g@4ax.com...
> Hi Sven.
control the rendering of
something like this at the top
> of your scene:
object:
> #if ( draw_sphere )
> #end
I was going to suggest the same thing!!! My scenes generally start with a
whole array of such switches, turning objects on or off. Combined with the
selection rectangle, testing is easy. I do not feel the need of a lasso,
frankly.
Date: 2 May 2006 22:19:15
Message: <44581323$1@news.povray.org>
Thomas de Groot nous apporta ses lumieres en ce 02/05/2006 02:41:
>>Hi Sven.
>>of your scene:
> object:
>>#if ( draw_sphere )
>>#end
> frankly.
> Thomas
Also, rendering an irregular shaped area could ultimately be slower than a slightly to
large area.
This will be due to a substentialy more complex code. The code for a simple square
section is
simple: you limit the region to render. That for an arbitrary free-hand capture will
need to test
every pixel against the desired area. You may also need to render, but not display, in
a, square,
region larger than the selected area.
File not found. Should I fake it? (Y/N)
Date: 2 May 2006 22:34:49
Message: <445816c9@news.povray.org>
Hmm. A pity. Alright, thanks.
Sven
> slightly to large area. This will be due to a substentialy more complex
> code. The code for a simple square section is simple: you limit the region
> to render. That for an arbitrary free-hand capture will need to test every
> display, in a, square, region larger than the selected area.
> Alain
Date: 4 May 2006 10:48:06
Message: <445a1426$1@news.povray.org>
> a slightly to large area. This will be due to a substentialy more
> complex code. The code for a simple square section is simple: you limit
> the region to render. That for an arbitrary free-hand capture will need
> to test every pixel against the desired area. You may also need to
> render, but not display, in a, square, region larger than the selected
> area.
While I don't necessarily think we need this feature, I don't think it
would be that bad.  For each line, you could just store the beginning
and ending points (assuming only convex shapes were allowed) and render
a straight line across.
...Chambers
Date: 4 May 2006 16:40:55
Message: <445a66d7$1@news.povray.org>
Hi Chambers and Alain,
I am also a programmer and when suggesting the new lasso feature, I had
exactly in mind what Chambers explains.
But on the other side, I am not sure how and how much it affects the speed.
I would like to have here an opinion by someone from the POV-Ray team, as
they know the source code the best, and can also very fine estimate how the
new lasso would affect calculation amount and speed.
Greetings,
Sven
"Chambers" <ben### [at] pacificwebguycom> schrieb im Newsbeitrag
news:445a1426$1@news.povray.org...
>> a slightly to large area. This will be due to a substentialy more complex
>> region to render. That for an arbitrary free-hand capture will need to
>> test every pixel against the desired area. You may also need to render,
>> but not display, in a, square, region larger than the selected area.
> would be that bad.  For each line, you could just store the beginning and
> ending points (assuming only convex shapes were allowed) and render a
> ...Chambers
Date: 5 May 2006 00:34:05
Message: <Qq3HlUA4UtWEFwLT@econym.demon.co.uk>
One awkwardness might be the difficulty of doing a shift-lasso to
remember a permanent region.
With the existing shift-drag rectangle, only four parameters need to be
appended to the command line, but an arbitrary shape might require a
very large number of parameters.
Without the ability to set the lassoed region permanently, you'd have to
re-lasso the area after each test run, even if the last test failed so
badly that nothing was visible in the target region.
Mike Williams
Gentleman of Leisure
Date: 5 May 2006 08:47:06
Message: <445b494a@news.povray.org>
Thanks for your replay, Manuel.
However, I am not sure if I understood your points right, let me repeat the
way I understood. So you can correct me.
"When selecting with a rectangle, POV-Ray is currently remembering the
outlines and can therefore repeat a render just like that. However when
using a lasso shape (irregular shape) with more corners than a rectangle,
POV-Ray could not automatically re-render that selection.
And it is not possible to select (based on what you see so far after a
rendering) to select a part of the scene so exactly as you could with a
rectange."
Is this what you meant?
Sven
"Mike Williams" <nos### [at] econymdemoncouk> schrieb im Newsbeitrag
news:Qq3### [at] econymdemoncouk...
>>speed.
>>the
> Mike Williams
Date: 5 May 2006 12:20:01
Message: <web.445b7a2b972075426c4803960@news.povray.org>
> rectange."
> Sven
What he means is that when selecting with a rectangle, only points (4
numbers) are needed to describe the lower left and upper right corners of
the selection.  When you do this, you canoptionally have these written to
your ini file for rerendering the exact selection.  These are written to
the ini as Start_Column, Start_Row, End_Column and End_Row (+SC, +SR, +EC,
+ER).  These can also be appended manually to the commandline to render
onlya region.  However with a lasso selection, many more values need to be
used to describe the region.  It is likely possible to do this, however,
adding it to the ini file or command line would not be convenient.
Not to say that it can't be done, but it would likely have to implemented
differently than the current rectangle selection.
-tgq
Date: 5 May 2006 13:49:59
Message: <445b9047$1@news.povray.org>
Greetings, Trevor!
Yes, I agree with you about both points you are making: it can be
implemented, but due the more positions it would have some sort of impact to
the current command line options (integration of an array of x-y numbers). I
think, this parameter could look this way ("laso needs to be replaced by a
single letter):
+LASSO50:10,40:30,50:50,70:50,80:40,70:30
This could make a hexagon.
But even if so, the old SC, SR, EC,ER parameters could be continued, as
well. Why not?
It is just, that some scenes have details surrounded by many slow objects.
In order to prevent any of these unneccessary slowing objects, only a lasso
can do.
Sincerely,
Sven
> -tgq
Date: 6 May 2006 03:13:47
Message: <445c4cab$1@news.povray.org>
It's trivially easy, actually.  Just render the selection region to a
1-bit mask, then test the mask pixels to see if a display pixel should
be rendered.
Ray
Chambers wrote:
>> than a slightly to large area. This will be due to a substentialy more
>> will need to test every pixel against the desired area. You may also
>> need to render, but not display, in a, square, region larger than the
>> selected area.
> ...Chambers
Date: 6 May 2006 10:27:49
Message: <445cb265$1@news.povray.org>
Sounds very interesting, but also very ununderstandable! Ray, I just never
had POV-Ray doing such. I even don't know, how. Can you give me/us more
details? Can you describe the entire procedure?
Sorry for my unknowledgement, but I really want to understand your idea as I
truly look for suggestions.
Thanks, greetings,
Sven
"Ray Gardener" <ray### [at] daylongraphicscom> schrieb im Newsbeitrag
news:445c4cab$1@news.povray.org...
> 1-bit mask, then test the mask pixels to see if a display pixel should be
> rendered.
> Ray
>>> area.
>> ...Chambers
Date: 10 May 2006 16:20:57
Message: <44624b29$1@news.povray.org>
In semi-pseudocode, you want to do something like this:
render_window::on_mousedown(point)
	if(selmode == lasso)
		pt_array.clear();
		pt_array.push_back(point);
		set_capture(this);
render_window::on_mousemove(point)
		if(get_capture() = this))
render_window::on_mouseup(point)
		release_capture(this);
		build_mask(pt_array);
		pt_array.clear();
	if(win32)
		set up offscreen 1-bit dib
		dib.clear(black);
		define polygon from pt_array
		make region from polygon
		dib.selectobject(region)
		dib.fillregion(white);
		povray.mask.make_from(dib); // white = transparent
povray::render_scene(...)
	for each pixel in scene
		if(mask.exists and mask pixel is black)
			continue;
		render(pixel);
Ray
> Thanks, greetings,
> Sven
>> rendered.
>> Ray
>>>> area.
>>> ...Chambers
